Author Topic: Operating system... What are you using?  (Read 321 times)
severdhed
  • Last login:Today at 03:45:59 pm
  • RIP Dinosaur Hippo
« on: Yesterday at 08:22:41 pm »
It's been many years since I've built a cabinet, but I'm in the planning stages of one. I'm the past, I've always used a Windows PC because they are very configurable.
I've recently setup a bunch of console emulator systems using batocera on some raspberry pis, and I've been thinking about using that instead. I've get it installed on a mini PC and setup with final burn neo. It seems to run ok, although it takes longer to launch the games than I would expect (⁷th Gen i5, 8gh ram, 1tb SATA SSD). It was easy to set up, the ui looks ok, but I just worry that I can't customize it like I'm used to.
I'm not a huge fan of hotkey based functions, especially for pause and exit.
I'm tempted to just install Windows 7 and setting it up with Mame and attract mode like I've done with my previous cabinet... What are your thoughts? What do you use?
Sent from my SM-S928U using Tapatalk
Zebidee
  • Last login:Today at 10:48:02 am
Re: Operating system... What are you using?
« Reply #1 on: Yesterday at 11:37:16 pm »
I'm using Win7 with Attract-Mode. Very happy with it. I run it on much older computers than yours.
Aside from familiarity, I also like to use my arcade cab for playing music and PC games, so this suits my needs.
If all I wanted to do was run MAME and some emulators, I'd probably be looking more seriously at a linux or Pi based solution. Still interested in doing this when I have the time to focus on it.
Whatever works for you.
MartyKong
  • Last login:Today at 01:22:36 pm
« Reply #2 on: Today at 01:18:13 pm »
Windows 7 for the arcade. No reason to fix what ain't broke. I run a Retrobat system off a USB for a portable system.
