Author Topic: Ms. Pacman monitor hell  (Read 955 times)
Flashflood140
  • Last login:September 16, 2025, 01:31:46 pm
« on: September 14, 2025, 09:40:47 pm »
I just got done doing a cap kit on my cocktail Ms. Pacman, it wouldn't play blind but I figured out that was a bad fuse. Now, its playing blind monitor is getting power through the plug as I've tested it. I don't understand where to go to next except possible filter cap and the glass fuses on the board. I just want this thing up and running again.  Any hints?
Sent from my SM-S921U1 using Tapatalk
bobbyb13
  • Last login:Today at 03:18:20 am
Re: Ms. Pacman monitor hell
« Reply #1 on: September 15, 2025, 02:03:38 am »
Do you have neck glow on the tube and/or can you hear the crackling zap of the flyback generating high voltage when you power it up?
What chassis is it?
Filter caps rarely go bad actually and usually just generate an AC ripple wave in an image when they are beginning to age.
How much experience do you have with monitors already?
Need more info to help.
Flashflood140
« Reply #2 on: September 15, 2025, 04:49:20 pm »
What chassis is it?
No neck glow, and  no I haven't removed the glass to see if the flyback is working even though it is brand new. The chassis/monitor is a 19in g07 i didn't replace the resistor or the glass fuses on the monitor chassis. I hope this helps.
The experience I have working on monitor is basically self-taught and watching Jon's arcade on YouTube.
« Last Edit: September 15, 2025, 04:51:56 pm by Flashflood140 »
bobbyb13
« Reply #3 on: September 16, 2025, 01:02:23 am »
THIS is the guy you want to follow to fix that beast.
https://youtu.be/fsSKHMhciJ8?si=vlBwUZtKJacIzSNc
I don't know those monitors at all, but Master Zenomorp does...
