Arcade Collecting > Merit/JVL Touchscreen
Megatouch Evo Ion STUCK on setup screen...HELP!!!
<< < (2/3) > >>
Vman17:
I ran the 4 & 7 DP switch again today and everything checked out normal. Setup menu when I run hard drive check it says passed. The I/O check only makes it as far as the setup button which has a green light. Calibration or channel checks do not happen. Tried 3 I/O boards and all go directly to setup menu so I know it's not that. Could it possibly be the hard drive?
lilshawn:
--- Quote from: Vman17 on August 24, 2019, 01:49:25 pm ---Could it possibly be the hard drive?
yes. if it's still an original drive, just replace it. it's probably got 40,000 hours on it.
mahkeymike:
--- Quote from: lilshawn on August 25, 2019, 09:40:11 pm ---
He sent me pics. Its an old ide drive. Looks like it originally had 2008 on it, so yeah it probably have a lot of hours on it.
Vman17:
Tried new hard drive and still doing the same thing! Stuck on this screen.
mahkeymike:
Setup button has to be stuck closed. Since you replaced the IOboard, it has to be the OSD board. Call me and i will help you find the culprit.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
