Author Topic: Solved? Win 11 24H2 seems to have broken ArcadeOSD.  (Read 2721 times)
CRTFTW
  • Last login:December 02, 2025, 02:23:08 pm
« on: October 18, 2024, 01:48:06 pm »
UPDATE: possibly fixed further down in the thread
The app opens fine, and looks fine until I select a new resolution. It will switch the resolution, but the app itself will appear frozen on the resolution list screen (it's still working in the background though, because I can close by hitting ESC a few times). Of course this makes doing any adjustments within ArcadeOSD impossible.
Anybody know of a workaround I can try? A certain compatibility mode maybe?
I always update my Emudriver PC to the latest version of Windows for shits and giggles, it generally works out fine. But it's looking like I may need to roll this one back.
« Last Edit: November 21, 2024, 03:21:25 am by CRTFTW »
Calamity
  • Moderator
  • Last login:Yesterday at 02:37:45 pm
  • Quote me with care
Re: Win 11 24H2 seems to have broken ArcadeOSD
« Reply #1 on: October 18, 2024, 02:23:01 pm »
I haven't updated to W11 any of my machines. So none of this software's been tested on W11 by me. It's probably an issue with D3D9 support. While running Arcade OSD, press "D", that will open a debug console. There might be some error message in there.
Steps to create a log:
haynor666
  • Last login:November 21, 2025, 05:45:00 pm
  • retro maniac
« Reply #2 on: October 18, 2024, 02:52:35 pm »
I've just upgrade to Windows 10 v22H2 because I had too - hardware will not work with older system  :D
I don't think there is any beenefit to move to Windows 11 especially new version that is not tested by too many people.
CRTFTW
« Reply #3 on: October 18, 2024, 04:33:15 pm »
Currently no benefit that I'm aware of, I just do it because it's neat running the latest cutting edge version of windows at 480i and 240p
But as for staying on Windows 10, that is sunsetting next year. So if you need your machine hooked up to the internet there may be some risk there. How much risk, I don't know
haynor666
  • retro maniac
« Reply #4 on: October 19, 2024, 04:30:09 am »
I have standalone PC for arcade with no internet connection but my main PC still has Windows 10 22H2 because it works better than Windows 11 23H2 and I still have one year of support for security anyway.
CRTFTW
« Reply #5 on: November 04, 2024, 03:21:59 pm »
Little update, I forgot about this and the 10-day window to rollback to 23H2 expired so I had to deal with it
My best guess is that the problem may have been caused by Windows automatically installing the default AMD driver for my r5 430, in spite of Emudriver being installed previously. So it turns out I was was using ArcadeOSD with official drivers, instead of Emudriver.
So I DDU'd everything, reinstalled Emudriver, blocked official driver with "wushowhide" (not sure if that's going to work long term), and now Arcade OSD seems to be working.
Though it might be a bit slower was than before? There's an approximately half-second freeze when switching resolutions or doing timing adjustments. This seemed to be snappier in the past before 24H2
But it does work now so all is good.
I also installed a preview Windows update in this time, so perhaps it's possible that was what actually fixed it so I guess I don't know for sure.
« Last Edit: November 04, 2024, 03:24:29 pm by CRTFTW »
