Main > Monitor/Video Forum
Hantarex polo 25-28 multisync horizontal with control (SOLVED)
perjmolsen:
--- Quote from: grantspain on November 02, 2019, 04:38:33 am ---you said in earlier post that T115 was a bdx530, do you mean a bdx53c?
Hi
Yes I had made a typo :)
Its IS a BDX53C
grantspain:
similar faults on polo 2 i have had in the past have been mostly what has already been checked, T115 and T114 and east/west circuit
have you checked r224 100r
is there a reason d140 is not installed on that chassis
grantspain:
ignore my d140 statement, i read the earlier reply
perjmolsen:
--- Quote from: grantspain on November 02, 2019, 05:07:27 am ---similar faults on polo 2 i have had in the past have been mostly what has already been checked, T115 and T114 and east/west circuit
Hi Grant
I have pulled out R224 and it tests as 98.9 Ohm, so that resistor is also good.
Strange fault it is ..
perjmolsen:
I have pulled this chassis out again, I want to fint the fault :)
A question..B+ on this chassis is that also 145V?
It is only 108V...
