Author Topic: Gun.Smoke with 2 buttons?  (Read 4996 times)
Haloman800
  • Last login:February 07, 2020, 12:40:00 am
  • Awfully Awesome
« on: September 03, 2019, 01:21:28 am »
I'm building a barrel arcade based on this one https://retroarcadebarrels.com/
It wasn't until after I made the control panels & drilled the holes that I remember Gun.Smoke uses 3 buttons. Is it possible to play with only 2, or am I SOL?
Here's my control panel, I could add a 3rd button, but it would be tight. https://imgur.com/a/lSr2788
big10p
  • Last login:May 01, 2023, 01:46:23 pm
  • Mmmm, arcade classics!
Re: Gun.Smoke with 2 buttons?
« Reply #1 on: September 03, 2019, 06:04:43 am »
If you're using MAME, you should be able to reconfigure input so that B1 fires left, B2 fires right and B1+B2 fires forward.
edit: you would need to define left fire as B1 being pressed on it's own. Same for right fire. I was sure there was a way to do this in MAME but can't remember how it's done. Anyone know, or did I imagine it?
« Last Edit: September 03, 2019, 06:22:01 am by big10p »
  • Last login:Today at 08:25:01 am
« Reply #2 on: September 03, 2019, 09:34:19 am »
Hit tab, select remap this game, go to the line for the button that shoots up, press enter, hit both buttons at the same time.  Done.
big10p
« Reply #3 on: September 03, 2019, 09:43:09 am »
That's all I thought you have to do too, but it doesn't seem to work.
Haloman800
  • Awfully Awesome
« Reply #4 on: September 03, 2019, 09:56:56 am »
What about with a 60 in 1 board?
« Reply #5 on: September 03, 2019, 10:06:50 am »
Get creative with your wiring so that buttons 1 and 2 hit at the same time complete the circuit for button 3.
  • Last login:Today at 12:46:16 pm
« Reply #6 on: September 03, 2019, 10:15:27 am »
If you have cash to burn you could buy this.
https://riddledtv.com/arcade/condenser_boards.html#2to3button
The 2 to 3 button adapter might work for you.
« Reply #7 on: September 03, 2019, 12:18:00 pm »
Also, looking at your control panel, you could make it so that the third button is down by your thumb if you use first two with your index and middle finger. If that feels natural to you, it might be worth a go.
DarthMarino
  • Last login:December 17, 2025, 10:53:45 am
« Reply #8 on: September 03, 2019, 07:13:07 pm »
Highlight button 1, press enter, press the left button then QUICKLY double-tap the right button
Highlight button 2, press enter, press both buttons
Highlight button 3, press enter, press the right button then QUICKLY double-tap the left button
If done correctly it should say:
left not right
left right
right not left
Haloman800
  • Awfully Awesome
« Reply #9 on: September 04, 2019, 12:47:41 am »
I think I'll do this... Thanks Vigo.
big10p
« Reply #10 on: September 04, 2019, 08:09:30 am »
left not right
left right
right not left
Ah! I was sure there was a way to do it, just couldn't remember how. Seems like the OP has a 60-in-1 though, so can't use this method.
lilshawn
  • Last login:February 20, 2026, 07:25:33 pm
« Reply #11 on: September 04, 2019, 02:50:26 pm »
enter service mode and change the dip switch setting on gun smoke from 3 button to 1 button.
(attached pdf page 26)
Haloman800
  • Awfully Awesome
« Reply #12 on: September 05, 2019, 09:20:39 am »
THANK YOU... Now I don't have to drill any further  ;D
mrclean
    • Guscade
« Reply #13 on: September 05, 2019, 06:10:44 pm »
1, button, 2 buttons, 3 buttons.... practice & let me know when you'd like to go head to head ;-)
This game should really be played with 3-Button configuration. Mainly because that's how it's intended to be played, you have the ability so spray buttons with different button combinations. Look at the instruction card. This allows you to have 6 different combinations, the proper way to play the game... just saying, but what would I know about that game.
2,370,650 Gun.Smoke
