Author Topic: Video Jukebox - download now available!  (Read 11570 times)
Rebel Oz 69
  • Last login:Today at 05:30:24 pm
  • Old-school arcade fan.
« on: May 24, 2025, 11:50:02 pm »
It's been quite some time since I've had anything to report, as for the last year or two things have been pretty hectic, but I've been gradually redeveloping/migrating this project over to a multi-platform environment in my spare time.
That said, this project is now at the point where I reckon it's ready (enough), so, (at long last), here it is!
As of now, the support for a secondary display is not enabled (who would have thought having two windows running in a single instance of Flutter would have been so tricky?), but that's the next major code change planned.
Some of the key changes over the prototype version:
  • Licensing options:
    • In the 'FREE Forever' version, the media library will be fully populated, but there will be a limit of 24 items made available. I figure that's what you got in a 'real' classic Jukebox, and for some, that'll be all that's needed. For those of us who want more, licensing options will be available on right-click menu.
    • During the initial Public Beta stage, the software will 'expire' 90 days from release date. It will still be fully functional, but playback speed will be reduced (as a reminder to come back and grab the latest version). This limitation will be removed once the Beta phase is complete.
  • Multi-platform support:
    • While the initial release will be for Windows, we will release Linux and Android versions also (planned for early July).
  • Video support:
    • Now enabled: video skin support! You want to see the platter spinning and the colour tubes cycling? Well, now that's possible.
      Basic wallpaper support is ready to go.
    • Zooming. When video media is playing in the 'mini display', pressing the 'BTN_ZOOM' key (mapped to 'Z' by default) will smoothly transition the video to full-screen mode (and back, by hitting the same key again).
  • Touch Screen support:
    • Full support for touch screen, with swipe gestures to navigate through song cards, tap to select tracks, etc.
  • Colour Palette:
    • The pre-defined (named) colour list now contains over 7000 items (though a couple hundred are aliases for a given colour value - eg 'Dark Gray' and 'Dark Grey').
      Can be viewed in 'ColourSwatches.html' (generated on demand by setting 'ExportPaletteSwatches' to true in the jukebox.ini file) in the program directory.
    • Sortable by either HSV, Name, RGB Value, or Rainbow.
    • Custom colours can be specified as 0xAARRGGBB (Alpha, Red, Green, Blue), or 0xRRGGBB.
  • Metadata:
    • We now have multiple metadata collection methods. If the first fails to collect any meaningful data, we try the second. If that doesn't yield anything, we try the third, etc. We then combine the results.
      Can be slow (especially on large video files), but usually gets good results. With good tagging of files though, it's SUPER quick.
    • If 'UseID3' (metadata tag collection) is turned off (or doesn't yield useful info), we examine the filename.
      With well-named files (ie, 'AlbumName-DiskNumber-TrackNumber-Artist-TrackTitle') it's pretty fast.
    • The framework is in place (though disabled) for MetaBrainz Identification of tracks.
      This will allow the creation of a unique audio fingerprint for each file, then look up that fingerprint in the AudioBrainz online database and retrieve the track information.
      Comprehensive, and quite accurate, but significantly slower to generate our index.
      Requires an active internet connection when creating the index.
    • Improved filename parsing for better track naming.
    • Improved cover image collection.
  • Performance optimisations:
    • Sorting media (which can now be by Album, Artist, Title, Type (audio/video), Random (to 'scramble' the song list), or Popularity) used to take many seconds - sometimes minutes.
      Now, it takes microseconds; eg. 3000-odd media items - 7 thousandths of a second. And that's sorting TWICE (eg, by Artist, then sub-sorted by Title).
    • With checksum generation disabled (which is currently the default; we'll enable this for use with media de-duplication later), reading media metadata and populating the database is orders of magnitude faster.
    • Startup is now complete in under 2 seconds (including skin loading time); Usually much quicker.
      For example, in testing I loaded the default skin, with no previously created database (so, populate from nothing), read and store info for 3319 media items, sort by Artist - took 43.6 seconds (including extracting and writing to file any MP3 cover art metadata) on my old core i5 laptop.
      Same scenario, same media, without the database generation: 1.04 seconds.
  • Media card text sizes (for Artist or Track Title) can be either set for the entire collection, or per 'item'.
  • By default, we'll be adapting the font size in real time to match the current content on display - to use every available pixel to the maximum, and allowing window resizing on the fly.
  • Screen saver has had a facelift:
    • Now with multiple options (Blank, Bubbles, Lines, Mondrian, Rain, Slideshow, Stars, Tron, Warp, or Random).
    • As you see below, we can optionally also display cover art (where available) blended with the screen save effect.
    • If no options are specified, a default configuration will be supplied.
    • Media information is 'split', and each item (ie: title, artist, album, runtime) bounces independantly.
    • Lines - A kaliedoscope using alpha blend modes for silky smooth transitions and fades, now also allows multiple lines at once, and an improved kaliedoscope effect (with adjustable segment count, rotation, speed).
      If you prefer the 'classic' look, that's still in there.
    • Bubbles - Rising through the screen, reminiscent of a carbonated beverage in a glass...
    • Maze - Draws a maze, and walks through the solution. Can also save the maze (with & without solution) separately.
    • Mondrian - The classic random rectangles.
    • Pipes - Various pipe-like structures built around the screen.
    • Rain - My spin on 'Digital Rain' (Inspired by The Matrix).
    • Slideshow - Display images in a folder of your choice, with sub-title.
    • Stars - A twinkling night sky (coloured, or monochrome).
    • Tron - Last light cycle left standing wins.
    • Warp - A starfield rushing past as you trek along (coloured, or monochrome).
    • Random - Pick a new one from the available list each time the screen saver activates.
    • None - If you'd prefer no interruptions.
    • A lot of options are customisable (editable within the 'Jukebox.ini' configuration file), with more coming soon. Also, we've added a (removable) button the the 'lines' screensaver, to access options with 'point and click' functionality.
Some things that aren't quite right yet:
  • Media overlay:
    • Currently we're not displaying the media overlay information (at least, not in the way the settings in the ini file were designed for) - this will be added after we have dual monitor support fully operational.
    • Media waveform / graphic equaliser - disabled while we get dual screen working.
  • DW-Juke Skin options:
    • DW Juke skins should read in fine, but some things have been deprecated, and other things (like skin timers, for example) have not been implemented (yet).
      Check out the included skins for examples.
    • INI file processing is much more robust, and should handle most things case insensitively.
  • Skin swapping:
    • The key action bindings are there, but real-time transition between skins isn't quite ready for prime time - it works for SOME things, but it's not all fully baked yet...
  • Selector Keys:
    • There are still a few issues with mapping the displayed key combination to select a song on Dual-track cards. For now, best option is to click/tap the item (or highlight it using cursor and selecting it that way). Doesn't appear to be an issue with single-track cards. - working.
  • Skin Editor GUI:
    • This will not be available for some time yet, but it is on the roadmap...
  • Show Keys
The link should get you the V0.959b download; please let me know if you have any difficulties.
Please note, this version of the program is run with the 'StartJuke.bat' in the app directory (not the 'obvious' icon). Just uncompress it all wherever you like and run that (If you don't provide a configuration, one will be created for you, or copy in your old DW-Juke config.ini & jukebox.ini - it should 'kinda' work...) :)
Configuration is (like the awesome DW-JUKE) via the jukebox.ini file, so set your songpaths and other things by editing that file (if you can't find it, run once and exit, then it'll be there in the main program directory).
The program linked below is fully functional, with the limitation that it will only use the first 24 tracks in the library; please contact me if you'd like to acquire a license to remove this constraint. I'll be setting up the email address shortly, so in the meantime, PM me here.
One final thing; this version relies on Visual C++, so you'll need to have the VC Runtime (from Microsoft) installed to run it.
Link below. Enjoy! :D
https://drive.google.com/file/d/1SYoj1yL6aEQeaHM80gn2URMVwDD_KMjW/view?usp=drive_link
[/list]
« Last Edit: June 18, 2025, 05:28:42 am by Rebel Oz 69 »
Rebel Oz 69
Re: Video Jukebox - Update.
« Reply #1 on: June 23, 2025, 06:00:13 am »
It's my brother's birthday today, so to celebrate, I'm releasing an update! :)
This version has a few more bugs squished, so Next/Previous Alpha buttons work properly, along with improvements to sorting algorithms and better font handling for legacy skins.
The 'Popular' display is also much better (behaving more like you'd expect), so now, all the buttons on the 'Default' skin work properly.
The most exciting change, though: skin-swapping now works MUCH better, with transparency on the strip grid, strip cards and icons changing properly, and a notification popup displaying the skin info (which can be disabled in the jukebox.ini if you prefer).
Download it here:
https://drive.google.com/file/d/1G9LlpljCa0_PFu3acWk0PpZ2qXVmYInw/view?usp=sharing
Rebel Oz 69
Re: Video Jukebox - V0.961b released.
« Reply #2 on: July 13, 2025, 07:22:02 am »
Another update, with some major performance improvements.
Skin swapping is now almost fully complete.
Song selector enabled, with (customisable) focus box.
'UseZero' skin option now works correctly.
Screen saver now much smoother.
Quite a few little bugs fixed.
We've switched from G-Drive to using a OneDrive folder for uploads.
Comments and suggestions welcome. :)
Download here:
https://1drv.ms/u/c/0e0ef07ab6aa89ee/EYhP_q0cePZCisz6017O5FoBhp6IDcmGZyh52EM6qjWJFA?e=hFQcLG
« Last Edit: July 13, 2025, 05:58:44 pm by Rebel Oz 69 »
Rebel Oz 69
Re: Video Jukebox - download now available!
« Reply #3 on: July 14, 2025, 07:11:49 am »
A quick update (V0.962b) to fix an annoying bug I introduced, where the 'Coming Up' message icon was prevented from being displayed.
I've also changed the method for updating texts in all displays, to populate the displays even if not currently visible (so when they become visible, they have correct values already prepared) - marginally quicker.
I've also tweaked the mini-media display transparency, so if no video is playing, the queue / popular lists display more clearly.
Also fixed the sound-effect volume calculations, so sound effects should now more accurately respect the jukebox.ini volume settings.
Link here:
VideoJuke - 0.962b
jonrome
  • Last login:Today at 05:15:22 pm
« Reply #4 on: July 31, 2025, 04:40:27 am »
HI, I have VideoJuke running happily, how do I upgrade to remove the restriction please? When I right click I get the form but it won't allow me to enter any details.
Jon
Rebel Oz 69
« Reply #5 on: Today at 05:51:12 am »
Jon
Hi Jon,
Glad you like it! :)
I've sent you a PM - looks like the form handling code has gotten broken along the way; I'll fix that and upload an update, then be in touch to make sure it works properly.
Rebel Oz 69
« Reply #6 on: Today at 09:27:54 am »
A quick update (V0.963b) to fix another bug I introduced, where the optimised code for handling dialog borders prevented the Registration Information dialog from holding keyboard focus (thus preventing typing).
Some other changes:
  • Addition of a few new Dual Strip card variants (simple plain labels, with a couple of colored lines for Artist in the middle).
  • Optimised display writing (so screen updates are performed much faster now).
  • Improvements to keyboard buffer handling.
  • Fixed error where under some conditions, the snackbar dialog would display (even when disabled).
  • Added ability to dismiss snackbar notifications by clicking/tapping anywhere on-screen.
Link here:
VideoJuke - 0.963b
