Author Topic: cab mame launching a letter box sized view  (Read 6979 times)
ant2
  • Last login:June 02, 2024, 07:05:47 am
« on: February 02, 2016, 02:01:51 pm »
I am real rusty with mame set up options, but I am trying to run cabmame for virtua racing.
when i run the game in full screen mode (and any other game) it opens full screen, but only displays in the middle of a scree in a tiny box.
I have tried changing -resolution and other options, lots of googling, does the same on both pc's, tried an old mame.ini that I use, which works fine for mame and still no good.
What option am I missing, I've given up :)
  • Last login:Today at 06:44:21 pm
Re: cab mame launching a letter box sized view
« Reply #1 on: February 02, 2016, 02:41:04 pm »
Is -switchres turned on, because if it isn't the resolution option doesn't do anything.
ant2
« Reply #2 on: February 02, 2016, 03:21:19 pm »
doesn't seem to be. ive tried building a new config, no luck:
mame.ini
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
rompath                   roms
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
memcard_directory         memcard
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
sleep                     1
speed                     1.0
refreshspeed              0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              0
use_backdrops             1
use_overlays              1
use_bezels                1
use_cpanels               1
use_marquees              1
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# CORE SOUND OPTIONS
sound                     1
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.05
joystick_saturation       1
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
log                       0
verbose                   0
update_in_pause           0
debug                     0
debugscript
debug_internal            0
# CORE MISC OPTIONS
bios
cheat                     0
skip_gameinfo             0
uifont                    default
ramsize
confirm_quit              0
# WINDOWS DEBUGGING OPTIONS
oslog                     0
watchdog                  0
debugger_font             "Lucida Console"
debugger_font_size        9
# WINDOWS PERFORMANCE OPTIONS
priority                  0
multithreading            0
numprocessors             auto
profile                   0
bench                     0
# WINDOWS VIDEO OPTIONS
video                     d3d
numscreens                1
window                    0
maximize                  1
keepaspect                0
prescale                  1
waitvsync                 0
syncrefresh               0
menu                      0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 1
# DIRECT3D-SPECIFIC OPTIONS
d3dversion                9
filter                    1
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable               0
hlslpath                  hlsl
hlsl_ini_read             0
hlsl_ini_write            0
hlslini                   %g
hlsl_prescale_x           0
hlsl_prescale_y           0
hlsl_preset               -1
hlsl_write
hlsl_snap_width           2048
hlsl_snap_height          1536
shadow_mask_alpha         0.0
shadow_mask_x_count       320
shadow_mask_y_count       240
shadow_mask_usize         0.09375
shadow_mask_vsize         0.109375
curvature                 0.0
pincushion                0.0
scanline_alpha            0.0
scanline_size             1.0
scanline_height           0.7
scanline_bright_scale     1.0
scanline_bright_offset    0.0
scanline_jitter           0.0
defocus                   0.0,0.0
converge_x                0.0,0.0,0.0
converge_y                0.0,0.0,0.0
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.0,0.0,0.0
grn_ratio                 0.0,1.0,0.0
blu_ratio                 0.0,0.0,1.0
saturation                1.0
offset                    0.0,0.0,0.0
scale                     1.0,1.0,1.0
power                     1.0,1.0,1.0
floor                     0.0,0.0,0.0
phosphor_life             0.0,0.0,0.0
yiq_enable                0
yiq_cc                    3.59754545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     0.0
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# FULL SCREEN OPTIONS
triplebuffer              0
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
resolution 1360x768
# WINDOWS SOUND OPTIONS
audio_latency             2
# INPUT DEVICE OPTIONS
hide_cursor               1
dual_lightgun             0
skip_disclaimer 1
skip_gameinfo 1
skip_validitychecks 1
« Reply #3 on: February 02, 2016, 04:02:41 pm »
There's your problem.  You aren't defining a proper resolution.
1024x768  won't work in mame.  You also need to define the refresh rate, so 1024x768x60  will do it.
You can confirm that mame is "finding" the resolution via using the -verbose flag and reading the text in the command prompt when done.
ant2
« Reply #4 on: February 02, 2016, 04:24:14 pm »
1360x768 appears to be getting picked up, but I also tried 1024x768, the picture is still a small square in the center.
i think its something to do with cab mame, the config and res work fine in standad mame:
ive attached the verbose log of both, to keep the post down.
thanks for your help. or if any one has a good cabmame mame.ini they could give me that would be great...
SailorSat
  • Last login:Today at 08:19:17 am
    • For Amusement Only e.V.
« Reply #5 on: February 02, 2016, 08:38:52 pm »
try adding "changeres 0" to your mame.ini
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
ant2
« Reply #6 on: February 03, 2016, 01:16:42 pm »
that was the ticket! thanks sailorsat!
now i am being picky but I don't suppose there is any way to stretch the screen fully? as i have two bars down the sides
« Reply #7 on: February 03, 2016, 01:32:07 pm »
That's the way it's supposed to look.  It's a 4:3 game.  Every time you stretch a 4:3 to 16:9 a 27 inch arcade monitor falls on a puppy and kills it.
"Winners Don't Distort Games"
--  Howard A Casto
    Director, Idiot Police
  • Moderator
  • Last login:November 21, 2025, 10:39:28 am
« Reply #8 on: February 03, 2016, 01:34:41 pm »
The original Virtua Racing deluxe cabinet was available in widescreen.  :)
The option is in MAME and works.
ant2
« Reply #9 on: February 03, 2016, 04:45:09 pm »
I changed the system set up to "16:9" within the game itself, what option do I need in mame ? I have tried the following, but it doesn't appear to do much:
screen_aspect 16:9
SailorSat
« Reply #10 on: February 03, 2016, 05:13:15 pm »
try "cleanstretch 0"
ant2
« Reply #11 on: February 04, 2016, 03:47:15 am »
no joy :(
once we figure this out, i'll post the config to getting virtua racing full screen with network to help others skip this pain :)
MrThunderwing
  • Last login:August 19, 2025, 02:18:43 pm
  • As I pass, do I give you the ass or the crotch?
« Reply #12 on: February 18, 2016, 04:40:38 pm »
This is the config I use to get it to run fullscreen with no letterboxing - I think this was using the same advice that I got from SailorSat that she's already already given you here though. Give it a try and see if it helps though.
Code: [Select]
readconfig                1
writeconfig               0
rompath                   roms
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
cheatpath                 cheat
cfg_directory             cfg
input_directory           inp
state_directory           sta
diff_directory            diff
hiscore_directory         hi
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
burnin                    0
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  0
sleep                     1
speed                     1.0
refreshspeed              0
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
artwork_crop              1
use_backdrops             0
use_overlays              1
use_bezels                0
use_cpanels               0
use_marquees              0
brightness                1.0
contrast                  1.0
gamma                     1.0
effect                    none
cleanstretch              0
changeres                 0
redraw                    0
antialias                 1
beam                      1.0
flicker                   0
sound                     1
samplerate                48000
samples                   1
volume                    0
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.1
joystick_saturation       0.95
natural                   0
coin_impulse              0
directinput               0
mouse_device              mouse
log                       0
verbose                   0
update_in_pause           0
debug                     0
debugscript
debug_internal            0
# CORE MISC OPTIONS
bios
cheat                     1
skip_gameinfo             0
uifont                    default
ramsize
confirm_quit              0
# CORE COMM OPTIONS
localhost                 0.0.0.0
localport                 15112
remotehost                127.0.0.1
remoteport                15112
# CORE MKChamp OPTIONS
disable_hiscore_patch     0
disable_nagscreen_patch   0
disable_loading_patch     0
oslog                     0
watchdog                  0
priority                  0
multithreading            0
numprocessors             auto
profile                   0
bench                     0
video                     d3d
numscreens                1
window                    0
maximize                  1
keepaspect                0
prescale                  1
waitvsync                 0
syncrefresh               0
menu                      0
hwstretch                 1
d3dversion                9
filter                    0
hlsl_enable               0
hlslpath                  hlsl
hlsl_ini_read             0
hlsl_ini_write            0
hlslini                   %g
hlsl_prescale_x           0
hlsl_prescale_y           0
hlsl_preset               -1
hlsl_write
curvature                 0.0
pincushion                0.0
scanline_alpha            0.0
scanline_size             1.0
scanline_height           0.7
scanline_jitter           0.0
defocus                   0.0,0.0
saturation                1.0
offset                    0.0,0.0,0.0
scale                     1.0,1.0,1.0
power                     1.0,1.0,1.0
floor                     0.0,0.0,0.0
yiq_enable                0
yiq_cc                    3.59754545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     0.0
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
triplebuffer              1
switchres                 1
audio_latency             2
hide_cursor               1
dual_lightgun             0
I have a cabMAME question myself: If you're running multiple instances of it on a single PC, only the 'open' window seems to register any joypad inputs. Is there any way to get the other windowed versions of MAME to register a joypad when they're not the selected window (if you know what I mean)?
Edit: NVM, think I've found the answer.
« Last Edit: February 18, 2016, 04:53:38 pm by MrThunderwing »
ant2
« Reply #13 on: February 27, 2016, 03:29:37 pm »
thanks thunderwing, this was the ticket.
with the above config, all you need now is the following batch file on each pc: (remote host is the destination PC)
"C:\LAN\Virtua Racing\cabmame64.exe" vr -remotehost 192.168.1.201
Then the other PC has the remote host of your other PC
i.e
"C:\LAN\Virtua Racing\cabmame64.exe" vr -remotehost 192.168.1.202
MrThunderwing
« Reply #14 on: February 27, 2016, 07:13:43 pm »
Thanks, but I think you may have misunderstood what I was asking. I know how to set up a LAN and also a single PC network (I removed my IP info from the ini config). The issue I was having was that on a single PC network, you could only control one car (thinking specifically of Virtua Racing) - the one that was in the window that was in focus. The latest version of MAME (170b) has corrected this (it may even have been sorted in an earlier revision) with a global inputs option.
« Last Edit: February 27, 2016, 07:15:46 pm by MrThunderwing »
ant2
Re: Virtua Racing - Network Play
« Reply #15 on: February 28, 2016, 02:33:47 am »
Sorry you misunderstood, the information above wasn't directed at you in particular :)
I wanted to write up the information on how to play Virtua Racing with Netplay and fullscreen - to save someone else the hassle.
MrThunderwing
« Reply #16 on: February 28, 2016, 07:47:07 pm »
Ah, no worries, I'd just assumed it was for my benefit.
