Author Topic: Williams modern flipper assembly parts list  (Read 9996 times)
Ken Layton
  • Guru
  • Technician
« on: November 27, 2016, 08:00:42 pm »
I've created a one page listing of all the parts number for modern Williams flipper assemblies. I have noted which parts are particular to System 11 style and which are particular to WPC style.
otsep
  • Last login:September 28, 2025, 02:53:45 pm
  • I'm your huckleberry...
Re: Williams modern flipper assembly parts list
« Reply #1 on: November 27, 2016, 08:16:48 pm »
I thought about doing the Fliptronic style upgrade for my Pinbot.  This brings it to the front again.
Vids: Namco Rockin' Bowl-O-Rama
Pins: Aerosmith Pro, ST Premium Vault, Beatles Gold
Remember Wheaton's Law
Ken Layton
  • Guru
  • Technician
« Reply #2 on: November 27, 2016, 08:20:26 pm »
Pinball Life has 95% of the parts needed (and in stock) for most rebuilds and at very reasonable prices.
otsep
« Reply #3 on: November 27, 2016, 08:29:03 pm »
Been thinking of picking up this kit: http://www.pinballlife.com/index.php?p=product&id=172
Pinbot would need the SFL 19/400 - 30/750 coil, A-12111 Coil Stop and the SW-1A-194 Normally Open EOS.
I'm a little hesitant because I've never rebuilt a flipper before and getting this seems almost too easy.
So far, I've been pulling apart minor assemblies for cleaning and rebuilding(sleeves, springs) and this would be a big step up.
otsep
« Reply #4 on: November 27, 2016, 08:39:07 pm »
Correction.  I need the 03-7811 switch.  I think..
  • Last login:Today at 09:19:58 pm
« Reply #5 on: November 27, 2016, 10:10:47 pm »
Barring a broken part - Cleaning the sleeve, smoothing the plunger with sand paper, and filing the coil stop flat accomplishes like 95% of what a rebuild does and costs nothing.
Changing the flippers on Pin Bot is cheating.
Ken Layton
  • Guru
  • Technician
« Reply #6 on: November 27, 2016, 10:15:53 pm »
You want this assembly:
http://www.pinballlife.com/index.php?p=product&id=717
Select coil stop A-10821 and coil # FL23/600-30/2600-50VDC
Pinbot uses 50 volt flipper coils.
When you order the above complete flipper assembly and selected the items I mentioned, it will arrive with everything installed and wired, including the correct EOS switch and the spark suppressing capacitor.
Ken Layton
  • Guru
  • Technician
« Reply #7 on: November 27, 2016, 10:33:18 pm »
Yes you could do that, but that won't eliminate any "slop" in the assembly. Slop robs the flipper of power and response.
Pinbot is from 1986 and if it hasn't had a flipper rebuild, it's waaaaaayyyy past due. You'll probably find the coil stop is worn down and the plunger excessively worn too. Not to mention the slop in the plastic link or the bolt going through the link. Don't forget the end of stroke switch has had 31 years of sparking to wear it down too. In those days they never put any capacitors on the end of stroke switches. The complete flipper assemblies I linked too have all the updates/upgrades already. The modern units also make it easy to replace an end of stroke switch because the mounting bracket is bolted on not welded.
« Last Edit: November 27, 2016, 10:36:21 pm by Ken Layton »
otsep
« Reply #8 on: November 27, 2016, 10:50:59 pm »
So you think I should rebuild with that kit instead of the fliptronic style?
Ken Layton
  • Guru
  • Technician
« Reply #9 on: November 27, 2016, 10:58:40 pm »
Yes, I think you'll be very happy!
« Reply #10 on: November 27, 2016, 11:54:33 pm »
Slop is caused by a worn out link.   Certainly worth inspecting but I've rarely had to replace.  If the flippers feel nice and you can make the shots, there's no need to replace any of this.  Even if it's 31 years old.  I think a lot of owners don't bother with a cleaning attempt and give too much credit to their new parts.
otsep
« Reply #11 on: November 28, 2016, 12:01:59 am »
I'm actually pulling it apart assembly by assembly and rebuilding.  Cleaning everything and replacing rusted springs and coil sleeves.  ;)
otsep
« Reply #12 on: November 28, 2016, 12:10:41 am »
My flippers do not have the capacitor.
Ken Layton
  • Guru
  • Technician
« Reply #13 on: November 28, 2016, 12:21:45 am »
Oh God! Your flippers are 100% all original! Looks like they've never been rebuilt. All old style parts. I see tons of wear on the plungers plus you've got the original black plastic links. Needs to have capacitors installed, but with those old style EOS switch brackets, there's no place to mount them.
ed12
« Reply #14 on: November 28, 2016, 12:23:05 am »
the cap is there to surpress the arc across the eos switch
from gotileb system 3 up every mfg used it
or sent out a service bulliten to tell us to add it
ed
Ken Layton
  • Guru
  • Technician
« Reply #15 on: November 28, 2016, 12:39:32 am »
Standard procedure for me now is any solid state machine coming in for service now gets a capacitor on the EOS switch as well as a .1 uf @ 500 volts ceramic disc capacitor across the flipper button (cabinet) switches to keep them from sparking.
ed12
« Reply #16 on: November 28, 2016, 12:43:20 am »
yup
they even ditched there failure of opto switchs (flipper button) and went back to good ol leaf (with cap)
ed
otsep
« Reply #17 on: November 28, 2016, 07:29:10 am »
Alright. So I guess I really need to grab those kits you linked. :)
otsep
« Reply #18 on: November 28, 2016, 02:25:55 pm »
I checked today and the coil you mentioned is not an option.
Ken Layton
  • Guru
  • Technician
« Reply #19 on: November 28, 2016, 04:45:00 pm »
You call them or email them and tell them the coil you want.
Or else just select FL11630 coil. It's the same thing except it for having parallel coil windings and wiring it up is shown here:
https://pinside.com/pinball/forum/topic/vids-guide-to-upgradingrebuilding-flippers/page/2#post-453690
« Last Edit: November 28, 2016, 04:54:12 pm by Ken Layton »
