Author Topic: Can someone please help me get my mouse working in mame  (Read 32875 times)
coppermouse
  • Last login:September 06, 2018, 11:04:12 am
« on: February 01, 2017, 09:58:40 am »
I cannot get any trackball games to work. I have a trackball connected to an ipac going into the serial port on the computer. Trackball or mouse works fine in Windows.
I am running Windows 7 pro 64 bit
MAME64 ver 0.172
I edited mame.ini and set mouse to 1 and trackball_device to mouse
I also tried a USB mouse.
Please help. Everything worked ok on my old computer running 0.038
Titchgamer
Re: Can someone please help me get my mouse working in mame
« Reply #1 on: February 01, 2017, 11:29:00 am »
2 stupid things to check first:
1) Have you configured the trackball in the mame options after pressing the tab button?
If so was it recognised ok?
2) some games have to be enabled to use trackballs/spinners etc via there service menu which can be activated via pressing F2.
coppermouse
« Reply #2 on: February 01, 2017, 11:46:13 am »
Yes it says mouse x and mouse y in the tab config menu
I will try F2 tonight
  • Last login:Today at 07:00:31 am
« Reply #3 on: February 01, 2017, 03:45:39 pm »
...but does MAME recognize the mouse when you try to remap them there?
coppermouse
« Reply #4 on: February 02, 2017, 10:21:04 am »
 I am not sure what you mean "...but does MAME recognize the mouse when you try to remap them there?: ? Can you explain to me better?
Had no luck with using F2, still does not work, and actually I am stuck in the service menu for centipede and cannot get out
Titchgamer
« Reply #5 on: February 02, 2017, 11:23:17 am »
When you enter the tab menu and scroll down the list to mouse x and y hit enter (on either) and move your trackball in the associated way.
If mame is recognising it then it will map it to your track ball.
If not there is something else wrong.
  • Last login:Today at 08:58:36 pm
« Reply #6 on: February 02, 2017, 11:27:19 am »
To remap controls in the MAME "Input (this Game)" menu:
- Use the up/down arrow keys to highlight the control you want to remap i.e. "Track X Analog"
- Press Enter
- Move the trackball horizontally
- MAME should register that movement and map the trackball X-axis to the "Track X Analog" input
- Do the same for "Track Y Analog" with the vertical Y-axis
If you make a mistake, Enter then ESC will set the highlighted input to "none" and Enter then ESC again will return the input to the default setting.
If you get stuck in a service menu, press F3 to reset/reboot the game.
coppermouse
« Reply #7 on: February 02, 2017, 12:31:59 pm »
No it does not map the trackball when I try that in the tab config menu
« Reply #8 on: February 02, 2017, 01:31:42 pm »
Something in MAME isn't properly configured.
Your mame.ini file should be in the "..\mame\ini\" folder.
-- If it isn't, move it there.
-- If it is, please post a copy so we can help you troubleshoot.
EDIT: Just noticed that you're using MAME64.
Is there a menu in the MAME64 GUI that allows you to enable trackball?
MAMEUIFX has a "Default Games Options--Controllers" menu with that option.
« Last Edit: February 02, 2017, 01:41:24 pm by PL1 »
Titchgamer
« Reply #9 on: February 02, 2017, 02:50:51 pm »
Dont think mame 64 has that menu Scott.
But yeah post up the contents of your ini file that should give us some clues....
« Reply #10 on: February 02, 2017, 03:15:43 pm »
It's been ages ago, but back when I first started messing around with this stuff I used MAME Plus. (circa v.128)
It turned out that it had it's own ini file in some other folder and making changes to the mame.ini in the main folder made no difference.
Could be something similar going on.
SlyBlueFox
  • Last login:November 29, 2023, 12:11:50 pm
« Reply #11 on: February 02, 2017, 04:17:18 pm »
Have you enabled multimouse in MAME?
  • Last login:Today at 07:14:15 pm
« Reply #12 on: February 02, 2017, 04:22:45 pm »
Mouse support was removed from MAME in an effort to make it "more accurate."
coppermouse
« Reply #13 on: February 03, 2017, 09:21:32 am »
Here is my mame.ini. Putting it in the \ini directory did not help. Renamed it to mame.txt as this site will not allow .ini extension
Multimouse is not enabled, I will enable it tonight.
Mouse support was removed?
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
rompath                   roms
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
pluginspath               plugins
languagepath              language
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
record_timecode           0
exit_after_playback       0
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
snapbilinear              1
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
sleep                     1
speed                     1.0
refreshspeed              0
# CORE RENDER OPTIONS
keepaspect                1
unevenstretch             1
unevenstretchx            0
intscalex                 0
intscaley                 0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              0
use_backdrops             1
use_overlays              1
use_bezels                1
use_cpanels               1
use_marquees              1
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
antialias                 1
beam_width_min            1.0
beam_width_max            1.0
beam_intensity_weight     0
flicker                   0
# CORE SOUND OPTIONS
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     1
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          mouse
lightgun_device           mouse
positional_device         mouse
mouse_device              mouse
# CORE DEBUGGING OPTIONS
verbose                   0
log                       0
oslog                     0
debug                     0
update_in_pause           0
debugscript
# CORE COMM OPTIONS
comm_localhost            0.0.0.0
comm_localport            15112
comm_remotehost           127.0.0.1
comm_remoteport           15112
# CORE MISC OPTIONS
drc                       1
drc_use_c                 0
drc_log_uml               0
drc_log_native            0
bios
cheat                     0
skip_gameinfo             1
uifont                    default
ui                        cabinet
ramsize
confirm_quit              0
ui_mouse                  1
autoboot_command
autoboot_delay            0
autoboot_script
console                   0
plugins                   1
plugin
noplugin
language                  English
# OSD KEYBOARD MAPPING OPTIONS
uimodekey                 SCRLOCK
# OSD FONT OPTIONS
uifontprovider            auto
# OSD INPUT OPTIONS
keyboardprovider          auto
mouseprovider             auto
lightgunprovider          auto
joystickprovider          auto
# OSD DEBUGGING OPTIONS
debugger                  auto
debugger_font             "Lucida Console"
debugger_font_size        9
watchdog                  0
# OSD PERFORMANCE OPTIONS
numprocessors             auto
bench                     0
# OSD VIDEO OPTIONS
video                     d3d
numscreens                1
window                    0
maximize                  1
waitvsync                 0
syncrefresh               0
# OSD PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# OSD FULL SCREEN OPTIONS
switchres                 0
# OSD ACCELERATED VIDEO OPTIONS
filter                    1
prescale                  1
# OpenGL-SPECIFIC OPTIONS
gl_forcepow2texture       0
gl_notexturerect          0
gl_vbo                    1
gl_pbo                    1
gl_glsl                   0
gl_glsl_filter            1
glsl_shader_mame0         none
glsl_shader_mame1         none
glsl_shader_mame2         none
glsl_shader_mame3         none
glsl_shader_mame4         none
glsl_shader_mame5         none
glsl_shader_mame6         none
glsl_shader_mame7         none
glsl_shader_mame8         none
glsl_shader_mame9         none
glsl_shader_screen0       none
glsl_shader_screen1       none
glsl_shader_screen2       none
glsl_shader_screen3       none
glsl_shader_screen4       none
glsl_shader_screen5       none
glsl_shader_screen6       none
glsl_shader_screen7       none
glsl_shader_screen8       none
glsl_shader_screen9       none
# OSD SOUND OPTIONS
sound                     1
audio_latency             2
# BGFX POST-PROCESSING OPTIONS
bgfx_path                 bgfx
bgfx_backend              auto
bgfx_debug                0
bgfx_screen_chains        default
# WINDOWS PERFORMANCE OPTIONS
priority                  0
profile                   0
# WINDOWS VIDEO OPTIONS
menu                      0
# DIRECT3D POST-PROCESSING OPTIONS
hlslpath                  hlsl
hlsl_enable               0
hlsl_oversampling         0
hlsl_write
hlsl_snap_width           2048
hlsl_snap_height          1536
shadow_mask_tile_mode     0
shadow_mask_alpha         0.0
shadow_mask_x_count       320
shadow_mask_y_count       240
shadow_mask_usize         0.09375
shadow_mask_vsize         0.109375
shadow_mask_uoffset       0.0
shadow_mask_voffset       0.0
curvature                 0.0
round_corner              0.0
smooth_border             0.0
reflection                0.0
vignetting                0.0
scanline_alpha            0.0
scanline_size             1.0
scanline_height           0.7
scanline_variation        1.0
scanline_bright_scale     1.0
scanline_bright_offset    0.0
scanline_jitter           0.0
hum_bar_alpha             0.0
defocus                   0.0,0.0
converge_x                0.0,0.0,0.0
converge_y                0.0,0.0,0.0
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.0,0.0,0.0
grn_ratio                 0.0,1.0,0.0
blu_ratio                 0.0,0.0,1.0
saturation                1.0
offset                    0.0,0.0,0.0
scale                     1.0,1.0,1.0
power                     1.0,1.0,1.0
floor                     0.0,0.0,0.0
phosphor_life             0.0,0.0,0.0
# NTSC POST-PROCESSING OPTIONS
yiq_enable                0
yiq_jitter                0.0
yiq_cc                    3.59754545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     0.0
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# VECTOR POST-PROCESSING OPTIONS
vector_length_scale       0.5
vector_length_ratio       500.0
# BLOOM POST-PROCESSING OPTIONS
bloom_blend_mode          0
bloom_scale               0.0
bloom_overdrive           1.0,1.0,1.0
bloom_lvl0_weight         1.0
bloom_lvl1_weight         0.64
bloom_lvl2_weight         0.32
bloom_lvl3_weight         0.16
bloom_lvl4_weight         0.08
bloom_lvl5_weight         0.06
bloom_lvl6_weight         0.04
bloom_lvl7_weight         0.02
bloom_lvl8_weight         0.01
# FULL SCREEN OPTIONS
triplebuffer              0
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# INPUT DEVICE OPTIONS
global_inputs             0
dual_lightgun             0
Titchgamer
« Reply #14 on: February 03, 2017, 09:56:20 am »
Other than enabling multimouse to 1 that looks ok and should work.
coppermouse
« Reply #15 on: February 03, 2017, 10:08:08 am »
Ok thanks. I will try that when I get home tonight
« Reply #16 on: February 03, 2017, 10:30:07 pm »
PBJ's gotta PBJ.   :lol
For now, that shouldn't make a difference since MAME doesn't see any mouse devices yet.
First get MAME to recognize mice, then enable multimouse if you want/need to isolate the mouse inputs.
inipath                   .;ini
Not sure if it makes a difference, but mine doesn't have the ".;"
I don't see anything else in there that might cause problems.   :dunno
If there's a "centiped.ini" file, delete it, launch Centipede again, and try mapping the mouse controls again.
-- In the "Controls (this Game)" menu, does "Track X Analog" show up as "Mouse X" or something else?
-- Can you remap other controls like P1 Button 1?
If that doesn't work, you might need to delete mame.ini and generate a new one using "mame -cc".
If that doesn't work, did you download MAME from MAMEDEV or is it a GUI build like MAMEUI or MAMEUIFX?
coppermouse
« Reply #17 on: February 04, 2017, 02:23:29 pm »
multimouse 1 did not help. I downloaded mame64.exe from mame dev. I deleter centipede config and it still will not map
Titchgamer
« Reply #18 on: February 04, 2017, 02:45:09 pm »
Hmm
What track ball u using? Though tbh ime running out of ideas?
Is it just centipede u having trouble with or any game?
« Reply #19 on: February 04, 2017, 03:15:48 pm »
Try these 4 steps:
1. Delete mame.ini, generate a new one with "mame -cc", and only change mouse to "1" in the new mame.ini. (fresh ini file with only one change made = best chance of success)
2. In the "Controls (this Game)" menu, does "Track X Analog" show up as "Mouse X" or something else? (tests if MAME recognizes that mouse is supposed to be enabled)
3. Can you map a different keystroke to P1 Button1?  (verifies that MAME can remap controls)
4. If so, when you exit MAME and re-launch it, does it retain the re-mapped key? (tests if MAME files are set to "read only")
coppermouse
« Reply #20 on: February 05, 2017, 11:09:29 am »
Ok I followed those steps and in the new mame.ini I noticed ini was set to ini/presets, so I copied the ini file to the ini/presets/ directory and it works. Thanks for all the help!!!!
RCalabraro
  • Last login:February 21, 2020, 01:35:43 pm
« Reply #21 on: February 21, 2020, 01:35:43 pm »
I am having a similar problem. I just installed MAME64. There is no mame.ini file that I can see. Please help!
« Reply #22 on: February 21, 2020, 02:48:07 pm »
Installing MAME doesn't generate a mame.ini file.
You have to run MAME with the "-cc" (create config) option one time to do that.
- For example, if your MAME executable is MAME64.exe, run "MAME64 -cc".
After that, you can edit mame.ini to enable mouse.   ;D
« Last Edit: February 21, 2020, 02:49:52 pm by PL1 »
retrometro
  • Last login:May 24, 2024, 09:11:44 pm
    • Arcade, mame, retro... and the gp2x.
« Reply #23 on: November 01, 2020, 12:46:31 pm »
I can confirm from 2020 that anyone with mouse issues being recognized in MAME, the main two lines to look for in main mame.ini or your individual game's ini file is to ensure that
Code: [Select]
mouse = 1
multimouse = 1
-------- gp2x and retro... play it forever! ------------------------
http://www.youtube.com/view_play_list?p=0EE573E86D5A86E0
Wavfact
  • Last login:March 13, 2025, 08:23:09 am
« Reply #24 on: May 05, 2021, 01:51:58 pm »
Well..  sorry.. reviving an old thread....
I have the same issue...   I did the "mame -cc".. Checked where it was looking for the ini file and put a copy there..  I enabled both mouse and multimouse in the ini file, rebooted and tried setting the mouse in the game config menu..  Nothing..
I am using a pi4 8gb, RetroPie v4.7.12.  Controller is a Mini-Pac with a Ultimarc U-Trak trackball which is plugged in the board..  When I rin "cat /dev/input/mouse0" I get feedback when moving the trackball..  Trackball work in retroarch gui and also in Pexil...  My mame version is 1.8.8 and emulator is mame2016
I've spent days on this and not getting anywhere...  Man, I really could use some suggestions..
BTW: I did add mame2016-mame_current_mouse_enable = "enabled" to core config..   In retroach.cfg I tried setting the index for player 1 from 0 thru 6 with no change..
Luzie
  • Last login:April 02, 2023, 08:32:15 am
« Reply #25 on: April 02, 2023, 08:31:05 am »
Just had this problem today and found the soluition:
Maybe mouse is set to 0 in GAMENAME.INI-File?
