Author Topic: Golden Tee - Review  (Read 6448 times)
negative1
  • Last login:Yesterday at 02:33:31 am
Golden Tee - Review
« on: June 07, 2019, 02:04:07 pm »
lilshawn
  • Last login:Yesterday at 07:56:08 pm
Re: Golden Tee - Review
« Reply #1 on: June 07, 2019, 09:13:06 pm »
okay..
1: just...no
and
2: anybody who is anybody knows playing Golden tee on a cabinet with a monitor mounted near vertical like the 1up cab knows you'll smack your hand into it. this is why the real GT cabinets have the monitors damn near laying at a 45.
jennifer
« Reply #2 on: June 09, 2019, 12:29:45 am »
At 75 lbs for a machine that size, I would have to consider acceptable as a home use machine...But as L/shawn pointed out, screen damage and sore hands could be  issue with such an aggressively played game.
« Last Edit: June 09, 2019, 09:44:12 am by jennifer »
negative1
« Reply #3 on: June 10, 2019, 01:59:55 pm »
okay..
1: just...no
and
It's not vertical, it is slanted.
Thats what they did for this game.
Look at the picture.
later
-1
lilshawn
« Reply #4 on: June 10, 2019, 04:38:33 pm »
yeah it's slanted, but not nearly as much as an actual cabinet. and the control panel is nearly flat to plumb.. people who play golden tee typically follow through after hitting the trackball. not enough room here with the monitor as it is. the GT cabinet literally has the monitor mounted at around 45 degrees to plumb... combine that with the 15 some odd degrees the panel is to plumb, you are looking at close to 60 degrees between the panel and monitor. This gives you piles of space to follow through if that's your playstyle. (flipped for clarity)
  • Last login:Yesterday at 02:56:43 pm
« Reply #5 on: June 11, 2019, 09:09:20 am »
I agree that some folks are going to have to play differently. Heck, I have the golden tee arcade cabinet converted to Mame. When playing trackball games some people even hit the joysticks with their wild ass swings.
negative1
« Reply #6 on: August 28, 2020, 12:12:09 pm »
