Main > Project Announcements
javeryh's Small-ish Bartop ["Jack Attack!"]
Pages: << < (59/108) > >>
javeryh:
--- Quote from: Malenko on August 31, 2018, 11:18:13 am ---if he hasnt already done it by the time I get home, I'll take care of it
Thanks!!   :cheers:
Arroyo:
Theres a white border (1 inch outline from the outer edges) and theres a white edge (artwork has a has a very small white outline on the outermost edge).  You want both removed or just the white border?  I also assume you want the green outline removed as well?
Malenko:
just got home, looks like hey's taking care of it. Good jerb Arroyo
Arroyo:
Scratch that, Malenko gonna need you to take this one.  I’m on CS4 and I noticed something was off, it’s stripping the shadow layers in the robot.  If I flatten the image it’s there.  I’ll try to get an updated version of Photoshop if you are having the same trouble.
Malenko:
I'm on CC 2014 I'll give it a go. I miss having access to the entire adobe line, but I dont have that job anymore.
EDIT: Is this what you want? (screen grab attached) or do you want the white outline around the cab axed as well?
Go to full version
