Author Topic: MAME 2020 vs 2002  (Read 16887 times)
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
MAME 2020 vs 2002
« on: September 05, 2020, 12:25:59 am »
I joined this forum in 2002 and built a cab a long time ago that was based on MAME .79 at the time.
The cab was scratch built following design by LuSiD's Arcade Flashback, Windows XP, MAME .79 and is still in operation today at my youngest son's place.
Fast forward and its suddenly 2020....
I have a nephew interested in taking my help in a build project, probably a pedestal. This would be PC based system likely driving a LCD on the wall.
I am also intrigued by what has been done with the Raspberry PI and may dabble in a bar top unit or portable 2 player control panel.
My question is, what are the best resources to review in order to understand the games that are emulated and playable today using latest MAME as compared to what I originally built 18 years ago? The suggested hardware in terms of CPU etc given the emulation requirements for more recent games, etc.
Add to that, what is actually feasible to run on Raspberry PI.  I assume there is a specific MAME port for this hardware. (Also reading what I can in the PI forum).
I have been out of the arcade for a long time so I am more of a "classics" man from the 80s but nephew may have interest in much more recent games given his generation.
Thanks in advance for suggestions on how this old man can get back up to speed on the software side of things as well as educate myself on the hardware components mentioned above.
Haze
    • MAME Development Blog
Re: MAME 2020 vs 2002
« Reply #1 on: September 05, 2020, 04:13:36 am »
If you use a Pi you're basically still stuck in 2002, as that's where the support scene is for them as most of the earlier ones can't run anything newer at any playable speed.
In terms of proper MAME, there have been an astronomical number of improvements to the emulation of everything from the late 70s games to the early 2000s stuff; just the other week late 70s / early 80s games that have never had sound emulation finally got it, and a large amount of protection devices have been dumped for 80s/90s Taito games in that time, meaning they actually play properly now.  Bugs like the ones that exposed BMs Donkey Kong high score tapes as being emulation based have been fixed too.  Even the like of the QSound emulation used by a lot of high profile Capcom games is leagues ahead of what it was just 2 or so years ago.
I'd say the project has seen a real improvement in the technical ability of those involved since around 2015, and a lot of what was considered impossible at that point has now been done.  The differences might not be obvious at first, but our confidence in things is much higher, and the longer you spend with the things the more you notice how much closer everything is to hardware these days.
You may, or may not agree with MAME doing a lot more than arcades these days (and I'll be the first to say a lot of what I've worked on recently is absolute garbage) but that's where a lot of the new talent has come from; people with backgrounds in technical computing seem to make far better devs than those with backgrounds only in arcades so by branching out and appealing to both groups MAME has benefited greatly.  It should be noted that many of these improvements do have a performance cost, the aforementioned sound emulation for the late 70s / early 80s games requires a good machine, but gives a quality the old samples (where they even existed) can't match.
« Last Edit: September 05, 2020, 04:19:26 am by Haze »
Kingcade
  • Last login:January 17, 2025, 10:50:45 pm
  • Building a steampunk arcade cabinet
« Reply #2 on: September 06, 2020, 10:27:29 pm »
Haze, do you foresee a point where the Pi and MAME might converge again? While it seems unlikely that the Pi will ever be able to keep up with emulating the more modern systems, it would be great if it could benefit from updates to emulation to older systems.
KINGCADE - my Steampunk Wild West penny arcade-style cabinet
http://forum.arcadecontrols.com/index.php/topic,161105.msg1697383.html#msg1697383
Haze
« Reply #3 on: September 07, 2020, 04:06:02 pm »
You can run a lot of things in current MAME on a Pi 4.
The problem is mostly RetroArch / LibRetro's making.  They offer various old MAME builds that everybody has stuck to, rather than people still doing native ports, or hand picked-ones closer to what each specific piece of hardware can run.
Aside from 'current' (which nobody using RA seems to bother with as it's an always changing version) the newest 'named' version anybody uses is from over 10 years ago, and a butchered one at that.
As a result, rather than using something suitable, or a mix of suitable builds, people end up using 2002/2003 builds 'because everybody else is'  It's a sad state of affairs really, and a major regression from times before RA existed, when people were starting to do native ports of the most suitable versions for each platform.  RA presented an 'easy option' and the masses took it rather than trying to do things properly anymore.
Even on a PC RA really messes up some MAME features, and inexplicably kills performance in certain drivers.
MAME can't fix what is basically a problem that's now part of the culture / scene surrounding those things.
In terms of MAME's requirements we will continue to move forward, within the envelope of what current PC hardware allows.  Some other projects have been held back by about 15 years due to trying to keep within the performance envelope of those devices, but when good emulation (eg the discrete sound sims) really can't be done properly without high requirements MAME isn't going to ignore the advances in hardware that make things possible; we'd rather be giving people reasons to use MAME over something like a MiSter than looking at the trashcan end of the market, and the discrete audio stuff is an area MAME can offer something the MiSTer struggles with.
There will always be things in MAME that are actively improving that are going to be out of reach of whatever the latest Pi is, because the simple fact is a $30 machine is always going to be lagging significantly behind the curve.  As I mentioned tho, plenty does work, not every improvement shoots the CPU requirements up significantly (eg. most of the proper protection emulations are fairly lightweight) and people using old builds for games where newer ones would work better is a scene problem (always trying to accommodate the lowest common denominator) not a MAME problem.
« Last Edit: September 08, 2020, 04:19:49 am by Haze »
mameotron
  • Last login:October 13, 2024, 05:31:13 pm
  • A mamer is you...
« Reply #4 on: September 09, 2020, 02:05:09 pm »
Wow, does this mean the sound for Vanguard is finally emulated properly?  I'm a llittle more ahead of Steve, I have MAME .92 in my cab.
Haze
« Reply #5 on: September 09, 2020, 02:27:54 pm »
Vanguard hasn't seen any recent work.
Keep in mind that the complexity of this work makes emulating the games and getting them running in some form in the first place look like 1% of the work, with this being the 99%; it's many magnitudes more challenging than the initial work and not something that's going to happen for all systems with analog sound components overnight.
« Last Edit: September 09, 2020, 02:31:34 pm by Haze »
fallacy
  • Last login:October 11, 2025, 12:36:57 pm
« Reply #6 on: September 10, 2020, 01:34:43 am »
Built my cabinet in 2009 so I still have mame .130. Let me know when Marvel vs Capcom 2 can be played on mame, that will be my q to update.
  • Last login:October 18, 2025, 11:48:43 pm
« Reply #7 on: September 10, 2020, 02:59:49 am »
Yeah updating mame isn't particularly necessary in terms of just wanting to play games.  I mean it's nice to do it every once in a while when a new game gets improved emulation or whatever but don't sweat it.
Osirus23
« Reply #8 on: September 11, 2020, 12:01:40 pm »
2008, MAME 0.125 here. Still no incentive to update.
Haze
« Reply #9 on: September 12, 2020, 08:06:21 am »
There are plenty.  You're just choosing to ignore them, or don't have the hardware capable of dealing with them.
As I mentioned in an earlier thread, even just taking the audio improvement to the 70s/80s classics from the previous release is reason enough if you have the hardware capable.  The correct sound makes them feel like almost entirely different games.
You could say the same at any point in those 12 years, and we'd be able to pick a key example from the last couple of releases at the time.
If people want to do themselves out of a world of improvements because they're waiting for one specific thing, that's of course their business, but let's not pretend there aren't massive improvements across the board because that's just spreading misinformation, and that's not cool.
« Last Edit: September 12, 2020, 08:09:01 am by Haze »
Osirus23
« Reply #10 on: September 12, 2020, 09:55:40 am »
Correct. I don't give a ---steaming pile of meadow muffin---. It isn't broken so I'm not going to fix it.
  • Last login:Today at 04:45:41 am
« Reply #11 on: September 12, 2020, 10:29:18 am »
When the sound is wrong on a game it is broken. If you don't care that is fine. It bugs the crap out of me when the sound is bad. I appreciate the fact that they are still fixing those issues.
tobias
  • Last login:January 05, 2024, 09:29:34 pm
« Reply #12 on: September 12, 2020, 10:48:07 pm »
Hi y'all, I'm just getting started in this hobby. Are you saying if I want Defender to sound like Defender I need to run MAME on a PC, not a Pi?
Haze
« Reply #13 on: September 15, 2020, 08:17:41 am »
In general, although I don't think there's much to the Defender sound system for a Pi to get wrong, it's not one that makes heavy use of netlists (maybe there are some filters we don't yet emulate, I haven't checked)
If you want slowdowns closer to real hardware on the Williams games you definitely want to be running on a PC tho.  They're still not perfect, but they've been tuned a fair bit since the versions on a Pi.
Haze
« Reply #14 on: September 15, 2020, 08:23:35 am »
Indeed, I've argued for a while that 'no sound at all' or 'severely broken sound' should be considered 'not working' in MAME terms.
Sound is an important part of many games.  From audio either telegraphing events, alerting to you something that has happened, or simply just creating the overall immersive mood of a game, it needs to be correct.  It can give you a frame of reference for timing too, if I think to many games I've played the rhythm used for a series of tricky platform jumps can come from something as simple as knowing when the sound effect to a pick-up ends and synchronizing yourself to that.
A lot of arcades did have weak sounds, because the 'standard' for Arcade audio on non-dedicated cabs for a long time was mono audio out of an awful speaker, drowned out by everything else in the arcade, but that doesn't mean you can ignore it entirely and still pretend the game is fine.
« Last Edit: September 15, 2020, 07:47:10 pm by Haze »
negative1
  • Last login:Yesterday at 09:56:33 am
« Reply #15 on: September 15, 2020, 04:21:18 pm »
Sound is an important part of many games.  From audio either telegraphing events, alerting to you something that has happened, or simply just creating the overall immersive mood of a game, it needs to be correct.  It can give you a frame of reference for timing too, if I think to many games I've played the rhythm used for a series of tricky platform jumps can come from something as simple as knowing when the sound effect to a pick-up ends and synchronizing yourself for that.
A lot of arcades idid have weak sounds, because the 'standard' for Arcade audio on non-dedicated cabs for a long time was mono audio out of an awful speaker, drowned out by everything else in the arcade, but that doesn't mean you can ignore it entirely and still pretend the game is fine.
sound is important, i agree.
but to me if the game works without it i'm fine.
i turn the sound down or off, and play my own music for most games, or games i've mastered.
hearing the same sounds or music for hours on end is boring, and distracts me.
good sound is a perk, but not necessary for setting records on games.
later
-1
mahuti
« Reply #16 on: September 15, 2020, 05:55:15 pm »
If you play it and have fun, then its working FOR YOU. If your friends are like mine they couldn't tell the difference.
There is absolutely an objective standard for whether a game is fully working. But there is also a subjective standard which it must meet to be enjoyable to each person. If it meets that standard then rock on. If not, then better hardware is a must. If one is a purist in general then you'll definitely need the best hardware possible.
JRobATL
  • Last login:September 27, 2022, 10:20:34 am
  • Completed - Tron Legacy
    • forum.arcadecontrols.com/index.php/topic,162637.0.html
« Reply #17 on: September 16, 2020, 09:23:01 pm »
Steve,
Backing up to a point before some tangents were taken, you had asked about hardware performance. I believe you can get a used old i4 or i5 processor running Win10 for about as cheap as a raspberry pi. Are there size/space limitations that drew you to a ras pi?
And to your other question, for me personally it would be worth getting a more current version of Mame and a newer romset. 2002-2020 is an awful lot of change logs to have to review. ...but in terms of resources, that's where I would start.
« Reply #18 on: September 16, 2020, 09:57:55 pm »
^This^
An old pc is always cheaper per performance dollar than a pi.
Kingcade
« Reply #19 on: September 17, 2020, 01:21:11 am »
To the OP and Tobias, there are lots of people running Pi setups (including me) quite happily. The Pi does have its advantages, and it works quite well for older arcade games. Some games require samples to be used in place of hardware emulation.
Also, check out this thread where bbegin has MAME .224 running on a Raspberry Pi 4B, apparently with good performance:
http://forum.arcadecontrols.com/index.php/topic,162889.0.html
Haze, it would be good to know some examples of older games that might test the Pi due to the latest MAME audio emulation, for example. Do you have some specific games to try?
« Reply #20 on: September 17, 2020, 01:33:44 am »
I would argue that the pi has far more disadvantages than advantages.  It's difficult to customize, as Haze has pointed out you don't have the option to run more current builds of mame and it's puny horsepower means you won't be playing a lot of newer games.  Plus you can't (easily) play other stuff not in mame.  It's a really good option when space is limited but that's about it.
Osirus23
« Reply #21 on: September 17, 2020, 10:17:22 am »
I bought a refurbished Dell Optiplex with an Ivy Bridge i5 for less than the cost of an RPi4 once you buy a power supply and SD card. No reason to hobble yourself with one of those devices unless you're building a handheld or something.
Titchgamer
« Reply #22 on: September 17, 2020, 10:51:29 am »
Sound is important to me, I dont mind if the tones off slightly or something like that.
But if its stuttering or sounds totally wrong then its a turn off for me, I also dont want to play in silence!
bollwerk
  • Last login:November 20, 2023, 08:27:52 pm
« Reply #23 on: September 17, 2020, 12:10:39 pm »
If all you care about is arcade games, a PC (even an old/cheap one) is vastly superior to a Pi.
One of the main advantages of a Pi, aside from small size, is the out-of-the-box support for lots of other old gaming consoles in Retropie, et. al.
I'm sure the same is possible on a PC, but it might be more work. (although I could be wrong?)
formula409
  • Last login:January 03, 2021, 02:13:17 pm
« Reply #24 on: September 17, 2020, 09:33:10 pm »
The ability to play native Windows games on top of emulators makes the PC a no brainer.
Pis are only budget options if you absolutely can't afford a real setup, and honestly, if money's that tight, you'd got bigger problems than playing video games.
SteveJ34
  • Trade Count: (+9)
« Reply #25 on: September 20, 2020, 02:12:09 am »
Steve,
Makes sense. The PI option was just to get the feedback on capability of that platform as compared to just using a PC based system which I am already familiar with.
I am also giving consideration and researching (searching) for wireless controller options, ie: having a basic arcade stick controller connected wireless to a base unit across the room.
Probably best to start a new thread for that one.
Vocalitus
  • Last login:October 25, 2021, 06:16:58 pm
« Reply #26 on: September 21, 2020, 12:08:05 pm »
Raspberry Pi is a great way to game on the cheap.  It is a more plug and play affair, especially with 50 somethings and kids to get into classic gaming.  So Final Burn (.74) is good enough for that and the classic consoles.
It is also true that a refurbished i3 or i5 for $50 will work wonders too, but unless you are going for a linux based distro like recall box then you have your work cut out for you that that is the rub.  It doesn't matter really (unless you are a purist) what version of MAME you are using if you want to have 30 minute sessions on a piece of nostalgia.  It takes forever to set up a new PC and we are not talking CoinOPS.
Yes the newer versions of MAME has some more bells and whistles but the mamedevs over the years have a poor record of fixing old issues than creating new ones, and that is probably due to experience and available talent.  It is a massive project which is mind boggling to just comprehend.
Nice to know that Starfire has audio now.  Thanks to Haze for all his valued help over the years, whom has done a lot of the heavy lifting, we now can enjoy all our old classics without going broke buying Arcade 1up cabinets.  Even that mod is far easier with a Pi and without all those gambling and mahjong roms taking up space.   ;D
« Reply #27 on: September 22, 2020, 02:58:16 am »
I don't necessarily agree with that.  Mame is not turn key nor should it be.... you have to put in the work.  If you use one of those pre-baked distributions it's either going to have too many games, too few games or the wrong games for your liking because we are all different and thus we should all make our own personal game lists and not rely on others for that.  That being said most people are more familiar with a windows environment than linux and thus a pc is easier and quicker to setup.  Also we just have more developers making stuff for windows, particularly middleware like front-ends and launchers.  That means you have more options and options are good.    There are reasons to use a pi but it's more for when you need something small or you have specific hardware needs.
Titchgamer
« Reply #28 on: September 22, 2020, 04:33:12 am »
Totally agree with this ^ 100%.
I have said it before snd I will say it again....
Dont use pre made images!
Hyperspin HDDs, Pi images etc none of them will do what you want and its harder to fix a setup you never made than to sort out a problem on one you did.
I never use pre made images, I build from the ground up so I know everything is how I want it and where to look in the event of problems.
jennifer
« Reply #29 on: September 22, 2020, 06:49:24 am »
Why stop at 2002, why not 1985 when they said it diddnt start, yet another big lie, It is still overly complex with all the buttons, and half baked control, D/Kong still sounds like you are playing with pudding in your ears, the only thing Mame has ever been good for is saving me from burning a few cabs so a few cheapskates can just cut them themselves...Want to get over feeling cheated out of a lifelong promise?, Go buy a real machine, spend a few bucks, you will sleep better at night.
Titchgamer
« Reply #30 on: September 22, 2020, 07:01:07 am »
I wouldn’t agree with that.
MAME has helped to save several real cabs and kept them OG to.
My Area 51 cab for instance had a failing HDD but thanks to MAME I had access to a CHD file to make a new one.
jennifer
« Reply #31 on: September 22, 2020, 07:06:14 am »
Well perhaps Roms dumps (And CHDs) could be considered, It should be noted however on older games, The pokey chip, as far as emulation goes would have had to be one of the biggest hurdles for a Dev to overcome, and wasn't ever truly hacked until very recently...Just saying.
Vocalitus
« Reply #32 on: September 22, 2020, 12:17:28 pm »
I totally respect your opinion on the matter.  You are an arcade collector/expert and and any seasoned arcade hobbyist would take the time to install the emulators correctly.
Unfortunately you guys are few and far between.  Pi images have become a mainstay in the "need to get it working quick" community, and yes, the images have a lot to be desired.
The Pi images are not completely avoidable, and provide an insight on how game emulators work and their respective art on a particular platform.  On their own, the Pi images are little vessels of history and have an importance for their respective format.
The included games in these images, however, is another topic in its own right.    ;)
« Reply #33 on: September 22, 2020, 12:44:05 pm »
I have a lot to say about this, but people already think I am a big meany pants.
Titchgamer
« Reply #34 on: September 22, 2020, 12:47:40 pm »
DO IITTTTT!!!!!
jennifer
« Reply #35 on: September 22, 2020, 12:49:35 pm »
I know right?...I even heard you can't weld either.😈
« Reply #36 on: September 22, 2020, 12:50:53 pm »
How about pics of some of those 10,000 MAME cabs you built. I am still waiting.
jennifer
« Reply #37 on: September 22, 2020, 12:58:45 pm »
I dont build Mame, bite you tongue...Mame still sucks, I build real machines like they should have been built...That cab you are referring to is to be my last build ever...I am seriously  thinking to make a build thread on it however, but if I do, it would go from composite to milled ply, and laminate in the interest of time and financing. (Rather than drag it out forever)
jennifer
« Reply #38 on: September 22, 2020, 01:01:49 pm »
In fact Jenn was just sitting here looking at bits...
« Reply #39 on: September 22, 2020, 01:03:26 pm »
How about a pic of any of the 10,000 dollar machines you have finished?
