Author Topic: Megatouch Aurora Scratched Touch Screen  (Read 8810 times)
arcadezz
  • Last login:January 27, 2023, 03:59:27 pm
« on: July 12, 2021, 04:48:31 pm »
I have a couple scratches on my Aurora touchscreen that are effecting the touch screen and gameplay. Other than replacing the touch screen, anyone had any luck with other solutions that worked?
Thanks for any info.
lilshawn
  • Moderator
  • Last login:December 04, 2025, 08:10:20 pm
Re: Megatouch Aurora Scratched Touch Screen
« Reply #1 on: July 17, 2021, 04:29:56 pm »
nope. exact replacement only.
how scratched is it? i've seen some really deeply gouged overlays that pickup just fine.
i'd make sure your outlet is properly grounded and the touch screen overlay isn't touching the inside of the case. (the case has conductive coating to reduce EMI)
arcadezz
« Reply #2 on: August 12, 2021, 09:19:49 am »
Its maybe a mm or 2 deep....I can get my nail into the scratch pretty easily. I have a glass 3M touch panel thats the same length and width, any idea how thick the touch overylay is on these? Wondering if I could swap it out.
lilshawn
  • Moderator
« Reply #3 on: August 13, 2021, 03:02:15 pm »
3/16? somewhere thereabouts. touch panels are made pretty consistent.  the only issue with swapping it out is you have to swap it for the same part because you have to retain the same controller. sure, you could plop a ELO overlay and controller in there, but the software is programmed to have the exact controller that's in it...in it. you can't just slap another controller in there cause the game won't know what to do with it. (and would throw up an error saying the touchscreen is not found as it boots)
arcadezz
« Reply #4 on: August 18, 2021, 09:22:06 am »
I have used this touchscreen in force models with no issues.....any idea if the force touch overlay works in an Aurora? (I know the size is wrong, just curious if it functions)
Megatouchmike
  • Last login:September 19, 2025, 01:43:48 pm
« Reply #5 on: August 18, 2021, 05:53:17 pm »
Force TS will work in Aurora but I'd hate to see that monstrosity
arcadezz
« Reply #6 on: August 19, 2021, 08:17:35 am »
Thanks, no intention to.....but the 3m glass one I have should work too then, its just a matter of taking the Aurora all apart and the 3m glass TS width fitting in the Aurora case.
lilshawn
  • Moderator
« Reply #7 on: August 19, 2021, 04:01:51 pm »
yeah, as long as you can retain the controller... any overlay that will plug into it will work.
arcadezz
« Reply #8 on: August 24, 2021, 01:34:50 pm »
Any idea what kind of screws are at the back of the monitor to unlatch it.....mine are rusted pretty bad....are they torx?
lilshawn
  • Moderator
« Reply #9 on: August 24, 2021, 10:59:49 pm »
hex head (allen)
