Author Topic: Problems with Ultimarc U360 from version 248  (Read 2847 times)
haynor666
  • Last login:November 21, 2025, 05:45:00 pm
  • retro maniac
« on: November 17, 2022, 05:00:52 pm »
Starting from version 248 of groovymame my Ultimarc U360 does not work correctly - buttons attached to U360 PCB works but joystick directions does not. Official mame 249 works fine on the same computer. Also all other emulators works fine.
Calamity
  • Moderator
  • Last login:Today at 08:10:37 am
  • Quote me with care
Re: Problems with Ultimarc U360 from version 248
« Reply #1 on: November 18, 2022, 12:48:54 pm »
This is probably caused by the rawinput feature for joysticks, currently only in GourMAME & GroovyMAME. I don't have a U360 here to test. Maybe it's a matter of remapping the joysticks in MAME's ui, can't say. If nothing works, simply modify the joysticks provider option in mame.ini from auto (rawinput) to other api.
Steps to create a log:
haynor666
  • retro maniac
« Reply #2 on: November 18, 2022, 02:21:18 pm »
Sadly even remapping is not possible. I'll try other provider.
EDIT. winhybrid solves the problem. Thanks for help Calamity :)
« Last Edit: November 18, 2022, 02:49:10 pm by haynor666 »
psakhis
  • Last login:September 24, 2024, 11:54:25 am
« Reply #3 on: November 21, 2022, 11:42:52 am »
Happens here too with arduino encoder.
winhybrid and dinput works as well changing joystickprovider from auto
haynor666
  • retro maniac
« Reply #4 on: November 21, 2022, 03:51:36 pm »
I wonder if firmware in such devices could be altered to work with raw input  ::)
Calamity
  • Moderator
« Reply #5 on: November 24, 2022, 01:22:38 pm »
Haynor,
I'm talking with Monkeypox about a possible fix. Could you try commenting out this line please?
https://github.com/antonioginer/GroovyMAME/blob/27521b272246f522b3935229d9efaf16dab24d6f/src/osd/modules/input/input_rawinput.cpp#L700
haynor666
  • retro maniac
« Reply #6 on: November 26, 2022, 04:01:13 am »
I'm compiling mame with this line commented. I matter of two hours I'll test this solution.
haynor666
  • retro maniac
« Reply #7 on: November 26, 2022, 08:37:21 am »
Tested - no response from keyboard or joystick :/
I cannot even pass warning screen
