Main > Monitor/Video Forum
Hantarex polo 25-28 multisync horizontal with control (SOLVED)
perjmolsen:
--- Quote from: princess prin prin on November 01, 2019, 02:29:27 pm ---Maybe it's my fault for not thinking of that after seeing this mistake done so many times by Italian collectors. Yes, with that tube you need the adapter.
Hi
No not your fault at all.. I could had tried it :)
I have now used the "imperdance adapter" - and the picture got wider, just a bit too wide, but it is an 25" monitor that I am testing on, so I think that a 28" would fit perfect.
But I am still unable to adjust the "curves" nothing happens when i turn "Pin cus". or the "Trap" pot.
Also nothing happens if I turn the horizontal with coil, I have tried to turn it all the way don, and also all the way out... no change at all...
princess prin prin:
Well, just remember to always use the adapter. 25" or 28" makes no difference. Now you're back to the original problem: no EW correction. The correction goes through the bridge coil but I doubt it's bad. You can check it though.
grantspain:
interesting fault, does anyone have the schematic ?
btw do you have any horizontal size adjustment?
perjmolsen:
--- Quote from: grantspain on November 01, 2019, 07:15:31 pm ---interesting fault, does anyone have the schematic ?
Hi Grant :cheers:
If I turn the H.AMP pot I am able to make a tiny adjustment in <-> size but only a 1-2 mm.
If i turn the H.PASE pot I can move the picture around sideways as normal, no problem there.
I have this schematics
https://www.dropbox.com/s/dmevxzs1rmw203y/schematic%202.jpg?dl=0
https://www.dropbox.com/s/oqgd9l346a5wted/schematic1%20.jpg?dl=0
grantspain:
you said in earlier post that T115 was a bdx530, do you mean a bdx53c?
