Author Topic: retroshooter reaper guns works with vertically mounted monitor?  (Read 12192 times)
SNAAKE
  • Trade Count: (+29)
sup gang, I got a project cabinet(lol its time to play some capcom vs snk 2 online). I was wondering if the modern guns would work on a vertically mounted tv? im trying to use a 43" tv which gives me about 27" visible area. just wanna  make sure I can use it for light guns too when I get a pair. I really  dont know/understand how the moden guns work other than what I saw on youtube you put the sensors on the corners and set it up thats it.
MartyKong
  • Last login:January 09, 2026, 12:25:53 pm
Re: retroshooter reaper guns works with vertically mounted monitor?
« Reply #1 on: May 28, 2025, 01:06:41 pm »
If you're asking about monitor angle I am using AimTrak guns with about a 12 - 15 degree lean back with no problem. When originally designing cab I was told for guns the more vertical the better. Don't know about the reaper guns.
SNAAKE
« Reply #2 on: May 28, 2025, 01:31:31 pm »
not angle, im mounting a 43" monitor vertically and rotate my screen from windows setting so I have about 27" 4:3 aspect ratio. I should probably email the company selling the guns
MartyKong
« Reply #3 on: May 28, 2025, 02:41:59 pm »
Ok, got it. Also the AimTrak sensors are mounted above the tv verses mounted around it so this may make a difference. Hopefully someone with a setup closer to yours will chime in :)
SNAAKE
« Reply #4 on: May 31, 2025, 05:50:11 pm »
well they got back to me saying it should work because screen orientation doesnt matter. guess I will give it a shot(PEWPEW) :burgerking:
SNAAKE
« Reply #5 on: August 14, 2025, 12:29:20 pm »
outta luck btw..the tv I got dont even have an option to make the picture 4:3 aspect and can't calibrate the gun full screen since its always streatched. all other games run fine on 4:3 but the windows and batocera dashboard itself is always stretched wide 16:9 :angry: at some point I might swap the tv..
