Author Topic: megatouch EVO wont load, Please help!  (Read 5606 times)
clc1986
  • Last login:January 03, 2016, 03:50:26 pm
  • need help fixing my megatouch evo
« on: December 26, 2015, 02:57:49 pm »
I recently bought a used  megatouch EVO and when I got it, its doesn't work. When I turn it on the fan works and it starts to load, it says no signal and then goes to a page that says  "force intelligent entertainment press TAB to show POST screen, DEL to enter SETUP "and then it just freezes up on that page. I tried hooking up a keyboard to the back to see if that would work and still nothing. Does anyone know anything about these machines? Any info would be great considering I do not know anything about them.
orizzle
  • Last login:September 21, 2020, 07:20:41 pm
Re: megatouch EVO wont load, Please help!
« Reply #1 on: December 26, 2015, 08:38:54 pm »
Press DEL to get into setup. Can you see if the hard drive is being detected?
otsep
  • Last login:September 28, 2025, 02:53:45 pm
  • I'm your huckleberry...
« Reply #2 on: June 08, 2016, 11:58:41 pm »
I had one that did this until I replaced the motherboard battery.  Pull the battery and check it's voltage.
After replacing/keeping the battery, set DIP switch 8 on the IO board to the down position.  This should reload the CMOS setting and do a test of the system.
I'm not expert, but this has worked for me in the past.
Vids: Namco Rockin' Bowl-O-Rama
Pins: Aerosmith Pro, ST Premium Vault, Beatles Gold
Remember Wheaton's Law
lilshawn
  • Moderator
  • Last login:December 11, 2025, 11:01:31 pm
« Reply #3 on: June 09, 2016, 04:37:04 pm »
a failed drive or bad drive cable can cause the computer to sit and wait endlessly for the drive to become available.
have a listen to the harddrive...it should spin up...click a few times then be ready. if it clicks clicks clicks it's toast. if it sounds like it's not spinning up...check your power supply. it should have 12 volts and 5 volts. if it's good. the motor on the drive is probably toast.
ed12
« Reply #4 on: June 09, 2016, 09:00:03 pm »
if it is a Maxtor hard drive ?
u can lean towards toast
ed
otsep
« Reply #5 on: June 09, 2016, 09:10:24 pm »
Any good, inexpensive SSDs out there? lol
lilshawn
  • Moderator
« Reply #6 on: June 14, 2016, 01:12:11 pm »
i'v had hit and miss experience with SSD's and megatouch. I haven't tried in a while...but  the way the megatouch runs.... puts a lot of reading stress on an SSD. the constant reading of the NAND wears it out very quickly and makes it susceptible to failure and corruption. modern SSD's are a lot better at autonomously fixing issues on the fly so it might not be much of an issue with a brand new modern SSD.
