Author Topic: Remove Game info and press OK in mamewah?  (Read 2870 times)
angryadmin
  • Last login:October 31, 2013, 12:14:53 am
« on: December 26, 2003, 05:23:12 pm »
I need to use the command line options to remove mame's press ok and gameinfo screens, but can't in mamewah can I???
NH
  • Last login:Today at 02:16:47 am
Re:Remove Game info and press OK in mamewah?
« Reply #1 on: December 26, 2003, 07:50:23 pm »
you don't need to... set these settings in the mame.ini that mame will generate for you if you type:  mame -cc
eightbit
  • My cab is never done...
« Reply #2 on: December 27, 2003, 02:12:23 am »
Yes you can, there is a option under emulater settings, under execution settings called "default options" and you can set your command line options here. Its easier to do what howard said as you will likely want to set a bunch of options.
« Reply #3 on: December 28, 2003, 12:24:02 am »
how is memorizing the command line options only to enter them manually in mamewahs config easier than using the heavily commented mame.ini file?
« Reply #4 on: December 28, 2003, 10:34:55 am »
Read eightbit's reply again HC, he was recommending your way :)
But yes it is best to set these options in your mame.ini file.  The Default Options setting is there to use if you must, but for MAME this is rarely (/never) neccessary.
sk8er_boi
  • Last login:November 12, 2017, 07:16:30 am
« Reply #5 on: January 01, 2004, 08:18:26 am »
this wont work for me :( it creates the extra lines on mame.ini but it still comes up the game info and all
« Reply #6 on: January 01, 2004, 11:32:58 am »
Did you set:
skip_disclaimer         1
skip_gameinfo           1
sk8er_boi
« Reply #7 on: January 02, 2004, 01:45:54 pm »
Did you set:
skip_disclaimer         1
skip_gameinfo           1
yea it wrks now thts why it didnt wrk but thks anyway for the info and thks again for making mamewah and wondering if u could give me the source as im planning of making my own fe and would like to study yours
« Reply #8 on: January 02, 2004, 01:59:07 pm »
Did you set:
skip_disclaimer         1
skip_gameinfo           1
Glad it worked.  Sorry, my source is not open atm :(
sk8er_boi
« Reply #9 on: January 02, 2004, 04:42:05 pm »
Did you set:
skip_disclaimer         1
skip_gameinfo           1
thts ok i understand tht people may want to ruin it. do u kno where i could get any help with making 1? :)
EndTwist
  • Last login:May 26, 2022, 05:04:49 pm
  • Arg.
« Reply #10 on: January 02, 2004, 08:45:24 pm »
Try at www.visualbasicforum.com...ask A LOT of questions that are different aspects of what you need. I created an FE by getting help there...
Read through this thread that (I started and) helped me very much: http://visualbasicforum.com/showthread.php?t=123825
sk8er_boi
« Reply #11 on: January 03, 2004, 08:25:24 pm »
thks ill check tht l8er i was thinking of using director mx something like tht do u have any ideas? but thks anyway for the links :) :)  just i dont kno much about vb ??? ???
derek1800
  • Last login:January 29, 2005, 03:23:31 pm
« Reply #12 on: January 03, 2004, 11:54:24 pm »
What is the setting to take away screen about this game lacks sound press ok. I have set
skip_disclaimer        1
skip_gameinfo          1
Derek
« Reply #13 on: January 04, 2004, 12:17:17 am »
you can't unless you compile your own mame.  Those messages are important so the mame devs decided not ot let you remove them.
originalself
  • Last login:March 13, 2005, 11:47:13 pm
« Reply #14 on: January 04, 2004, 12:53:55 am »
Im glad that it will still say "the sound wont work, ect ect" Then my dumb friends wont ask why they cant hear the game!
SpamMe
  • Last login:July 01, 2006, 03:19:58 am
  • .creature of bad habit.
    • Mame cabinet blog
« Reply #15 on: January 04, 2004, 12:59:34 am »
Yeah, but I wish it said "type ok or wiggle joystick."
Getting tired of answering that question :)
« Reply #16 on: January 04, 2004, 02:13:40 am »
On a 640x480 screen or less, "type ok or wiggle the joystick to continue" would take up a lot of space
eightbit
« Reply #17 on: January 04, 2004, 01:18:58 pm »
Put an instruction card on your control panel that explains it or filter out the games that don't work.
aeroflott
  • Last login:October 13, 2012, 04:50:01 pm
« Reply #18 on: January 11, 2004, 06:55:08 am »
Did you set:
skip_disclaimer         1
skip_gameinfo           1
Hi,
Just a bit more info needed here - where do I find these options? I've typed mame -cc in the command line prompt. I've opened up the ini file in MAME, but can't find Skip-disclaimer or skip_gameinfo.
T
« Reply #19 on: January 11, 2004, 07:17:08 am »
Hi,
Open mame.ini and look towards the bottom, in this section:
### Mame CORE misc options ###
artwork                 0
use_backdrops           1
use_overlays            1
use_bezels              1
artwork_crop            0
artwork_resolution      0
cheat                   0
debug                   0
# playback              <NULL> (not set)
# record                <NULL> (not set)
log                     0
maxlogsize              10000
oslog                   0
skip_disclaimer         1
skip_gameinfo           1
crconly                 0
bios                    default
aeroflott
« Reply #20 on: January 11, 2004, 08:08:10 am »
OK, I've doubled checked and
maxlogsize              10000
oslog                  0
skip_disclaimer        1
skip_gameinfo          1
crconly                0
Are not there. Typing in Skip_disclaimer etc and saving doesn't seem to change anything?
« Reply #21 on: January 11, 2004, 01:38:16 pm »
maxlogsize              10000
oslog                  0
skip_disclaimer        1
skip_gameinfo          1
crconly                0
It sounds like you are using a MAME version before those options were added.  Can't remember exactly when they were added (v0.7something I think) - try a newer version :)
« Reply #22 on: January 11, 2004, 11:02:40 pm »
I believe if you continue to have problems then this question has went beyond the relm of byoac.  You'll need to post it over on the mameworld forums for really specific, mame-related, problems.
Lilwolf
« Reply #23 on: January 12, 2004, 05:11:57 pm »
The one I want to get rid of is "no known roms exist" or whatever... because you don't even get the wiggle the joystick to solve it...
and I haven't been able to send an OK to the keyboard stream and get it to work yet...
null
  • Last login:January 13, 2004, 04:00:53 pm
« Reply #24 on: January 13, 2004, 01:19:40 am »
You can configure noname mame to skip the disclaimer, game info, warnings, and bad dump screens.
