Author Topic: Can you give mame a specific portion of the screen, and a marquee on the top?  (Read 11193 times)
Lilwolf
I'm looking at building a smaller candy cab.  I'm having some issues with the marquee I had (betabrite).  It doesn't match the monitor I was going to use (too wide).
So the next idea.  Maybe I would buy a larger tv, and split the TV real estate with the majority at the bottom for the arcade.  But the top chunk for an active lcd marquee.
Is there any easy way to do this these days?
Drake
Nocturnaloner
  • Last login:May 05, 2016, 12:39:53 pm
  • AARRRRcade!
I was thinking about this.  I did get Hypermarquee running pretty well with a secondary small but wide monitor that was made to go in car seat backs.  Looks ok mounted in the cabinet above my main monitor, but the quality of the monitor is pretty poor.  Anyway, in order to do what you're thinking of, I'm afraid it would just be two applications running in windowed mode.
2600
You should be able to do this using the MAME artwork system.
lamprey
+1
That's what I've done on my system.
Nocturnaloner
  • AARRRRcade!
+1
That's right, it slipped my mind that you could do it with a .lay file.   Are you making custom layouts for each game(!!) or did you come up with one layout that works for everything?
Lilwolf
I would also love to know.
But I think, in my case, they will always be the same... and I could programmatically create a layout file for every mame game...  use a default marquee if it's there... or use a the original if I have it.
Thanks for the ideas!
+1
  • Last login:Today at 03:10:35 am
mamehooker will do it as well.... you don't have to make a layout for each game.  A tutorial is on the site.
nexusmtz
I know that mamehooker is a good choice for secondary monitors, but how would it go about sharing a single screen with MAME? I'd think that would require changes in MAME itself.
lamprey
+1
Custom for all.
I have a basic layout that I copy so it isn't too big of a deal. The most time consuming is converting the screen position within bezel artwork.
nexusmtz
...The most time consuming is converting the screen position within bezel artwork.
If you're modifying the values of the bezel and screen, you're probably making it harder than it has to be. Instead, just set the bounds of the view, and add the marquee.
[EDIT: OP wants to use a vertical screen. This math works OK on a horizontal screen, but not necessarily on a vertical, because the width of the bezel usually forces MAME to scale everything down on a vertical screen. When that happens, the marquee won't be at the top anymore.]
Let's say you want your bottom part (bezel and game screen) to be 70% of your screen, and the marquee to be 25% (with 5% in between), then, for a normal game where the bezel surrounds the game screen:
  • The width of the view is the same as the width of the bezel
  • The height of the view is the height of the bezel divided by .7
  • The X of the view is 0
  • The Y of the view is the height of the bezel minus the height of the view (you want a negative number)
  • The X and Y of the marquee are the same as the X and Y of the view (you want the marquee's box to start at the top left)
  • The width of the marquee is the same as the width of the bezel
  • The height of the marquee is the height of the view times .25
So, for Qbert, the view would be:
Code: [Select]
<view name="Upright with Marquee">
<bounds x="0" y="-1510" width="4000" height="5034" />
<marquee element="marquee">
<bounds x="0" y="-1510" width="4000" height="1259" />
</marquee>
<screen index="0">
<bounds x="836" y="278" width="2250" height="3000" />
</screen>
<bezel element="bezel">
<bounds x="0" y="0" width="4000" height="3524" />
</bezel>
</view>
Note that this does stretch the marquee. If you don't want that, you'll have to adjust the bounds of the marquee. Of course, that's just a little more math. If there's a way to force an element to keep aspect within given bounds, I haven't found it yet.
« Last Edit: March 18, 2016, 08:02:35 pm by nexusmtz »
nexusmtz
...The height of the view is the height of the bezel divided by .7
Oops. I forgot to compensate for the bezel's width vs the monitor width on vertical widescreens (as to how it affects the scaling.) I'd still use the view's bounds to place things instead of modifying the bounds of the bezel and screen, but placing the marquee in relation to the bezel is not as straight forward.
nexusmtz
...but placing the marquee in relation to the bezel is not as straight forward.
This is the math for the case where the width is the limiting factor, e.g. a typical bezel displayed on a portrait monitor
Keeping with the 70% screen space, 5% blank space, and 25% marquee space from the previous example, and assuming you want the game vertically centered in your 70%:
    • width="4000"
  • The height of the view is the width of the bezel divided by the monitor aspect
    • If the monitor is portrait, the aspect is going to be less than 1, e.g. 9/16 (.5625) instead of 16/9 (1.777...). Of course, if you want to think of this as multiplying by the landscape aspect, that's fine too.
    • 4000/(9/16)=7111.1111...
    • height="7111"
    • x="0"
  • The Y of the view (expressed as a negative) is the total of the vertical centering offset and the top section's height:
    • 70% of the height of the view (height*.7), minus the height of the bezel, divided by 2
      • (7111*.7-3524)/2=727
    • Plus 30% of the height for the top
      • 7111*.3=2133
    • 727+2133=2860
    • y="-2860"
    • x="0" y="-2860"
    • width="4000"
    • 7111*.25=1777.75
    • height="1778"
Code: [Select]
<bounds x="0" y="-2860" width="4000" height="7111" />
<bounds x="0" y="-2860" width="4000" height="1778" />
</marquee>
<screen index="0">
</screen>
</bezel>
</view>
After checking my marquee directory, it looks like the average marquee is more like 3.4:1, so 20% or less might look better than 25, but it's just a number. Since the aspects vary so much, you should resize your marquees outside of MAME e.g. imagemagick, retaining aspect (adding black bars), to the absolute width and height of your marquee space. At 25% of a 1920x1080 monitor rotated portrait, that's 1080x480.
If you have Imagemagick installed in c:\program files\ImageMagick, try:
Code: [Select]
pushd c:\games\mame\marquees
for %I in (*.png) do "c:\Program Files\ImageMagick\convert.exe" "%I" -antialias -resize 1080x480 -background black -gravity center -extent 1080x480 "%~nI_marquee%~xI"
Also, I notice that a lot of the bezels are width=4000. If you're not scripting the creation of the lay files, it would be helpful to write down the view height, plus the percentage values, as the only thing that will change is vertical centering (based on the height of the bezel).
Figuring out the view might look like it's a lot of work, but on a game like space invaders, it's easier than moving around 5 layered elements. It also makes it easy to compensate for whatever offsets you need.
bionictoothpick
  • Last login:July 28, 2025, 12:04:08 pm
  • Yes, I still play Maze Craze.
I thought I found the solution for vertical cabs using mamelay plus, but the diff no longer works since rendlay went from .c to .cpp .
Googling hasn't revealed anyone working on the project anymore...
sealcouch
  • Last login:October 19, 2025, 07:08:59 pm
Sorry to bump, but I'm working with the idea making a bartop inspired by the Mimic build and I was curious as to if there has been a better solution found since last April.
Going to use the top bit of the screen as a marquee instead of having another monitor and I would love to have a physical separation (ie a piece of t-modling with the spine trimmed) across the screen and always have the marquee on top of that divider for every game.
I'm going to do a little more work with the .lay files when I get home, but in the hour I tinkered with it I couldn't get the marquee to show.
  • Last login:Today at 12:56:46 am
Did you try changing the MAME "Video Options" menu settings, too?
sealcouch
Figured it out. It was a matter of double checking spelling. of all things.
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
Hey there!
I'm really digging up the past on this one. At this time is there any better way to accomplish this feat?
 Vert 16:9 screen. top portion marquee and the lower portion to gameplay.
My idea was to stick the lowest portion of a screen below the CP with the center of the display playing the game and the topmost showing a marquee.
