Author Topic: Lethal Enforcers 2. My first restoration project.  (Read 6777 times)
Scassidy24
  • Last login:October 12, 2023, 11:56:34 am
  • I love my Nostalgia Machine
    • forum.arcadecontrols.com/index.php/topic,150379.0.html
« on: October 12, 2016, 10:09:50 am »
Taking the plunge!
After building my own mame cab from scratch I'm ready to wet my beak on a real machine. Had to have this Lethal Enforcers cabinet.
I haven't had a chance to look inside yet but right off the bat I know it deserves new side art, new plexi glass, not sure if the viewing area was originally plexi? Or actually glass? The CP plexi needs replacing. Lots of cigarette burns and it's a busted up.
I'll have a few questions later when I get a closer look at the cab and more detailed pics to come
First question:  the FAQ in artwork has links to resources for side art but those are no more.  Anybody know where I could find some side art for this cabinet?
« Last Edit: October 12, 2016, 10:20:01 am by Scassidy24 »
Scassidy24
« Reply #1 on: October 12, 2016, 09:59:57 pm »
Pcb hanging by a thread
The control panel has clamps beneath but somebody took the liberty of screwing it on   Maybe they were afraid to reach past the tube to get to the clamps
Not sure what this was for. Behind the pcb foil side facing away from the pcb
This is dead no power to anything but the monitor
« Last Edit: October 12, 2016, 10:41:12 pm by Scassidy24 »
mourix
  • Last login:September 13, 2025, 06:23:32 pm
Re: Lethal Enforcers 2. My first restoration project.
« Reply #2 on: October 14, 2016, 06:45:40 am »
That's an awesome first restoration cab you've got there 8)
It seems like reproduction side art for this one is not available (yet). Your only hopes for now are touching up the original art or looking out for NOS replacements. The power supply you can just order on Happcontrols.
Good luck!
Titchgamer
« Reply #3 on: October 14, 2016, 07:45:19 am »
Ile look forward to seeing you get that back up and running :)
Scassidy24
« Reply #4 on: October 14, 2016, 05:10:39 pm »
New power supply installed. Unfortunately it didn't have the wiring or harness for the power switch/lighting circuit however....
Also I realized today that the instruction card got lost on the drive home :angry:
I didn't notice it was missing until I played the game today
I cleaned out the inside of the cabinet and secured the remaining 3 mounts for the pcb as well
« Last Edit: October 14, 2016, 05:13:07 pm by Scassidy24 »
Titchgamer
« Reply #5 on: October 14, 2016, 07:07:47 pm »
Good stuff
Scassidy24
« Reply #6 on: October 18, 2016, 06:01:45 pm »
New instruction card I pulled the image out of my mame artwork and printed came out sharp with no pixelation
Scassidy24
« Reply #7 on: November 03, 2016, 07:14:36 pm »
Does anybody know where I can find a 17" bulb?
Is this original hardware because If not I'll just slap any new fixture in?
« Reply #8 on: November 03, 2016, 07:19:21 pm »
check lowes / home depot, but youre better off just replacing the whole fixture.
Scassidy24
« Reply #9 on: November 05, 2016, 08:07:32 pm »
*deleted
« Last Edit: November 05, 2016, 08:15:41 pm by Scassidy24 »
Scassidy24
« Reply #10 on: November 05, 2016, 08:11:47 pm »
So because the new power supply doesn't have the 4 pin connector I can't use the  cabinet top mounted on/off switch.
I'm thinking I'll take a power supply cable and cut it in half, wire the switch in to it on the way to the power supply.
That'll get power to the machine and to the marquee lamp.
If I could have found a schematic for the old power supply I could confirm if that switch can handle the amperage. really like that switch I think it's original to the cabinet.
I'm just not certain If the power switch can handle the amp draw of the entire machine,maybe that's what it was intended to do or maybe the old powe supply had that power switch on a relay, anybody know?
« Last Edit: November 05, 2016, 08:24:13 pm by Scassidy24 »
TheMythTheLegend
  • Last login:June 08, 2018, 01:53:53 am
« Reply #11 on: December 21, 2016, 09:18:08 am »
You could wire in a 115v contactor that is toggled by the power switch.
I used one in my control panel build for my homebrew setup.
If I am working with over 5 amps and do not want to have to pull a plug, I will wire in a kill switch too.  Never pull a power cord that is smoking from the wall lol...
Also the contactor, takes the burden of the load and not the switch. So as long as you had a 115v switch it should be fine. Or I could be wrong. ;)
« Last Edit: December 21, 2016, 09:19:44 am by TheMythTheLegend »
Scassidy24
« Reply #12 on: March 02, 2017, 10:10:09 am »
NOW FOR SALE!  This cabinet new power supply has been in for a while now with the wiring all sorted out and it is up for sale if anybody is interested.
Titchgamer
« Reply #13 on: March 02, 2017, 11:31:08 am »
Well lets see some final pics then! ;)
