Author Topic: Removing the crosshairs in mame lightgun games  (Read 7899 times)
Magnet_Eye
  • Last login:May 11, 2020, 09:26:19 pm
  • Feel the heat?
    • Web Hosting deals for BYOAC Users!
« on: April 17, 2004, 09:28:11 pm »
I know you can hit F1 to hide the crosshairs, but can you permanently hide them instead of having to hit F1 everytime?
I offer discounted WEB HOSTING to BYOAC members! Only $2.49 a month for a FULL FEATURED account! www.cloud9media.com
  • Last login:February 01, 2026, 01:32:52 pm
Re:Removing the crosshairs in mame lightgun games
« Reply #1 on: April 18, 2004, 12:33:07 am »
Not currently... but come to think of it, it would be easy to add a command line switch in mame.  I'll look into it. :)
Magnet_Eye
  • Feel the heat?
« Reply #2 on: April 18, 2004, 04:04:11 am »
cool. let me know what you come up with.  ;)
« Reply #3 on: April 19, 2004, 02:30:49 am »
ok this should work, I haven't tested it yet as i'm waiting for the next official mame build before I recompile (hate dealing with diff files)
« Reply #4 on: April 19, 2004, 02:31:31 am »
if src/drawgfx.c:
change
static int crosshair_enable=1;
void drawgfx_toggle_crosshair(void)
   crosshair_enable^=1;
void draw_crosshair(struct mame_bitmap *bitmap,int x,int y,const struct rectangle *clip)
   unsigned short black,white;
   int i;
   if (!crosshair_enable)
to
/* static int crosshair_enable=1; */
   options.crosshairs^=1;
   int i;
   if (!options.crosshairs)
In /src/windows/config.c:
Add
{ "crosshairs", "ch", rc_bool, &options.crosshairs, "0", 0, 0, NULL, "draw crosshairs for lightgun games" },
« Last Edit: April 19, 2004, 03:45:45 am by Howard_Casto »
« Reply #5 on: April 19, 2004, 02:42:26 am »
to use it simply type:
crosshair/nocrosshair  ch/noch at the command prompt to set it
If anyone wants to try it feel free and post your results (i should be able to fix any glitches on paper)
Once the next official build comes out I'll go ahead and submit it to mame.  If nothing else, I'll have sirp add it to his hacks page so it can be added to noname mame and all the others.
TheGatesofBill
  • Last login:August 22, 2018, 09:07:04 am
« Reply #6 on: April 19, 2004, 02:55:30 am »
if src/drawgfx.c:
change
   int i;
to
   int i;
In src/mame.h:
add
int   crosshairs;
Add
Okay, now it'll work. The "crosshair"s should have been "crosshair_enable"s.
« Reply #7 on: April 19, 2004, 03:41:11 am »
actually no, it should be crosshairs
if you notice the only instance of "crosshair_enable" in the original source is locally in drawgfx
I commented that out and replaced all instances with the global variable crosshairs, to match with the new command line switch
oops the wrong code was pasted in, sorry
on second glance, however i'm not actually passing the new switch to anything.... the easiest solution is to remove the new global "crosshairs" and instead read and write to options.crosshairs
The code posted above has been fixed in the original post.
« Last Edit: April 19, 2004, 03:46:21 am by Howard_Casto »
TheGatesofBill
« Reply #8 on: April 19, 2004, 03:48:57 pm »
Hmm... still doesn't compile.
Lilwolf
« Reply #9 on: April 19, 2004, 04:15:57 pm »
btw..
wouldn't it be nice to have the player 1 and player 2 seperated?
something I was always annoyed with.. but once you have a real gun (assuming actlabs guns are considered real)..  It doesn't matter.
but others might like it.
« Reply #10 on: April 20, 2004, 07:43:28 pm »
btw..
It would, but the way drawcrosshairs is implemented you'd have to change the source to every single game that uses crosshairs.  So I'm not going to figure it out anyway.  ;)
