Author Topic: Intervideo - Hard drivin restore  (Read 11911 times)
perjmolsen
  • Last login:December 08, 2022, 04:09:06 am
  • I want to learn, and try.. I NEWER give up :)
    • My gameroom
Re: Intervideo - Hard drivin restore
« Reply #40 on: March 08, 2019, 06:59:27 pm »
Hi
Thanks for the help  :cheers:
Yes the last one on the photo is a 18K
But i only have one 18K resistor  in my old parts box, and no 18K in my new parts boxes  :cry:
I have also looked on old china chassis, I might have an old CRT TV in my garage that i can take apart tomorrow, to see if there is one more 18K 1W or better a 36K 2W resistor
perjmolsen
    • My gameroom
« Reply #41 on: March 10, 2019, 05:43:44 pm »
Hi
I did not have any matching resistors in my parts bokses, or the old CRT TV - so i have to wait until middle of the week to get the last fiexed on the monitor.
Meanwhile i want to change the caps on the other boards too.
Starting with the motor amp board -> diagram can be found here: https://www.dropbox.com/s/a8ekyt9iepimzmx/Motor%20Amp%20PCB%20%28802%20KB%20PDF%29.pdf?dl=0
It seems a bit funny, there is to capacitors in series. 2x 100uf 35V
I want to replace them with some new, I guess that the two new, that I install need to be connected they way as in the picture, and also the polarity is correct, as i show in the picture?
Update added som ned photos of the caps - it seems that they not are original, they are solder to an resistor, and a diode
Also the other cap C30 at the right side, do I have marked the polarity correct?
« Last Edit: March 11, 2019, 02:02:58 am by perjmolsen »
perjmolsen
    • My gameroom
« Reply #42 on: March 11, 2019, 06:04:36 am »
Update
Put in new caps on the board - including the two weird ones, also noticed that they had the two positive leads solder together and the negative leads to the diode and the resistor, so I put in the new one the same way   ;D
perjmolsen
    • My gameroom
« Reply #43 on: March 11, 2019, 06:07:50 am »
An update
Still waiting for the new motor optro pcb.
The screen is working, colors are great and the cabinet is being cleaned and painted
« Last Edit: March 28, 2019, 05:28:56 am by perjmolsen »
