Author Topic: Need comments and criticism on my cabinet plans.  (Read 9572 times)
paigeoliver
  • Awesome face!
Re: Need comments and criticism on my cabinet plans.
« Reply #40 on: August 24, 2018, 11:00:10 pm »
Make the base deeper so the panel doesn't stick out as far (lower front panel moves forward). It should be free to do as far as wood goes and it makes the cabinet more stable. I think it might help the cabinet lines too.
Also, if you want to take those cuts to the next level, look at a Joust, same basic shape but it rounds it all off and looks better.
FALSE
  • Last login:February 25, 2024, 08:13:59 pm
« Reply #41 on: August 24, 2018, 11:21:39 pm »
So your saying make the 24" base like 26"?
I thought a little more overhang would give me more clearance for not smashing my hand into the monitor when I blast a shot on Golden Tee lol.
My original plan had just a 4" overhang from the front.
What's a "good"amount of overhang?
EDIT
And yes, I'll probably round the corners. Just wanted to get something thrown together in sketchup tonight.
EDIT AGAIN
Didn't expand the base but pushed the CP in 2 inches and changed the angle of the monitor area so I have the same depth CP as before.
Also took a bit of inspiration from the joust cab and got rid of the hard corner under the CP. Will still probably round a lot of the corners, just didn't want to mess with modeling them right now.
EDIT NUM 3
Here's another version. 26" depth. Still a 4" overhang for the CP. Made the angle piece under the CP a little longer. CP is now deeper, 12ish" rather than 10ish" like before. Gives me a little more room for blasting the trackball.
« Last Edit: August 24, 2018, 11:47:12 pm by FALSE »
1500points
  • Last login:November 20, 2018, 01:44:12 pm
    • How to succeed at Robotron
« Reply #42 on: August 25, 2018, 12:45:33 pm »
Pine control panels are good and solid and easy to swap.
A 1x6 is 3/4 by 5-1/2.
Etc.
If you design around that you won’t have to cut it skinnier which is a time saving convenience.
I would suggest not skimping on cp depth since it is nice to be able to lay a palm on the panel for some games.  Maybe at least a 1x8 to allow for future adaptations.
