Author Topic: Raspberry Pi 3 with Retropie MAME Romset Question  (Read 11145 times)
tfphumorblog
  • Last login:April 18, 2016, 08:47:36 pm
« on: March 16, 2016, 02:15:14 pm »
I have a Pi 3 and am setting up Retropie this week. Any suggestions on best romset version for MAME? I got a few suggestions from the Retropie forum, but I'll throw it out here as well. The general consensus was that I should use lr-mame2003 with romset .78.
I understand it depends on what I want to play, but in general, would anyone disagree with this romset version? I run everything through clrmamepro just to make sure.
Thanks for your feedback!
Slippyblade
Re: Raspberry Pi 3 with Retropie MAME Romset Question
« Reply #1 on: March 16, 2016, 02:43:41 pm »
Sticky here with that info.  Unless you feel like doing some experimenting, stick with known configs.
http://forum.arcadecontrols.com/index.php/topic,144702.0.html
robboman123
  • Last login:February 17, 2021, 04:39:30 pm
« Reply #2 on: March 16, 2016, 02:46:03 pm »
I'm not sure, but interested too.
I've been setting up my RP3 over the past week, after first trying Retropie on my old RP1 the week prior.
The Retropie wiki lays it out pretty well.. just for MAME they have 5 different PI emulator ports, and they say exactly which romset is best for each one.  So I think you want to choose your emulator 1st, then get the romset to match it.  Mame4All runs the fastest, but AdvMame is the most customizable and supports the most games.
Right now, I'm not seeing much reason to not use AdvMame, since there seems to be CPU to spare on the RP3.
On my overclocked RP1, AdvMame was still too laggy on too many games.  Even a few of the old 80's classics.  But Mame4All ran everything I cared about, at full speed except for a tiny few that frameskipped.
Now on the RP3, AdvMame has run every game I've tried so far at full speed.  Even late 90's fighter games, and various Golden Tee into the 2000s.. stuff that is not in the old 0.37b5 romset.
Aside from the libreto\retroarch thing, I'm not sure what the pros and cons are with the other mame choices.
nitrogen_widget
« Reply #3 on: March 16, 2016, 04:23:50 pm »
lr-mame2003 will allow you to use shaders with scanlines and curved screen.
advmame only does scan lines.
that's all I can think of right now.
tfphumorblog
« Reply #4 on: March 16, 2016, 05:24:19 pm »
The only reason I'm trying lr-mame2003 is that one of the forum guys who seemed "in the know" thought it was a good idea. They haven't really updated the wiki with pi 3 suggestions yet. Mostly because nobody's quite sure how it will affect the mame front-ends.
I'll probably just try a few of them and report back! Thanks.
robboman123
« Reply #5 on: March 16, 2016, 10:07:30 pm »
Cool.
I'm running on a 27" arcade monitor, got all the curves and scanlines I need :)
