Author Topic: Pi project, almost done, last few bits I need help with.  (Read 5281 times)
tony.silveira
  • Last login:September 27, 2024, 03:04:35 pm
    • my baby
« on: March 13, 2015, 02:33:33 am »
Hi all,
I am LOVING my Pi running emulation station and have everything set up almost completely, with these last few exceptions. If anyone has any hints, I would appreciate any feedback:
1. mame – i can’t get select + start (360 pad) to exit the emulator. I tried even setting the exit command to select + h0down (select + digital pad down) but no luck. I think i am confused on what tetrarch.cfg file to edit.
2. final burn alpha, would love to have this running as a home system instead of arcade, any way to switch?
3. ScummVM, same as #1, can’t get select + start to exit. I would like to make my GLOBAL exit command select + h0down if possible. Even left button + h0down would be great.
4. is there anyway to get the emulators to quit quietly? meaning, when i exit an emu to go back to emulation station, there is a bit of linux text visible. anyway not to have this show?
5. when exiting just about any emulator, the text gives me a couple of warnings that I would like to get rid of, they are:
“Frontend supports RGB565 – will use that instead of XRGB1555″ and
“RetroArch [WARN] :: gl_glsl_init :: [GL]: Stock GLSL shaders will be used
If I could get all of the above taken care of, I’d be 100%.
Any help is appreciated and thanks!
P.S. I am building a self contained unit in a WD "my book" hard drive enclosure, just about done in fact.
nitrogen_widget
  • Last login:November 19, 2025, 07:10:59 am
Re: Pi project, almost done, last few bits I need help with.
« Reply #1 on: March 16, 2015, 10:32:12 pm »
Are you using retropie or rolling your own setup?
tony.silveira
    • my baby
« Reply #2 on: March 27, 2015, 06:05:15 pm »
RetroPie.  I am completely new to linux and went with the "off the shelf" set up.  i've learned a lot but still way green.
sharpfork
    • KADE
« Reply #3 on: March 29, 2015, 09:47:23 pm »
I'd like to see a pic of the enclosure when you get it wrapped up.
tony.silveira
    • my baby
« Reply #4 on: March 30, 2015, 03:45:33 am »
sure thing, here is my project announcement...
http://forum.arcadecontrols.com/index.php/topic,144683.0/topicseen.html
Bloinkxp
  • Last login:August 30, 2020, 11:20:28 am
« Reply #5 on: March 30, 2015, 12:06:42 pm »
Hi,
Can't help with anything but number 1.
Watch this video by Floob
Good luck.
Nothing witty here...move along.
