Author Topic: crt emudriver 2.0 groovymame 0.194 win 10 x64  (Read 3694 times)
mitsurugi
  • Last login:November 07, 2025, 04:57:10 am
« on: April 06, 2020, 12:44:28 am »
Hi.
I have installed crt emudriver 2.0 on win 10 x64 and no problem with 15 khz and most emulatores but... groovymame 0194 flick image (not showing ant 15khz) Are compatible or must install last version?
Another problem is supermodel 3 emulator not showing in 15khz (same as groovymame flickering image)...
Thanks!!
mitsurugi
Re: crt emudriver 2.0 groovymame 0.194 win 10 x64
« Reply #1 on: April 10, 2020, 01:46:42 pm »
With a fresh 0.219 Groovymame version it works fine! All emus works fine in win10 x64 except supermodel.
Supermodel testing different resolutions and disable ati service runs at half speed... I will keep tryiing solve the problem >:D
psakhis
  • Last login:September 24, 2024, 11:54:25 am
« Reply #2 on: April 11, 2020, 07:41:45 am »
Hi, for supermodel you need to config alternative resolution. The emulator takes 640x480@30hz modeline by default.
For example, i have 704x480. This is my command argument: supermodel_729.exe %1.zip -res=704,480 -fullscreen -stretch
Note: I only have 704@480@60hz installed as well.
« Last Edit: April 11, 2020, 07:43:32 am by psakhis »
haynor666
  • Last login:November 21, 2025, 05:45:00 pm
  • retro maniac
« Reply #3 on: August 22, 2023, 09:06:39 am »
The same problem here - if I force supermodel to work with interlaced resolution then it works at half speed :/
Looks like my hardware after all does not have enough power simply :/
« Last Edit: August 22, 2023, 12:17:53 pm by haynor666 »
Milsancho
  • Last login:November 20, 2024, 06:09:37 am
« Reply #4 on: August 22, 2023, 05:15:01 pm »
So which hardware are you using currently? Supermodel was one of the things I wanted to use on the setup I'm building.
haynor666
  • retro maniac
« Reply #5 on: August 27, 2023, 11:21:12 am »
It's Radeon HD5670 with G3258 4,3 GHz. But I'm not so sure if this is caused by too weak hardware or other problems.
Milsancho
« Reply #6 on: August 28, 2023, 05:46:07 pm »
Yeah, seems that unless you change it and lose accuracy, Supermodel uses Opengl shaders, and a 5670 could be a bit too old for those. Keep us informed, please.
