Author Topic: Megatouch Ion Elite Edge 2006 hardware upgrade  (Read 5642 times)
tthorn125
  • Last login:May 27, 2021, 05:59:25 pm
« on: April 28, 2015, 01:23:39 pm »
Hi all,
I recently purchased the above machine and would like to upgrade the motherboard.  It's quite loud, so I have another power supply coming as well.
I've read that the Intel D945GCLF2D Atom is an acceptable replacement for the Aurora, is it also the case for the Elite Edge?  Everything works as is, but I've read that the ECS boards are very likely to fail.  Thoughts?
Toby
« Last Edit: April 28, 2015, 02:17:29 pm by tthorn125 »
mahkeymike
  • Last login:January 15, 2026, 03:00:29 pm
Re: Megatouch Ion Elite Edge 2006 hardware upgrade
« Reply #1 on: April 28, 2015, 05:50:20 pm »
You will need a bunch of pcb stand offs and you will need to make a itx-atx mount template. I suggest using clear plexiglass and a utility razor knife and dremmel if you have one. I make conversion kits but they are made to order. If your handy, have at it. If not, send me some pics of your back case with the internals removed and i can make one for you. I am actually surprised nobody sells these on flea bay considering these ECS boards die all the time and are hard to find.
But one thing i should point out is the D945GCLF/2D boards will not work with any ION software version below 2009.5. In that case your best (cheapest) option is the non-official Asus A7n8x-vm/la. :cheers:
tthorn125
« Reply #2 on: April 28, 2015, 09:14:40 pm »
Thanks.  Currently software is 2011.
I'm very competent with computer hardware and internals, but not intimate with Megatouch.  New to the whole line.
You don't think that it'll line up at all?
mahkeymike
« Reply #3 on: April 28, 2015, 10:01:32 pm »
No the itx boards dont line up to the mounts on the ION  Evo cases. You need to basicly make a template from your ECS board and find a good spot to mount the itx board to the template. Bottom line is its a bit of work. But worth the effort. Those intel boards will last 10x longer then any of the other ION mobo's.
tthorn125
« Reply #4 on: April 30, 2015, 09:05:05 pm »
I've read on many sites that ATX and mini-atx / mini-itx are the same 4 screw holes.  Are you saying that the ECS boards are their own configuration?
mahkeymike
« Reply #5 on: April 30, 2015, 10:07:21 pm »
On the purple ECS board, only the holes on the back corners have mounts on the Ion case. The front gets inserted into slots. Its hard to explain. I suggest you open it up and look. You will see what i am talking about.
