Author Topic: Component modding CRT TV - "China TV"  (Read 38245 times)
Zebidee
  • Trade Count: (+9)
  • Last login:Yesterday at 04:51:44 pm
« on: December 09, 2021, 02:04:33 pm »
This thread is to document component-modding CRT TVs. Thought I'd kick it off with a "China TV" that I bought new a few years ago.
Here it is, new and sealed in the box. Well, it is mostly new - the CRT tube is actually recycled/refurbed. But the rest of the TV, including chassis and shell, is completely new. The brand/model is "Distar CTV1121-20" and it is assembled in Thailand.
I'm going to put up a few posts with pics to break up the text, so please be patient with me. To start with, here is the TV I'm going to be component modding today:
« Last Edit: July 09, 2025, 10:03:06 pm by Zebidee »
Zebidee
  • Trade Count: (+9)
Re: Component modding CRT TV
« Reply #1 on: December 09, 2021, 02:26:15 pm »
Here are some pics of the TV inputs for the Distar CTV1121-20. The only options are RF and AV/composite.
There are 2 AV inputs, at the back and the side (the second set of AV connections at the back are for output). Both back and side AV inputs are the same, the TV doesn't differentiate them internally.
I'm going to repurpose the side AV inputs into component/YPbPr inputs, so that is why we have a close-up.
Also here are some pics to show that the TV works. You can see the normal menu via remote control. I've already accessed the service mode and enabled "YUV" there.
I'm not going to get into how to access the service/factory mode here. This is covered in the attached the service/factory adjustments manual for a TV very close to this one (not identical, but in English and close enough that it works).
Zebidee
  • Trade Count: (+9)
« Reply #2 on: December 09, 2021, 03:22:18 pm »
OK, enough of the introductions. Now for some nitty-gritty.
I pulled the back off the TV and removed the chassis for closer inspection.
The area circled in yellow is where we will be focusing our efforts (below).
As an aside - this chassis, in various forms, seems to be officially called the "China TV" chassis (thus the CTV prefix), and it is very common especially in Asia and especially in developing countries. So in addition to China this includes India, Philipines, Indonesia, Malaysia, Vietnam, Thailand... and that is just what I've seen so far, so probably many more. Anyway, back to the modding.
First thing to look for is the jungle chip. On this TV it is the big one in the middle. In general, when looking for the jungle chip on any TV look for the big one first.
In this case the jungle IC designation is "8895CSNG7GG9". This chip incorporates OSD (On Screen Display) functions. There are no RGB inputs and no OSD RGB inputs to hijack (as they are all internal to the chip).
A close inspection of the schematic reveals component inputs (labelled "Cb", "Y", "Cr" at pins 19,20,21).
Now for a spoiler alert - this TV chassis is built onto a PCB that already has component input capability, but the manufacturers decided to leave all that out to save some money. Fortunately for us, we can use that to our advantage.
Following the PCB traces back from those jungle component input pins brings us to the part of the board we will be working on. The pins connect through to the 3 x ceramic disc capacitors (103, 0.01uF, C801, C802, C803). These 103 capacitors simply clamp these unused component inputs to ground, best practice is to not let them "float".
For the next step, we are going to remove the 103 capacitors (C801, C802, C803), and we are also going to remove the 6 wire bridges (R804-R809) you can see above them
NEXT - Action
« Last Edit: December 09, 2021, 06:44:25 pm by Zebidee »
Zebidee
  • Trade Count: (+9)
« Reply #3 on: December 09, 2021, 05:04:38 pm »
OK, now for the action you have been waiting for.
Let's start by removing some stuff - those 3 x 103 ceramic capacitors (C801-C803) and 6 wire bridges (R804-R809), as framed in yellow below.
Here is what it looks like once they are gone. I've added some blobs of colour for tracking signal paths
Next step is to replace the 103 caps with 2 x 104 for C801 & C802, which correspond with Pr & Pb. I'm going to use a 1uF electrolytic cap for C803 (Y). After some tests and looking at other schematics, I decided to go with a 104 (0.1uF) ceramic capacitor on Y as well.
Also need to replace 3 of the wire bridges with 75R resistors (termination to ground) and the other 3 with 100R resistors (in series with signal). The 75R are the ones with the distinctly purple/violet end, the 100R are the ones that have black bands in the middle (and brown at the ends). I used permanent markers for the Pr/Pb/ground connections, but didn't have a green marker sorry.
Here is a pic with the inputs attached
This is where those inputs will be connected to. I've modified the side AV input for component! Using a tiny screwdriver I carefully replaced the yellow/red/white facscia with green/blue/red. I also rearranged the connections a little on the back of the PCB (not pictured). Had to add a ground wire and rearrange the connector slightly after taking this photo.
OK, that's all for now. Will be back with more progress soon.
« Last Edit: February 21, 2025, 12:43:36 am by Zebidee »
Zebidee
  • Trade Count: (+9)
« Reply #4 on: December 09, 2021, 06:30:01 pm »
So, it all works! here are some shots of it all connected up. On the second pic you can see the standard test colour bars on the screen via PC input.
Here is the TV connected to a standard DVD player by component. No GreenAntz required for this, it is completely standard input from the DVD player.
Finally, some gratuitous shots of arcade game on a standard CRTEMU PC setup + GreenAntz
Please ask questions :D
« Last Edit: December 09, 2021, 07:13:20 pm by Zebidee »
Zebidee
  • Trade Count: (+9)
« Reply #5 on: December 09, 2021, 07:11:30 pm »
Finally, a shot of the modded TV with the cover back on, and component input (from PC/CRTEMU + GreenAntz) via side input panel. Neat and tidy, you wouldn't know that it wasn't done in the factory!
« Reply #6 on: December 09, 2021, 07:20:05 pm »
Great write up and great pictures too.
How did you come up with the values for all those resistors and caps, and what do you do if the chassis doesn't have the holes for the caps? I am assuming you just tap the legs of the IC and wire it to a breadboard?
Zebidee
  • Trade Count: (+9)
« Reply #7 on: December 09, 2021, 08:02:58 pm »
Thanks Malenko :D
I had no specific schematic, but came up with the resistor and capacitor values by looking at many datasheets and schematics for similar TVs with this class of jungle chip. I did a fair bit of experimentation and used an oscilloscope too, not just my eyeballs. Also, this is not the first time I've done this mod for this TV (though definitely the neatest!).
Using 75R for termination is obvious and then 100R in series is very common, in almost every comparable instance I've looked at. Certainly no other value. In any case, the spots were there for the 75R and 100R resistors and there is nothing else that would conceivably go there. And it looks good, better, with scope and eyeballs.
As for the capacitors, 104 (ceramic 0.1uF) is very commonly used after the 100R resistor in similar TV schematics. There are some exceptions of course, one of which is where I've seen a 1uF electrolytic cap used on the Y signal instead of 104, either with or without the 100R resistor. In this case the dead giveaway was the electrolytic cap symbol printed onto the PCB for the Y signal (C803) vs the ceramic cap symbol symbol used for Pb/Pr (C802/801). I later reviewed schematics closer to this TV and changed to 104 ceramic cap for Y as well. So three 104 caps, one each for Y,Pb,Pr. On the virgin chassis PCB, all three just had 103 caps to clamp the unused signal pins. So I whipped out the 103's and replaced with 104 caps.
So I'm confident that I've chosen well for this TV - however other TVs may/will be different. It is a good starting point for your own projects, but won't work exactly the same with every other TV.
You don't necessarily need any breadboard. Probably not, I'd try to avoid it myself. If there aren't too many bits to add, they can be put above or below the PCB. It is also possible to add to twist 2 or more components (e.g. 100R resistor+104 cap in series) together so that they fit into the space for 1 part on the PCB. Grounding 3x75R resistors together isn't too hard either. You can be very creative with this stuff.
I try to keep my work neat and tidy, especially for the pics. But some of the stuff I've prototyped looks like a gymnastics hall. Electronics in 3D.
With all that in mind, it'd be great if other people can contribute with their own component-modding projects.
« Last Edit: March 04, 2025, 04:06:39 am by Zebidee »
Zebidee
  • Trade Count: (+9)
Re: MOOORE Component modding CRT TVs
« Reply #8 on: March 06, 2025, 08:54:16 pm »
Last month or so I've gone and done component mods to two more of these China TV chassis, and I've learned a bit more, and want to share that. I also re-visited one of my earlier mods.
I took these photos over a period of roughly a month, a little while ago (Jan/Feb). I've had to pick out the best, as the TVs have mostly been closed up and put away already, and don't want to open them up again just for photos. So I'll be using pics from three very similar, but different, China TV chassis in this post. You will notice some minor differences.
These next two TVs have the same basic China TV layout, same jungle. However, unlike the ones I did earlier, these PCBs don't have any blank spots for the extra resistors and capacitors. There are no convenient landing points for the component inputs, and there are no copper traces leading to the jungle pins [Pb, Y, Pr] -> [19, 20, 21]. There isn't even any copper trace around the Y input (pin 20)! It is what it is.
Means some fiddly soldering right onto the legs. Will need to scratch off copper trace connecting pins 19 and 21 (Pb and Pr). In this pic we can see that the trace connects 19 to 21, and then to C804, a 103 (10nF) ceramic capacitor. This 103 cap clamps the Pb, Pr signal pins to ground, to prevent unused inputs from "floating ". It needs to be removed. The first pic below is untouched and shows which pins are the signal pins; the second pic (from an identical but different TV) has had the trace scraped off between Pr and Pb, and C804 has been removed.
Before soldering, I did some crimping and put it all together into 4-pin female headers, which I'll explain in a moment.
For my first attempt at soldering to the jungles pins, I attached some stout leads to the wires to make them sturdier, then stuck the ends into the PCB holes for the pins, and soldered. This works OK, great even, but the wires shoot straight up and, though it is sturdier than it looks, I still worry it might break off accidentally. Not that this has ever happened. It works fine, I won't redo it, but I can do better!
See that 103 capacitor, C804, circled in yellow? It is the one I mentioned earlier - I forgot to remove it before taking the pics! I went back, removed C804, moved the Pr input to the newly vacated hole. I then also cleaned it all up, it is still quite messy in these photos, and sometimes you don't realise how messy something is until you see the high-res images. The black spots near the pins are just magic marker, so I know which pins to solder.
For the second TV, I took a different approach. I recycled some surplus 3-wire TV ribbon cable and added an extra wire for GND.
Then I stripped a few mm of wire, carefully laid the ribbon down on top of the jungle, bent the exposed wires to meet the pins, and secured it with some paper tape.  The ribbon cable/wire has the right combination of being somewhat stiff yet flexible enough to make this work. This made the soldering much easier, and the wires more secure.
I put some coloured heat shrink on the wires so I wouldn't get them mixed up.
To make things more manageable, I created a mini input-PCBs for the input circuit. I used some offcut breadboard, 2 x 4-pin male connectors for IN/OUT, 3x100R resistors, 3x75R resistors, and 3x104 (100nF) ceramic capacitors. I've included a simple schematic. The last pic shows the input-PCB inside some heat shrink for electrical insulation. I cut some holes for the connectors. I didn't bother with heating the heat-shrink as it works perfectly the way it is, I can still remove it to get at the PCB inside, and those white connectors are a bit sensitive to heat.
104 (0.1uF/100nF) capacitors are pretty much always what you'll need for Pb, Pr. I've also gone with 104 (100nF) on Y, and that is right for these TVs. For other TVs with different jungles, some might go up to 1uF on Y, but I suggest starting with 100nF anyway. This is because capacitors in parallel ADD capacitance, and it would be easy to solder a 1uF capacitor below the 100nF. This would give you a total of 1.1uF, close enough for testing. If it works better that way for your TV, then you can make it permanent. If this seems confusing, then just stick with 100nF.
These input-PCBs are very convenient, especially now I have several TVs with the same component mod. In normal use, when the TV is closed, it is connected to the external side-input so standard video cables can be used.
When a TV is on my bench, for testing with GreenAntz connected, I can just unplug that external side input and use a shorter, more convenient cable that I've hacked. This saves space and hassle, the soldered connection to the jungle is more secure, and it is easier to work on the main PCB with everything unplugged.
I even created an input-PCB for one of my earlier mods, but without the input resistors/capacitors, as these are already present on the main PCB (see pics below). I just find it very convenient to use, and having all my TVs modded the same way makes it interchangeable.
For the connectors, I bought one of these kits with a range of JTC 2.54mm pitch terminal connectors with a range of sizes. The kits cost about $3-4 each and come with all the pins for crimping. I've been using a lot of 4P connectors, I tried to find these cheaper separately but could not. So I just bought another kit! I should probably invest in a better crimping tool too.
I will post again soon on:
- minor modification to the neckboard for a sharper picture
- schematics
- accessing and tweaking the service menu
- improving the picture sharpness
- hacking the EEPROM
« Last Edit: March 06, 2025, 09:56:20 pm by Zebidee »
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
« Reply #9 on: March 06, 2025, 09:32:52 pm »
This is brilliant!  I have some tvs from the 90s that ive been hoarding with hopes of pulling the case to see if they are candidates for chassis swap for some of my games. shooting from the hip what would you say my odds are of doing something like this to say a 90s zenith , rca?
Zebidee
  • Trade Count: (+9)
« Reply #10 on: March 06, 2025, 10:53:33 pm »
You should do your own research first. Identify model number and chassis number if possible. Identify the jungle IC number and where the inputs are. You should do an online search for datasheets on your jungle IC and schematics. Sometimes you can't find the exact datasheet or schematic for your TV, but one for something close can often suffice.
If you can do an RGB mod, then you are probably better off doing that. Unfortunately you can't do that with all TVs.
YPbPr/component input is almost as good as RGB if you are using the latest GreenAntz RGB to Component Transcoder v1.94. GreenAntz gives much better image quality than the cheap transcoders on Aliexpress (which are actually a substandard ripoff of a leaked old pre-GreenAntz design), which have washed-out color and "flickeryness".
These "China TV" chassis I'm working on are available new, also on Aliexpress, from around $25 each. They will work with most standard 14"-21" CRTs. They give better performance than most cheap arcade monitor RGB chassis that I've used. I've worked on them a lot and gotten to know them pretty well, so can perform most tweaking and repairs myself.
Zebidee
  • Trade Count: (+9)
Re: Component modding CRT TV - NECKBOARDS
« Reply #11 on: March 07, 2025, 03:14:43 am »
I noticed a lot of "bleeding" on blue with these last two modded TVs. After investigating many dead ends, I found the solution on the neckboards.
For some reason their neckboards have a 471 (470pF) capacitor (circled in yellow) on the blue drive transistor instead of a 391 (390pF). My earlier modded TVs have a 391 there, and they didn't have the bleeding issue. Don't understand why they used a 471, maybe it looks better that way with TV/composite video input. Looks pretty crap with component input.
Anyway, I swapped out the 471 for a 391 and the picture improved significantly, much sharper and less bleeding   :cheers:  I also found a burnt-out resistor (33R) on one, and replaced it with the blue one there (30R, circled in purple). That resistor connects G1 and G2. 30R was the closest value I had available, it seems to be holding up fine.
I'll improve the picture a bit more again by tweaking the service menu. More on that soon.
« Last Edit: March 07, 2025, 03:16:32 am by Zebidee »
Zebidee
  • Trade Count: (+9)
« Reply #12 on: March 08, 2025, 01:32:22 am »
Uploading some info: datasheets, schematics, service mode.
None of this is 100% match for these TVs, but is close enough.
To access service mode:
- press MENU
- press 2,4,8,3 - the word "FACTORY" should appear.
- press DISP
This gets you to page 0, "white balance", of the service menu. Press number keys to change page. To go above page 3, find "PAGE" and flip the value to "1". Press MUTE to go up one page. AFAIK this is the only way to access pages above 9.
« Last Edit: March 08, 2025, 01:41:20 am by Zebidee »
Zebidee
  • Trade Count: (+9)
« Reply #13 on: March 08, 2025, 01:45:07 am »
More China TV datasheet/schematics/service mode info that would not fit in last post. Attached as a zip file.
dennisbgi7
  • Last login:May 24, 2025, 01:38:44 am
« Reply #14 on: May 09, 2025, 03:46:15 pm »
Firstly, amazing idea and amazing execution, this is fantastic. I did have a question, more of a noob question since I am new to all this.....what did you do about the audio? I understand the side port now takes in component video signals, but since the composite audio is being replaced in this case, what are you doing about that? Also, is the composite input at the back still usable after this?
Zebidee
  • Trade Count: (+9)
« Reply #15 on: May 10, 2025, 10:38:10 am »
Thanks.
Composite video and audio L/R can be input to a standard set of 3 RCA ports at the back: yellow for video and red/white for audio. They still work as normal.
Both component and composite video can be connected at the same time, and I can flick between inputs with the remote or the front menu buttons. However, both composite and component share the same audio inputs.
See this pic of the rear inputs, and the unpopulated component input holes. Designed to share the same audio inputs as composite, and in these TVs is all connected together internally. I didn't use those blank holes as there was no convenient way to securely mount the extra ports inside. Re-purposing the side connector was much neater and easier.
dennisbgi7
« Reply #16 on: May 10, 2025, 04:24:57 pm »
Thank you so much for the response. I am actually using this as a guide and planning to do this myself soon. However, since I am a newbie, I do still have some questions, primary of which is that, in the first post at the end you mentioned having to add the ground wire by modifying the pcb...what modification did you have to do on that one?
Zebidee
  • Trade Count: (+9)
« Reply #17 on: May 15, 2025, 10:46:32 am »
... in the first post at the end you mentioned having to add the ground wire by modifying the pcb...what modification did you have to do on that one?
Ah, you mean the side connector?
Unfortunately I didn't take any pics of the modded back side, and I've reassembled all the TVs now.
Every TV model be a little different, and I've done about 5-6 TVs now. They all required some modification, but slightly different in each case. In most cases the left/right audio channels (red/white) were connected at the PCB. In most I had to use a craft knife to carefully cut a channel separating the audio inputs - sometimes a small cut, sometimes quite large. In all cases the cables back to chassis had only 3 wires (video, audio, ground), but for our purposes we need 4 wires (Y, Pb, Pr, ground) so a wire must be added.
Here are some pics of a side connector I salvaged from a dead TV. The TV had been left out in rain by a former owner, thus the corrosion on the outer metal shell.
Those coloured insets (yellow/red/white) can be removed and replaced with something else - you will need to desolder the metal ground shells from the PCB and prise them off with a small screwdriver or something. Then the coloured "donuts" come out, you can replace them with something more appropriate. I happen to have RGB coloured ones handy already, but you could make them yourself from some plastic or card.
Here is a close up of the underside. The three big pins at top, all connected together, are the grounds. They all connect to the metal shells on the other side. You'll need to desolder them to change the coloured insets.
The three big pins below that are (from left) for video, audioL and audioR. Notice that audioL & audioR lines are linked by a small bit of trace? I marked this in yellow.
The three smaller pins at top left are where the cable connects. See how only one audio wire is connected? Forget about stereo sound with this TV! The other two are for video and ground. There is a spot to add a fourth wire, but it isn't used. I marked this in turquoise, this is where you'd add the extra wire when modding this for component input.
So this side connector would be very easy to adapt for Y Pb Pr. You could just cut the small bit of connecting trace between the audio L&R. In this case the ground is already connected, would need to add a wire for one of the component colours.
« Last Edit: May 15, 2025, 07:55:59 pm by Zebidee »
dennisbgi7
« Reply #18 on: May 16, 2025, 04:20:02 am »
Thank you very much! That cleared it up completely. Now I feel confident enough to attempt the modding.
Razmann4k
  • Last login:July 30, 2025, 07:50:15 am
  • I want to start using CRTs again!
Re: Component modding CRT TV - "China TV"
« Reply #19 on: July 19, 2025, 06:37:11 pm »
Hi Zebidee, thanks for this guide, it's really in-depth and helped me out a ton ;D. I'm in a bit of a pinch however, as I completed the component mod on my TV but cannot get the factory menu open to enable YUV. My TV is branded as a 'Sonistar T-1499', and it uses the LA76931 jungle chip. I found a factory manual for the chip, which I will attach below. The factory mode information is on pages 57 - 62 and the gist is: 'Press “M” key to enter into factory mode, “M” will show on the top left corner of screen.' and ' You need a repair RC(model: HYDFSR-N-GEO)'
I'm assuming that means it's not possible to bring up the factory menu with the normal TV remote, have you ever run into this before? I tried looking up this HYDFSR-N-GEO service remote, but I can't find anything helpful. I just don't want my work on the component mod to waste :-\, so if you know anything I can do, that would be great!
Thanks.
Zebidee
  • Trade Count: (+9)
« Reply #20 on: July 20, 2025, 11:31:03 pm »
Oh dear, this is what I always dread. Fortunately it hasn't happened to me, or at least I've always been able to find a work-around.
Don't assume anything, unless there is no other option! Many of the world's biggest problems are caused by people making false assumptions.
Requiring you to use a special service remote is especially cruel. I've heard of it before for things like PVMs, not China TVs though! Let's hope it isn't that.
Have you tried to use your normal remote? Maybe that is all you need. Does it have a "M" key? Maybe M just means "MENU".
Some remotes have a secret service mode button: they might have a small hole by which you can use an unfolded paper clip or something to press the service mode button. Much like ejecting a sim from a smart phone. Sometimes they have a button that is only accessible by pulling the remote apart.
Otherwise, you might need to directly hack the EEPROM. You only need to change one byte from "0" to "1". This will be purely educated guesswork. You might be able to guess which byte by comparing nearby values with the defaults stated in that datasheet.
Looks like you have a 24C08 EEPROM (8K, 1024x8, 64pages x 16 bytes), but I can't be sure as your picture does not provide enough detail. I've circled in yellow what I believe to be your EEPROM. You should also look around for an unused 4-pin header, sometimes they are already on the PCB, but unpopulated. I see an unused header that looks promising, circled in turquoise.
Sometimes, like with my recent mod to a TCL CRT TV, I was somehow prevented from editing the EEPROM while it was on the PCB via a read-only setting. I don't understand exactly how or why they achieved this for my TCL TV, maybe something to do with the jungle IC. If yours is similarly "fixed" to read-only, then you may have to physically remove (de-solder) the 24C08 from the PCB to edit it. You could also try copying the .bin file onto a fresh new IC, which hopefully won't have the read-only settings.
Anyway, before editing anything you should extract a backup. You would also probably find it worthwhile to order some 24C08 ICs while you are ordering the CH341a EEPROM editor/reader. Both are cheap and available from your favourite online retailers.
For more on EEPROM hacking, please have a look at my recent thread on this.
You could also try searching for other examples. I did a search on "eeprom buttersoft markozlad" and got many interesting hits. I chose those two users specifically because I know they have explored TV EEPROM hacking to enable RGB mode on the Aussiearcade.com and shmups.system11.org forums.
Looking at your input mini-PCB, at first I thought you had gotten the inline capacitors and resistors back-to-front, and you used 75R instead of 100R, but I see that is how they are in the schematic you provided. I'd probably just stick to ceramic capacitors where possible, though the blue polypropylene film caps you've used should be sufficient. If it works then it works :D
Hope that helps.
« Last Edit: July 23, 2025, 08:19:00 am by Zebidee »
Razmann4k
« Reply #21 on: July 22, 2025, 06:14:37 am »
Well, I've got great news! I followed your advice and took the remote apart, after a few minutes of prodding around different traces, I found the factory mode button! I managed to enable YUV, and I now have component! I also made a v2 of the input mini-PCB with 103 caps instead of the blue ones and shielded wire this time. I wish I had a picture of it but I already closed up the TV because I was glad I could finally get it over with. :lol
The factory menu on this TV has about 20 pages of settings, very thorough, and strangely enough you can enable YUV but right underneath you can enable DVD, which I though was the same thing, and even the TV doesn't seem to know the difference! When I enabled YUV and DVD, the component input showed up under the DVD input, and when I disabled DVD, then it showed up under YUV-in. The only downside to all of this is no matter what I do, this TV no longer shows colours with composite after I enabled YUV and DVD in the factory menu, even when I plug the composite input into the original AV in, which is very strange as I didn't touch any of that. I don't really mind as I don't ever plan on using composite again, but it's quite strange nonetheless.
Thanks again Zebidee!
Zebidee
  • Trade Count: (+9)
« Reply #22 on: July 22, 2025, 08:39:19 am »
That really is great news!   :applaud:
I notice on the very last page of the service manual, there is a simplified schematic, focused on the jungle chip, with 104 caps on the Cr/Cb inputs.
Next time you open up the TV you might try experimenting by adding extra 104 caps in parallel with the 103's, which simply means lightly soldering the 104 legs over the existing 103 legs. This adds their capacitance, gives you 0.11uF, effectively the same as 104 by itself (0.1uF). See if it improves the picture or not. You won't break anything doing this, and the 104 caps are easy to remove if you don't like it.
Cheers!   :cheers:
Try setting various things back to default, especially relevant parts of menu page 3. But for all I know it might be something else, like in the colour system settings.
Razmann4k
« Reply #23 on: July 22, 2025, 09:33:01 am »
As for the 104 caps, will do! I forgot that that the pdf would contain the defaults, thanks for mentioning that, I'll confim all the settings apart from YUV is set to default (in that menu, not the specific tuned settings for my tube of course!)
At the moment believe it or not but I don't have a decent way to even test my component. I've been using a DVD player but the Cb port on it seems to be dead (confirmed with modern TV). Another old DVD player I have works properly when I plug it into my modern TV via component but when plugged into the CRT it's a garbled scrolling mess, which I've deduced as it outputting 480p instead of 480i. Now the DVD player can output 480i but I don't have a remote to change the settings with! Until my PS2/PS3 component cable shows up, I just have to hope it works properly because the Y and Cr looked good on that other DVD player.
Zebidee
  • Trade Count: (+9)
« Reply #24 on: July 22, 2025, 02:40:13 pm »
Yeah - I also forgot to suggest trying a 104 (0.1uF, instead of the 1uF can cap) on Y - though it is a little more hassle to test as you'd have to remove the 1uF. On my TVs I found that the default 1uF cap made Y a tiny bit fuzzier, less sharp - though some might see this as an advantage!
This is because these jungles artificially create a slight delay on the chroma signals as it takes a few hundred nanoseconds (fraction of a microsecond) for the IC (basically a tiny computer) to digitally process or "demodulate" the analog Pr/Pb into Cr/Cb and then => RGB, the delay means a visible Y/luma shadow, to the right, can be visible in some situations with a crisp 240p input. So, making the Y a little fuzzier disguises the delay. So I suggest trying 104 (0.1uF) on Y, but ultimately you may prefer the 1uF.
Anyway, probably best to wait until your PS2/3 component cables come in to test that.
Try swapping the red and blue component cables - the colours will be wrong, but at least you can test if the Cb channel on your jungle IC is working properly. If it isn't then your jungle might have a dead channel. This happened to me with my TCL TV mod - I replaced the jungle! Also prompted me to start including 12v zener diodes for input protection.
Razmann4k
« Reply #25 on: July 22, 2025, 03:27:09 pm »
Actually I did exactly that, the screen was pink with only Y and Pr working, when I plugged Pb into Pr of the DVD player it was blue on the TV so I'm sure Pb on the Jungle is working fine! I'm quite looking forward to how this will look in games, the last time I laid eyes on a CRT was when I was around maybe 10, and that was RF/Composite at best! I'm sure a small 14 inch with Component and 240p/480i will make for a good combo! Naturally, the scanlines at 240p will be hard to spot at this screen size.
I hope my arcade joystick works on Retroarch on PS3, I guess we'll see :lol
Razmann4k
« Reply #26 on: July 29, 2025, 11:57:57 am »
So my PS2/3 TEMU component cables arrived, obviously not of great quality as they costed around $3USD. So I opened them and removed the connector and soldered it onto an unused official Xbox 360 set of component cables, which resulted in a much, much better image with almost no visible noise (I assume the tiny amount of noise I can see in dark scenes is coming from inside the TV itself. Anyway, the picture was actually too green, but after swapping the 103s with 104s that was also solved.
Now that I could finally display a png of a grid from the 240p test suite, I was able to properly calibrate the TV, adjust the V Size, V Pos and H Pos from within the factory menu (and the H Size, but that had to be adjusted with a pot on the board as it wasn't present in the factory menu). I noticed a problem however, when the image was dark the right side of the screen would shrink, so the image no longer stretched to the bezel, and bright scenes had the opposite effect.
Upon researching this I realised it was a quirk of CRTs (at least cheap ones). However, it is pretty bad, and I think adjusting the H Size to fit the entire image in the frame made it more noticable. Turning the contrast way down does help solve the problem and the geometry does improve, but I just don't want to have such a washed out image even if it means better geometry. I did a visual inspection of all the caps on the board and none of them seem to be bulging or aged, despite the TV being almost 20 years old now.
I was wondering what your opinion on this was, and whether I should bother trying to improve it?
Zebidee
  • Trade Count: (+9)
« Reply #27 on: July 29, 2025, 07:32:37 pm »
This picture brightness and size variation is called "blooming", and it is a symptom of poor quality or failing power supply regulation. All CRTs have it to some degree, but mostly you don't notice it until it gets bad.
You can check all the capacitors. Some electrolytic caps blow up or leak dramatically, spraying or spewing junk, some just quietly fail without any obvious outward signs.
Buy and use an ESR meter to check on electrolytic cap health, especially around the power supply and the horizontal output stages (near flyback, HOT, yoke pins). While you are there, also visually inspect other components including the high-voltage "disc" caps for any signs damage. Carefully inspect the PCB board itself for any signs of damage or corrosion.
You could try bumping that 1uF cap on Y down to a 104 (0.1uF), though I don't expect this to do much about blooming.
Do you just accept the blooming and move on? That depends on you. Here is a story:
I once tried to reduce bad blooming, on a "brand-new" cloned Wei-Ya RGB chassis (from China). After replacing all the caps, and some other things, saw no improvement no-matter-what I did. Even cheap TVs had less blooming. I decided I was wasting my efforts on "polishing a turd", so instead chose to component-mod TVs and invent GreenAntz RGB-component transcoders! The final quality was much better and here we are.
Take from that what you will. I'd expect better from even a cheap TV. Buy an ESR meter. Check the power supply.
Razmann4k
« Reply #28 on: July 30, 2025, 07:51:05 am »
Thanks, will do! And I'm glad you got into component modding TVs because without this guide I wouldn't have one myself!
