Author Topic: SOLUTION: Use one PC to start games on two or more PC's (for twin cabs etc)  (Read 13202 times)
Pstylz
  • Last login:February 20, 2026, 12:53:08 am
  • 4Player Arcade Racer - WIP
Hi everyone,
I thought I would share my solution to use one PC to start a game on two (or more) PC's simultaneously - the use case for this is where one master cabinet "PLAYER 1" selects the game and starts that game on 2 PC's (in my case - my twin racing cabs).
   • Eliminates the need to use a frontend on each cab
   • Eliminates the need for the same game to be manually started on each cab at the same time
   • Stops the initial "network sync" errors with some games if they are not both started at the same time
   • Eliminates confusion for players
I am using the following to achieve this:
   • LaunchBox (BigBox)
   • AHK - AutoHotKey
   • EXE Slideshow - this was used to make an animated "<<< Select Game on P1" screen for the PLAYER 2 cab
How it works:
   • There is an AHK script that runs in the background on the PLAYER 2 cab looking for a "game" script in the folder C:\AHK to run. When no game is selected from PLAYER 1 the script keeps looping.
   • While PLAYER 2 cab is waiting for a game selection from PLAYER 1 cab, an animated EXE slideshow is running on PLAYER 2 cab
   • When PLAYER 1 selects a game, a "game" script is copied to folder C:\AHK on the PLAYER 2 cab
   • The looping script on PLAYER 2 cab finds that a "game" script is in folder C:\AHK.  It starts the game on PLAYER 2 cab, deletes the script from C:\AHK so the looping script can continue looking for game changes from PLAYER 1 cab
An extra:
   • When the ESCAPE key/exit button is pressed on the PLAYER 1 cab it will send a script to the PLAYER 2 cab to exit the current playing game and open the EXE Slideshow on the PLAYER 2 cab and wait for a game selection from the PLAYER 1 cab
AN EXAMPLE: DAYTONA USA SELECTED ON PLAYER 1 CAB
Code: [Select]
#SingleInstance force
;---- COPY DAYTONA USA GAME.AHK TO PLAYER 2 CAB ----;
;---- NOTE= Y:\AHK IS THE NETWORKED DRIVE ON PLAYER 2 CAB (C:\AHK) ----;
FileCopy, C:\AHK\FilesToCopyToP2\Daytona USA\GAME.ahk, Y:\AHK
;---- START DAYTONA USA ON PLAYER 1 CAB ----;
Run, C:\AHK\Links\2P\Daytona USA.lnk, , Max
;---- WHEN ESC IS PRESSED ON PLAYER 1, CLOSE ALL GAMES ON PLAYER 1 AND SEND A CLOSE ALL GAMES SCRIPT TO PLAYER 2 ----;
ESC::
FileCopy, C:\AHK\Escape\GAME.ahk, Y:\AHK
Send !F4::
Process, Close, TeknoParrotUi.exe
Process, Close, sdaemon.exe
Process, Close, supermodel.exe
Process, Close, Daytona.exe
Process, Close, emulator_multicpu.EXE
Process, Close, parrotloader.exe
Process, Close, OpenParrotLoader64.exe
Process, Close, ParrotLoader64.exe
Process, Close, BudgieLoader.exe
Process, Close, Wmn5r.exe
Process, Close, Rally.exe
Process, Close, MK_AGP3_FINAL.exe
ExitAPP
return
PLAYER 2 - LOOKING FOR GAME LOOP SCRIPT:
Code: [Select]
;---- LOOK FOR GAME SCRIPT TO EXECUTE GAME ----;
IfExist, C:\AHK\GAME.ahk
Run GAME.ahk
Loop
Sleep, 2000
Reload
AN EXAMPLE: DAYTONA USA GAME SCRIPT THAT IS SENT TO PLAYER 2 CAB WHEN A GAME IS SELECTED ON PLAYER 1
Code: [Select]
;---- CLOSE ALL POTENTIAL RUNNING GAMES ----;
;---- START DAYTONA USA ON PLAYER 2 CAB----;
;---- DELETE GAME SCRIPT FROM LOOP SEARCH FOLDER ----;
FileDelete, C:\AHK\GAME.ahk
;---- IF ESC IS DETECTED CLOSE ALL POTENTIAL RUNNING GAMES ----;
ESC::
;---- CHECK IF EXE SLIDESHOW IS RUNNING ----;
Process, Exist, Player 2 - Waiting Screen 0.4.exe
If Not ErrorLevel ; errorlevel will = 0 if process doesn't exist
Run, C:\AHK\Player 2 - Waiting Screen 0.4.exe, , Max
ExitAPP
return
This is a pretty easy way to sync the execution of a game on multiple PC's - there's probably better ways, but hope this helps.
One draw back, is that you need to create a few scripts for every game you want to run on your cabs, this includes when you add new games.
Because this process is only required for my racing cabs and it only has a select few games, its easy to manage and isn't an issue for me.
If anyone would like further explanation please let me know.
nugarp
  • Last login:March 17, 2026, 01:07:01 am
Never did I ever imagine AHK would be used to replace socket functionality. Neat trick you have there - thanks for sharing.
If you code at all or are curious, take a look at nodejs and the socket.io library. You won't need to keep polling. It's super user friendly.
Sent from my SM-G950U using Tapatalk
Empo
  • Last login:October 05, 2022, 05:47:50 pm
  • I want to build my own arcade flux capacitors!!
Sorry for dragging up an old thread. But this is a question i have been wondering about as i want this function in my setup. Very nice use of AHK to obtain this function i must say.
But in my digging regarding this i found the PsExec: https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
PsExec i think would be a better solution, anyone tried this ? (i already start my games in the twin driver setup using bat. files)
Pstylz
Thanks for the feedback.  :cheers:
Thank you for the suggestion but unfortunately I'm not skilled enough to code (very well) - I'm just a good "tinker-er" haha.
And fortunately the polling on P2 machine barely has any impact on system resources.
Pstylz
No worries.  Hoped this helped or gave you further inspiration for other solutions.  :cheers:
I did attempt to use PsExec many moons ago, but found I had issues with it.... cant remember what now, but i think P2's controls failed to register when games were initiated with PSExec
Pstylz
I've been working on a "cleaner" way to get BIGBOX/LAUNCHBOX to start up the selected game in preparation for my new project - 4 Player Arcade Racers cabinet(s)    8) >:D
In the OP above, you would need to duplicate and modify the same script for every game and compile.
I have now made a single "GameStart" script/executable that reads the "rom" title sent from BIGBOX to identify the game to start.
The GameStart script then creates an AHK file with the appropriate game title and saves it on the PLAYER 2 machine where the GAME LOOP SCRIPT running on PLAYER 2 will execute.
All that is required now is a ".lnk" of the game to be added into the "\\Arcade\AHK\Links\" folder on both player machines.
NOTE:  The game ".lnk" filename must match what is in BIGBOX   ;)
GAMESTART.EXE
Code: [Select]
;---- EXTRACT COMMAND LINE ATTRIBUTES (GAME TITLE) FROM BIGBOX (LAUNCHBOX) ----;
GAME = %1% %2% %3% %4% %5%
;---- START LOCAL GAME (P1) ----;
Run, C:\Arcade\AHK\Links\%Game%.lnk, , Max
;---- DELETE EXISTING GAME.AHK FROM PLAYER 2 ----;
;---- NOTE -- THIS ENSURES THE "GAME START LOOP" FOLDER IS CLEAR ----;
FileDelete, C:\Arcade\AHK\Player2\Game Start Loop\GAME.ahk
;---- CREATE PLAYER 2 START GAME FILE AND THEN SEND TO PLAYER 2 ----;
;---- NOTE: "Y:\" DRIVE IS THE NETWORK DRIVE ON PLAYER 1 CAB OF PLAYER 2 CAB'S "C:\" DRIVE ----;
fileAppend,
;---- CLOSE ANY RUNNING GAMES ON P2 BEFORE STARTING NEW GAME ----;
Process, Close, OpenParrotLoader.exe
Process, Close, racing.exe
;---- START GAME ON PLAYER 2 ----;
Run, C:\Arcade\AHK\Links\%GAME%.lnk, , Max
;---- DELETE GAME SCRIPT FROM GAME START LOOP SEARCH FOLDER ONCE GAME HAS STARTED ----;
;---- IF ESC IS PRESSED, CLOSE ALL RUNNING GAMES ON P2 ----;
;---- RUN "WAITING SCREEN" AFTER ALL GAMES CLOSED ON P2 ----;
ESC::
;---- CHECK IF EXE "WAITING SCREEN" IS RUNNING ----;
Run, C:\Arcade\AHK\Player2\Player 2 - Waiting Screen 0.4.exe, , Max
ExitAPP
return
), Y:\Arcade\AHK\Player2\Game Start Loop\GAME.ahk
;---- START BIGBOX.EXE ON PLAYER 1 IF DOESNT EXIST ----;
ESC::
FileCopy, C:\Arcade\AHK\Escape\GAME.ahk, Y:\Arcade\AHK\Player2\Game Start Loop\
Send !F4::
Process, Exist, bigbox.exe
Run, "C:\Arcade\LaunchBox\BigBox.exe", , Max
ExitAPP
return
return
Code: [Select]
Run GAME.ahk
Loop
Sleep, 2000
Reload
Fursphere
  • Last login:March 18, 2026, 05:56:24 pm
If you have a frontend running on Cab #2 (BigBox) will the "looking for game" script launch the game in the foreground still?
I sort of got PSExec running doing this, but if the front end was running on cab #2, it would launch in the background, and you'd have to alt-tab to it.   That seems to be the trickiest part of this whole thing, was getting the game running on the second cabinet without losing windows 'focus'.
I thought about approaching the launchbox/bigbox developers to make this sort of thing integrated, but I decided its such a niche case, it wouldn't be worth their time.  I mean, how many people have multiple emulation cabinets, and then out of that list, how many attempt to 'link' them.  :)
I built my current two two-player cabinets with this specifically in mind, the ability to play 4 player games.   For a brief moment, I considered a 3rd for those rare six player games, but I was already pushing my limits with two full side arcade cabinets, a virtual pinball cabinet and my wife's patience.   ;D
Fursphere
Can you give an example of the LNK file you reference here?  Its contents?
Are you putting the specific game startup command in this file?
For example:
Host Machine:
retroarch.exe -L cores/fbneo_libretro.dll -H romname    ??
Client Machine
retroarch.exe -L cores/fbneo_libretro.dll -C hostname romname   ??
Pstylz
Hmmmm good question.
You could make the AHK script close BigBox on both machines when a game starts and when "ESCAPE" is pressed to exit a game it can restart BigBox on both machines.
If you wanted to run BIGBOX on both machines you could:
- run the "Looking for game" AHK script on both machines
- modify the GAMESTART script to work on Player 2 machine (changing some directory and drive references)
- modify the ESCAPE script to start BIGBOX on when exiting games for both machines
I'm happy to offer some assistance
Pstylz
I've just started my 4P arcade racing cabinet for exactly that reason! 4 Player madness!!!!
I hear you regarding the wife's patience part haha
Pstylz
For example:
Host Machine:
Client Machine
The LNK file is just a windows shortcut to start the game.
In my case, BIGBOX isn't set up with emulators. It just pushes the GAME TITLE to my GameStart script to execute.
Considering I only have a limited number of racing games for these machines, it's a manageable process.
Fursphere
So I got this all working with BigBox.
On the "Primary" cabinet, I setup a new Platform for FinalBurn Neo.   Then Setup a BATCH file (I'm an old school DOS guy...) to start RetroArch with all the required parameters and %game% argument passed from the command line.
The Batch file does two things:
-Dynamically create a batch file on the Secondary cabinet with the required parameters to launch Retroarch in CLIENT mode, then delete itself.
-Launch RetroArch in HOST mode.
I used the basic AHK script you came up with to look for the game.bat file being created in the folder on the secondary machine, and launch it.
This works perfectly.   Primary and Secondary both launch the game, and on the secondary it just launches right on top of BigBox, and BigBox goes dormant.
I made the secondary FBNeo platform for two reasons:
-It has a unique romset from mame
-MAME is still a separate platform and launches games locally in 2 player mode.   FBNeo is setup strickly for 3+ player games.
The 'emulator' is just an FBNeo.bat file.    This exact concept could be used for other platforms w/ RetroArch (and various cores) to do netplay the same way.
this is the batchfile if your curious.   I may re-write the thing using AHK, but this was just really quick.
del \\cab-b\d\ahk\game.bat
echo d: >> \\cab-b\d\ahk\game.bat
echo cd\ >> \\cab-b\d\ahk\game.bat
echo cd emulators >> \\cab-b\d\ahk\game.bat
echo cd retroarch >> \\cab-b\d\ahk\game.bat
echo start d:\emulators\retroarch\retroarch.exe -L cores/fbneo_libretro.dll -C cab-a %1 >> \\cab-b\d\ahk\game.bat
echo del d:\ahk\game.bat >> \\cab-b\d\ahk\game.bat
d:
cd\
cd emulators
cd retroarch
start retroarch.exe -L cores/fbneo_libretro.dll -H %1
vrmax81
  • Last login:October 26, 2025, 08:50:49 pm
Re: SOLUTION: Use one PC to start games on two or more PC's (for twin cabs etc)
« Reply #12 on: December 17, 2022, 06:04:31 am »
I am currently building a 2 player 2 cab linking racing multicade. Before reading this thread I had no idea this was attempted before. I was able to accomplish this using psexec. I have notes and a small guide going as I am still working on this project. I have linked arcade and console emulators together using bat and vbscripts. Some emulators like project64 and dolphin I had to send keystrokes as command lines are not an option. I do have scripts setup to launch before the game incase another emulator is being used or the same emulator and wont cause a conflict of two emulators going at the same time.
Fursphere
Sorry for the nerco bump, but in case anyone digs up this old thread - there is a front end way to do this now with Launchbox and a Plugin.
https://forums.launchbox-app.com/files/file/4587-cli-launcher-launchbox-command-line-interface-for-launching-games-directly-from-stream-deck/
The plugin is billed as a Stream Deck integration, but its also got a handy CLI utility that can be used for remote launching of games on a remote LB platform.  Great for netplay / linked gaming.
