Main > Monitor/Video Forum
Hantarex polo 25-28 multisync horizontal with control (SOLVED)
Pages: << < (3/9) > >>
perjmolsen:
--- Quote from: princess prin prin on November 01, 2019, 09:06:59 am ---
--- Quote from: perjmolsen on November 01, 2019, 08:24:07 am ---I have tested that there is 12.4V at pin 1 at the IC301.
It needs 25V at pin 6.
Just tested there is 25V at pin 6 also
grantspain:
just want to add that if that is a direct clone of the polo 1 15/25 manual switching chassis then the deflection yoke horizontal specs are way different to a standard polo
princess prin prin:
Yes, that's why there is an impedance adapter mounted on the heat sink for 1.5mH tubes.
perjmolsen:
--- Quote from: grantspain on November 01, 2019, 11:07:56 am ---just want to add that if that is a direct clone of the polo 1 15/25 manual switching chassis then the deflection yoke horizontal specs are way different to a standard polo
Yes I have this strange thing on the chassis, I where wondering what that did. :dunno
So its an "impedance adapter"  :notworthy: - so I need to use this adapter if the yoke has a lower horisontal value than 1.5mh?
The yoke that I am testing on has the following values
HR: 2.2 ohm 1.56mH
VR: 6.4 ohm 10.86mH
Tube model: A59ECF50X05
In my test/faultfinding I have not used the adapter ....... is that my fault?  :banghead:
princess prin prin:
Maybe it's my fault for not thinking of that after seeing this mistake done so many times by Italian collectors. Yes, with that tube you need the adapter.
Go to full version
