Main > Project Announcements
javeryh's Small-ish Bartop ["Jack Attack!"]
Pages: << < (60/108) > >>
javeryh:
--- Quote from: Malenko on August 31, 2018, 05:03:56 pm ---I'm on CC 2014 I'll give it a go. I miss having access to the entire adobe line, but I dont have that job anymore.
EDIT: Is this what you want? (screen grab attached) or do you want the white outline around the cab axed as well?
Thanks!  The only thing I need removed is the thicker double white lines that the robot and the UFO are on top of (that are actually part of the art).  The other outer lines are guide lines for applying the art.  The entire piece is about 3/4" larger all the way around than it needs to be.
Malenko:
I saved  them as uncompressed PNGs.
https://drive.google.com/open?id=1SjaXncNjyqs2QLhWqsQKkPjaPxEdcXS_
if anything needs changed, LMK. Just tell me when you want the files deleted and I'll pull em down.
javeryh:
--- Quote from: Malenko on September 02, 2018, 02:09:28 pm ---I saved  them as uncompressed PNGs.
Thanks so much.  I'm DLing them now and if I have some time at work today I'll print it out for testing.  I hope to place the real art order this week...
firedance:
Further on from my thread where we discussed possible options for pc for this bartop, i've stripped down a dell optiplex 3010 sff (intel i3), the motherboard is 245mm square, the psu as shown in the picture is quite small as well, whether that would fit in the base of the bartop i'm not sure without measurements, could always use an ssd or laptop HD to save some space.
Just a thought, from eBay.co.uk a similar pc can be bought for around £70, maybe a similar price range from your eBay ?
https://www.ebay.com/itm/Dell-OptiPlex-3010-SFF-Desktop-i3-3220-3-30GHz-1TB-HDD-4GB-RAM-NO-OS-AVA/192607859695?hash=item2cd852b3ef:g:cHcAAOSweUlbNm~q
firedance:
**edit** just realised mine is actually a desktop (DT) not a SFF hence the differences - http://i.dell.com/sites/doccontent/business/smb/merchandizing/en/Documents/Dell_OptiPlex_3010_spec_sheet.pdf
So the SFF motherboard should be smaller but would have a larger PSU to deal with  ???
Go to full version
