Author Topic: Speaker hiss and short  (Read 4044 times)
CASUSMC0311
  • Last login:July 01, 2016, 08:42:58 pm
« on: May 28, 2016, 09:49:49 pm »
something wrong with my speakers. I bought new 5v speakers and a new sound card for pi3. Im getting heavy hiss  and pops and it's shorting somewhere. no metal is touching and I checked the settings in retropie to make sure everything was good to go. the card plugs into the USB and then to the audio hookup with a male to male wire. Am I missing something? perhaps my splice jobe is sub-par? I hope someone can help. I keep posting question and no one answers. :dunno
ballboff
  • Last login:July 22, 2024, 02:25:17 am
Re: Speaker hiss and short
« Reply #1 on: June 14, 2016, 05:10:10 am »
Check your power.  If you're running too many things off the pi, it may be drawing too much power to supply everything.  Mine all runs off a 5v power supply, but I did try to run everything through a USB hub that wasn't powered, and I was having similar issues.  A powered USB hub should be the way to go, that way your screen and your pi can be powered independently.  If it's actually USB sound card then it still needs to be connected to the pi, however if it's just USB powered then that can be supplied on it's own.  Mine has a USB cable, but it also has a standard 2.5mm jack to supply the audio, the USB cable is just to power the speakers.
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
« Reply #2 on: June 16, 2016, 08:22:02 am »
I had to use a ground loop isolator
  • Last login:January 29, 2026, 07:33:48 am
« Reply #3 on: June 16, 2016, 09:41:53 am »
Yep, learn it live it love it.  I don't even bother diagnosing the issue anymore.
megatron99
  • Last login:July 28, 2016, 04:33:12 am
« Reply #4 on: June 26, 2016, 03:15:46 am »
Do you also need to use an amp?
southpaw13
  • Whatever!
« Reply #5 on: June 26, 2016, 03:16:32 pm »
I did, there are some cheapies at Amazon
