Main > Software Forum
shuffleshot - analog settings?
Pages: << < (3/3)
REBIRTH:
Nope still the same thing.  The puck will go faster or slower, so the settings are changing the speed - but still either the puck stops at the 1 line (whee you would let go of the puck if you were actually playing, it is as if there is an invisible line there that the puck will not cross) - OR - the puck will cross but will fly off the back of the table (with no wax and only pushing just a tiny bit faster than when it doesn't move at all).  I am very upset...!!!!  thanks for the help anyway  :-[
REBIRTH:
For the people who do not have issues with this game:
- what version of MAME are you running?
- what sort of PC are you running?
- What mouse driver are you using?
Thanks!!!!!
ErikRuud:
NoNameMAME 0.76u2.11 unde Windows 2000 Pro (I also had it working under Win98se)
1.6ghz Duron on a Kobian Mercury Motherboard with 256megs ram.
MS Intellipoint Driver version 5.0.174.0
Jungle:
Not that this helps any, but count me as another having the exact same issue.
My "workaround" was to hold the joystick in the up position before shooting.  This moved the puck to where it was getting stuck.  Then, while holding the joy up, I could use the trackball to throw with control.
Not real elegant.
ErikRuud:
I did soem testing, trying to figure out how to recreate the issues you guys are getting.
So far I have found theat the puck stopping means that you are not getting enough speed.
I have never played the real game, so I am not sure how it feels, but in MAME there seems to be a very narrow range between to much spoin and too little.
With more practice I have been able play the game even when using the "slick" wax setting.
Pages: << < (3/3)
Go to full version
