Author Topic: Elbow Room Innovations - custom light boxes and other cool stuff!  (Read 16940 times)
  • Last login:Yesterday at 08:12:36 pm
Re: Elbow Room Innovations - custom light boxes and other cool stuff!
« Reply #40 on: August 25, 2015, 11:53:27 pm »
If it helps, the size of the inserts I design for my keys are 1.377" by 2".
Should be similar to these then - ( http://www.ebay.com/itm/10x-Clear-acrylic-keychain-2-x-1-3-8-photo-insert-for-luggage-ID-keyring-51x35mm-/360843329190?hash=item5403f03ea6 )
Figure they say the insert is 1 3/8" ( 1.375" ) x 2" -- not too bad for $0.70 a piece shipped from PA ( and they'll combine shipping if you order several sets.
OR these for $1.89 for 5 from china ( http://www.ebay.com/itm/5PCS-Transparent-Blank-Photo-Picture-Frame-Clear-Keychain-Key-Ring-Fob-5-1X3-2cm/310836080641?_trksid=p2045573.c100034.m2102&_trkparms=aid%3D555012%26algo%3DPW.MBE%26ao%3D2%26asc%3D32831%26meid%3Dd99d32eafe6f4e80a2d79a513f67e3d5%26pid%3D100034%26rk%3D2%26rkt%3D8%26mehot%3Dpp%26sd%3D360843329190 )
The PA ones say this on the insert: Photo insert dimension 1-1/8 x 1-3/4" (44x28mm)
That's still too small.
JDFan
« Reply #41 on: August 26, 2015, 12:16:24 am »
« Last Edit: August 26, 2015, 12:19:24 am by JDFan »
« Reply #42 on: August 26, 2015, 12:17:41 am »
I wonder if the 1.75 x 2.35 ones would be better?
  • Last login:Today at 12:56:46 am
« Reply #43 on: August 26, 2015, 12:28:24 am »
The one I posted above uses that size insert.
http://www.amazon.com/gp/product/B005ESGODA
It would be nice to find a bulk rate on them, though.   :dunno
JDFan
« Reply #44 on: August 26, 2015, 01:15:04 am »
Found some 12 packs for $7.50 on aliexpress ( http://www.aliexpress.com/item/12pcs-Bigger-Blank-Acrylic-Rectangle-Photo-Keychains-Insert-Picture-Logo-Keyrings-Key-tag-2-25-x/1911180131.html ) that look to be the right size !
Insert size : 49MM*34MM/2''*1.2''
« Reply #45 on: September 14, 2015, 11:09:23 pm »
Great news, I took a flier on these, and they ARE the same size as OldTymeToys if you want to roll your own keychains to match the ones you might already have:
TWO Photo Frame Key Chains 1.75" x 2.25" - Keep a Picture of Loved One w/ Keys
The same seller also sells them in lots of 12.... not a bad deal if you need a lot.
JDFan
« Reply #46 on: September 15, 2015, 10:41:30 am »
a bit expensive with the shipping for a single but not bad for the 12 pack @ $7 shipped -- Got the smaller ones in the other day and they came out decent but as mentioned are smaller - the second set is a bit better at 1"x 1.75" inserts (smaller set is 1" x 1.5") -- Here's a pic of a few I made up using them : (Excuse the poor quality pic as my camera is pretty bad !)
« Reply #47 on: September 15, 2015, 10:44:17 am »
You get TWO in the first link, not a single. But yeah,  the dozen is a great deal.
Mr. Peabody
  • Last login:November 11, 2025, 07:08:52 pm
« Reply #48 on: December 09, 2015, 07:58:55 pm »
I think these look better than a square old box. They make me think arcade cabinet rather than just game.
