Author Topic: force 2011 KEY RANGE MISMATCH  (Read 7895 times)
brtlkat
  • Last login:September 03, 2021, 08:33:36 pm
« on: February 13, 2016, 04:27:31 pm »
Bought a 2011 key/dvd update for my 2006.5. 2011 Installed fine, rebooted all the way to megatouch force splash screen then KEY RANGE MISMATCH. Searching I see there was a patch for this or is there another way around it. I reinstalled software no go, cleaned key holder bent pin slightly. I put 2006.5 back in and it booted fine.
mahkeymike
  • Last login:November 21, 2025, 04:40:35 pm
Re: force 2011 KEY RANGE MISMATCH
« Reply #1 on: February 13, 2016, 05:40:02 pm »
I seems there support site is down. I put it up on sendspace.
https://www.sendspace.com/file/jreeh4
brtlkat
« Reply #2 on: February 13, 2016, 07:47:23 pm »
Sweeet thanks so much. Do I burn to dvd then update?
brtlkat
« Reply #3 on: February 13, 2016, 08:59:47 pm »
Ok. When I put it on a usb. It finds update and then says failed to find tarball file and then fails update. Not sure if I'm doing it correctly.
mahkeymike
« Reply #4 on: February 13, 2016, 09:20:02 pm »
Can you take a pic of the fail screen?
According to an old cached webpage, the .tgz i uploaded is the correct one for 2011 force. Does the software find the update during the boot process? Also, what version 2011 force is on your install disc?
Make sure you format the usb thumb drive with rufus and use fat32 then add that .tgz to the main root of the thumb drive.
brtlkat
« Reply #5 on: February 13, 2016, 09:28:04 pm »
Hi just pmed you. On my end I have a update file and a usr file. Not in .tgz form. In total 2 files.
brtlkat
« Reply #6 on: February 13, 2016, 09:28:45 pm »
I can get a pic of the fail point.
brtlkat
« Reply #7 on: February 13, 2016, 09:39:04 pm »
version 28.30t it said when installing it.
brtlkat
« Reply #8 on: February 13, 2016, 09:44:52 pm »
pic of fail
mahkeymike
« Reply #9 on: February 13, 2016, 09:54:14 pm »
The link i gave you should give you one single .tgz file. You put that file directly onto a fat32 formatted thrumb drive and boot the system with it plugged into a usb port. It should automatically take the update.
brtlkat
« Reply #10 on: February 13, 2016, 10:16:29 pm »
The link gave me a zip file and I unzipped and seen 2 items a update file and a usr file folder,,, no .tgz file
brtlkat
« Reply #11 on: February 13, 2016, 10:34:55 pm »
snap shot of the download
mahkeymike
« Reply #12 on: February 13, 2016, 10:47:02 pm »
Its not a zip file. Its a gzip archived tarball. Just download it as is and put it on a thumb drive.
orizzle
  • Last login:September 21, 2020, 07:20:41 pm
« Reply #13 on: February 13, 2016, 10:54:47 pm »
Your screenshot literally shows it's a tgz file in the title bar...
brtlkat
« Reply #14 on: February 14, 2016, 03:59:53 am »
Thanks Mike Got it going  ;D
