Author Topic: GroovyMame always shows up on the wrong monitor  (Read 4665 times)
robsmashed
  • Last login:August 17, 2021, 10:24:54 am
« on: July 26, 2021, 04:02:17 pm »
Hello, I got a laptop and a 15khz monitor hooked up to VGA out (DP1), what's the way to set my VGA out as the default monitor for groovymame? I can make it work only by disabling my laptop screen and leave the VGA out as the only option.
I'm using Linux + switchres via xandr
feltz
  • Last login:September 25, 2023, 10:57:59 pm
Re: GroovyMame always shows up on the wrong monitor
« Reply #1 on: July 26, 2021, 09:36:41 pm »
You can specify the screen either via command line, or in the mame.ini
Example, i have this line in my mame.ini to force output to my second monitor:
screen                    \\.\DISPLAY2
robsmashed
« Reply #2 on: July 27, 2021, 03:24:40 am »
"\\.\DISPLAY#" format doesn't work on GNU/Linux.
Substring
  • Last login:November 23, 2025, 01:16:00 pm
  • Forking GroovyArcade
    • forum.arcadecontrols.com/index.php/topic,160023.0.html
    • GroovyArcade active fork
« Reply #3 on: July 27, 2021, 08:15:23 am »
Which version of mame ?
Calamity
  • Moderator
  • Last login:Today at 12:20:57 pm
  • Quote me with care
« Reply #4 on: July 27, 2021, 12:53:33 pm »
On Xorg, use:
screen screen0
or
screen screen1
etc.
Steps to create a log:
robsmashed
« Reply #5 on: July 27, 2021, 05:15:41 pm »
This worked, thank you!
Deathblow81
  • Last login:April 24, 2024, 01:16:39 pm
« Reply #6 on: September 05, 2023, 04:47:57 pm »
I have this issue... and open zorg says zorg in the background on X???
