Author Topic: How to use/save new geometry settings?  (Read 2954 times)
Endprodukt
  • Last login:January 05, 2026, 01:52:54 pm
« on: September 24, 2022, 08:00:41 am »
Hi there,
long time user but didn't update in a while. Now I'm super shocked about the news. So I tried the new geometry settings to get rid of black borders in Point Blank. It saves the settings in the sliders I did, but on next start it will go back to it's original settings.
Is my general modeline overwriting this? If so, how would I approach this? Thank you for all the help,
Olli
Calamity
  • Moderator
  • Last login:Today at 06:51:12 am
  • Quote me with care
Re: How to use/save new geometry settings?
« Reply #1 on: September 25, 2022, 07:12:07 am »
Hi Endprodukt,
It's working fine here. Just in case, make sure the mode used by that game doesn't match the one that's currently set for the desktop.
Steps to create a log:
Endprodukt
« Reply #2 on: September 25, 2022, 08:50:10 am »
Hi there
No it's a different mode. It does keep the settings in the slider but doesn't show the changes.
Do I need to put something specific in mame.ini?
Endprodukt
« Reply #3 on: September 25, 2022, 11:47:04 am »
Okay attached you find ptblank.txt. Maybe you find something wrong in my system.
Also, in games that I tried to change the geometry using the sliders are not Hyperspin compatible. The game will start but Hyperspin seems to lose focus and goes back to the FE, while the game is running in the background.
Calamity
  • Moderator
« Reply #4 on: September 25, 2022, 04:32:21 pm »
Did you get that log running GM from command line?
There's nothing specific to set in mame.ini, as long as you use the updated ini in GM's zip.
Calamity
  • Moderator
« Reply #5 on: September 25, 2022, 04:43:06 pm »
Anyway, the problem is it's using 320x240 for a 288x224 game. You should probably force -resolution 2560x0 in mame.ini, instead of trying to fix this with the geometry sliders.
Endprodukt
« Reply #6 on: September 26, 2022, 12:03:17 am »
Yes I got that file from the command line.
Why is it choosing that mode? That's weird. Can you tell me how to force 2560x0?
I created the mame.ini with -cc so it's fresh.
Calamity
  • Moderator
« Reply #7 on: September 26, 2022, 03:49:46 am »
Because it's there. (It would be preferable that it did't choose it, I know)
In mame.ini, change resolution auto by resolution 2560x0
Endprodukt
« Reply #8 on: September 26, 2022, 07:17:44 am »
Did it, thank you! :) I wonder why the geometry settings don't save for me, but it's not so important. After a power surge my bios has been corrupted and I have to fix that now :(
Calamity
  • Moderator
« Reply #9 on: September 26, 2022, 08:10:56 am »
They do save, but for some reason there's an error when trying to apply the changes (in your log). I don't know the cause of it. Might be an issue with bad timings caused by setting the geometry values a bit too far, can't say.
Endprodukt
« Reply #10 on: September 26, 2022, 01:32:38 pm »
Okay! Thank you anyways, thank you for all the hard work you put into GM :)
