Main > Software Forum
shuffleshot - analog settings?
ErikRuud:
--- Quote ---The speed and sensitivty are the analog settings in the game, not the key/joy speed.
I am talking about the analog controls. I'm not sure if the screen looks the same in every version of MAME.
When I hit the tab key and select 'Ananlog Controls', the first setting is 'Track X Key/Joy Speed'. This setting controls the speed of a simulated trackball when using the keyboard or joystick in place of an actual trackball or spinner. It has no effect on an actual trackball.
The other setting beside sensitivity that will effect how the trackball works in MAME is the speed settings in your intellimouse driver.
REBIRTH:
--- Quote from: ErikRuud on June 07, 2004, 09:07:46 am ---
I gotcha, never noticed they said key/joy. Thanks... still can't get it to work right though :(
ErikRuud:
I checked my Intellimouse settings, on the motion tab, I have speed set exactly in the middle, acceleration is turned off.
In mame the sensitivity is 25%.
Just in case you haven't tried it, try using the 'No Wax' setting. (Press player 1 button 2 to change the wax setting).
REBIRTH:
I will check the Intellimouse speed when I get home, i didn't touch that. I have tried playing with No Wax to slow it down, but 90% of the time it still flys off the end of the board and that Canadian guy announcer yells at me to slow down >:(
bdsjake:
>>and either the disc will not go up the board (stops by the 1 line) <<
hope you find a solution, have the same problem, the discs just abruptly stops. couldn't figure it out myself.
thanks,
