Author Topic: Wiring Harness  (Read 11165 times)
  • Last login:Today at 01:19:27 am
Re: Wiring Harness
« Reply #40 on: September 29, 2020, 11:33:22 pm »
brought it to a reputable guy
Who told you he was a reputable guy?   >:D
never tested the the two signal outputs.
In that case, he may have checked some components but he did not test the board.
Connecting 5v and ground to the board then observing that it isn't smoking is not testing the board.   :bat
The most basic function check to determine if the board is working should include these four steps:
1. Connect 5v and ground from a power supply/wall-wart/hacked USB cable to the card.
- Bring your edge connector so it's easier for him to connect to and test the whole board.
2. Set the multimeter to DCV.  Connect the black lead to ground and the red lead to one of the outputs.
3. The meter should alternate between logic high and low as you block then unblock the gap between the LED and photodiode with a thin piece of cardboard/cardstock.
4. Repeat steps 2 and 3 with the other output.
If you don't see the output changing between logic high and low in step 3, then it's time to troubleshoot what is wrong with the circuit.
I looked closer at the board and saw this...
The two through-holes with no solder are not a problem.
Look at the other side of the board, there is no component connected to either of them.
The trace runs around the eyelet hole so you don't need a lead soldered into the hole for continuity.
- The holes do make handy spots to hold the sharp tip of a meter lead steady.   ;D
Some of the conformal coating (green stuff that protects against corrosion) has been damaged/flaked off, but it doesn't look like the underlying traces have been broken.
spisi
  • Last login:February 26, 2026, 05:36:58 pm
Re: Wiring Harness
« Reply #41 on: September 30, 2020, 08:39:34 am »
He charged me $15 to test it. I don't know how much he'll charge, prob another $15 I'd guess.
spisi
Re: Wiring Harness
« Reply #42 on: October 01, 2020, 09:01:42 am »
So, I'm giving up!  I fixed the two solder joints, tested for continuity for everything on the board and it checked out good.  Then I connected my connector and re-checked for continuity from the end of all wires through the connector to the board.  That checked out good.  Still does not work!  :banghead:  I'm guessing it's something with either receiving the signal or sending the signal.  Either way I am done!
spisi
Re: Wiring Harness
« Reply #43 on: October 01, 2020, 09:13:51 am »
Scott, I don't know how, but I missed reading your last post!  I will give that testing a try later today!  Last ditch effort!  8)
spisi
Re: Wiring Harness
« Reply #44 on: October 01, 2020, 10:18:25 am »
Wait a sec, that test is not going to work because ...it's not working...
spisi
Re: Wiring Harness
« Reply #45 on: October 01, 2020, 03:49:31 pm »
Same reading blocked or unblocked.....I don't think the LEDs are lighting up.  But when I was in the shop I saw the guy get them to light.....
spisi
Re: Wiring Harness
« Reply #46 on: October 07, 2020, 12:01:33 pm »
OK.  I gave up.  Lost that battle!  :(   Bought a whole machine that had a working wheel and pulled it...
spisi
Re: Wiring Harness
« Reply #47 on: October 12, 2020, 03:42:52 pm »
Got it all working now  :D  Now I just got to make her look pretty!
