Author Topic: Megatouch force software wanted please  (Read 7679 times)
billfield
  • Last login:December 22, 2019, 06:33:59 am
« on: October 16, 2019, 02:17:25 pm »
Does anyone have a megatouch force hard drive with 2006 or new software on it please ? I will prob need the key as well.My hard drive died and its scrap so need new software ready to plug and play  Many thanks Ime in uk
lilshawn
  • Moderator
  • Last login:Yesterday at 11:01:31 pm
Re: Megatouch force software wanted please
« Reply #1 on: October 16, 2019, 02:57:52 pm »
what version key does your machine have now? (key part number... should be SA####)
if it is 2005 you can swap the drive for any drive and reload the software in it. merit removed the merit branded drive requirement (drives with custom 'merit' firmware) in 2005.5 update.
any version above at as well can use any drive. (06 07 08 09 10 11)
billfield
« Reply #2 on: October 17, 2019, 11:54:45 am »
My key is sa3502-05. How do i get the software and is it difficult to load as not that great with computer stuff?
lilshawn
  • Moderator
« Reply #3 on: October 18, 2019, 12:27:57 am »
must have been 2006... tech notes say...
FORCE 2006
Version: V20.00 – V20.27
Security Key: SA3501-XX // SA3504-XX (i assume keys between 3501 and 3504)
I can probably get you a 2006 re-installation disk image. you'd just use your computer burn the image to a blank cd disk...and then boot your machine with a cd rom attached to the motherboard and the software does the rest. once it's done disconnect everything and reboot.
if you want to take a stab at reinstalling it on a new drive that is.
as for when... i'm not 100% sure... all my stuff is currently packed becasue i'm in a very slow process of moving. i might have a spare at work i can upload an img of this weekend if that's good enough for you.
billfield
« Reply #4 on: October 18, 2019, 10:32:54 am »
That would be great ta .Unless you can load it on a hard drive for me and i will pay you of coarse ??
Megatouchmike
  • Last login:September 19, 2025, 01:43:48 pm
« Reply #5 on: October 18, 2019, 01:54:29 pm »
I've got an extra 2007 drive and key sitting around. If interested PM me
