Author Topic: Use the last 80% of your battery  (Read 3850 times)
SavannahLion
« on: June 07, 2015, 03:29:32 am »
All I can say is... WTF?
Start with the link: http://www.batteriser.com/
When I see this, I think of those stupid little stickers people used to put on their gas tanks to increase their mileage or the metallic sticker on the back of chocolate bar cell phones to increase the range.
What really gets me is that a ton of "respectable" sites are featuring this pile. What the hell? If there's anything inside that ribbon of metal, I have to wonder if the're trying to use a boost convertor. Which begs the question, can one make a boost convertor small enough to fit in the head of a PoS?
Edit: Apparently, that's exactly what this company is claming, that he did indeed create boost convertor thin enough to fit inside a compartment with a battery. Still doesn't smell right though.
« Last Edit: June 07, 2015, 03:39:05 am by SavannahLion »
ark_ader
  • I glow in the dark.
Re: Use the last 80% of your battery
« Reply #1 on: June 07, 2015, 06:38:28 am »
Will it smell like burning plastic?
shponglefan
« Reply #2 on: June 07, 2015, 09:21:30 am »
Hackaday had an article debunking it: http://hackaday.com/2015/06/06/crowdfunding-follies-debunking-the-batteriser/
And EEV blog as well:
lilshawn
  • Last login:September 20, 2025, 05:55:53 pm
« Reply #3 on: June 08, 2015, 12:25:15 pm »
heh pile.
also, making claims by omitting little bits of pertinent information is quite a common practice in "marketing wank" it's the only way some things ever get sold.
I too remember the little squiggly stickers you put under the battery of the phone to "improve your reception to the equivalent of a 4 FOOOT ANTENNA!" except radio frequency antennas are tuned to the exact frequency you are TX/RXing...  A longer antenna wouldn't give you better reception (even if it did what it claimed) when compared to the one tuned to the frequency you are trying to receive by the phone manufacturer...and since it (the antenna booster sticker) isn't electrically connected to any bits of the radio inside the phone ANYWAYS... it doesn't matter one lick of crap.
it's been a while since we've had a rip off product that would appeal to everyone like this.
SavannahLion
« Reply #4 on: June 08, 2015, 12:53:26 pm »
Does ReadyBoost count?
lilshawn
« Reply #5 on: June 08, 2015, 03:03:03 pm »
 :laugh2:
Readyboost never worked regardless of what device you plugged in.
  • Last login:Yesterday at 10:33:32 pm
« Reply #6 on: June 08, 2015, 03:48:58 pm »
I'm still kind of knicked about these "instant battery chargers" for your car.  I'm not talking about the ones that essentially have a car battery inside or hook up to your house power that actually work, I'm talking about the ones that essentially have the battery from your cordless drill in them and decidedly do not.
If your battery is ever so slightly low it *might* work but they market them like you can start a car with a dead battery with them.  I can't even start a car with my giant craftsman instant start if the battery is dead.
SavannahLion
« Reply #7 on: June 08, 2015, 09:36:31 pm »
 :laugh2:
I was specifically referring to rip off devices with marketing wank.
Has anyone ever used ReadyBoost? I recall a line of shoddy PC's sold with those USB sticks.
  • Last login:June 25, 2025, 03:09:16 pm
« Reply #8 on: June 12, 2015, 11:38:08 am »
I used readyboost on my old work laptop when trying to run photoshop and massive spreadsheets. It was mostly a security blanket to make me feel like I was getting doing everything I could to speed it up. It might have made a slight difference, but I really can't say it was a solid speed benefit. USB sticks are a dime a dozen.
lilshawn
« Reply #9 on: June 12, 2015, 02:53:33 pm »
when disk cache was measured in kilobytes, i suppose readyboost could help those drives... but it's not uncommon to have 64mb now. the throughput of the USB is more of a hinderance than drive speed was.
now with SSD so prominent, readyboost is moot.
MonMotha
« Reply #10 on: June 12, 2015, 09:38:26 pm »
This is a lot more feasible than it seems.  You would be astounded how much power you can pull off a power tool type battery (cell Li-Ion optimized for power, not energy, density).  Something like 6-7 years ago the battery shop I worked with was pulling 75A at 19V off a pack for a cordless drill.  That's 1.4kW (comparable, btw, to what you can pull off a 15A wall socket).  They were willing to warranty it for 2-3 years under essentially continual charge/discharge usage (professional craftsman setting).
I'm sure battery tech has improved at least some since then, and you can go quite a bit higher without compromising the electrical/personal safety of the system.  You'll just wreck the battery after only a few dozen cycles.  That's OK for this application.  Figure you can get a few hundred amps at a nominal ~19V off a high-quality Li-Ion pack sized for a typical cordless drill with no problems.   With a reasonably efficient switch-mode converter, you can hit 12-13V at currents comparable to the CCA rating of a typical car battery and with less effect from lower temperature to boot.
Now, you're not going to charge your car battery this way since there's not enough energy in the tiny portable jump-box, but hooking up a little box the size of 6 decks of cards stacked on each other and weighing less than 10 pounds to your car to "jump-start" it (and allow the alternator to charge the battery in the car normally) is amazingly feasible.
Obviously this won't work if your car battery damaged or so discharged as to be essentially shorted.  In that case, all the juice from the jump-box goes into the battery and not the starter motor.  Some of the portable jump-boxes that I've seen recommend disconnecting the car battery if you have trouble starting for this reason.
Some of them also work by re-charging the (presumably) dead-but-not-damaged (just left your headlights on or similar) car battery through the cigarette lighter port.  They usually recommend you leave it plugged in for several minutes for that to take place.  These are usually touted as allowing you to jump-start your car without opening the hood.  The problem with this trick is that it only works on a mildly dead battery.  There's not enough energy in such a small Li-ion pack to charge the humongous lead acid in your car up enough to run the starter motor.  The reason the direct connection method works is that, while the tiny little portable jump-box has comparatively little stored energy, it can dump it all rather quickly.
danny_galaga
  • Last login:Yesterday at 02:13:48 am
    • dans cocktail lounge
« Reply #11 on: June 16, 2015, 04:42:17 am »
:duckhunt
