Author Topic: Golden Tee Fore, HDD not fried. Update....  (Read 14621 times)
split
  • Last login:November 13, 2015, 10:16:29 pm
  • Get r fixed
Re: Golden Tee Fore, HDD not fried. Update....
« Reply #40 on: November 10, 2015, 01:00:57 pm »
I have the Golden Tee 2005 with a Red board
D20, Stat1 is on solid
D5A, Stat2 is blinking
IDE Activity, appears to be a RED LED and it is on very faintly.
D20 should be blinking....so what does this mean?
« Last Edit: November 11, 2015, 10:09:33 am by split »
Mtmanko
  • Last login:February 11, 2020, 08:49:47 pm
« Reply #41 on: July 28, 2017, 11:45:23 am »
Having the issue with being stuck on operator menu.  Goes through all checks well but will not exit operator menu.
ed12
« Reply #42 on: July 28, 2017, 01:04:20 pm »
if u have stuck or no green led's
the red led is the least of your problems
with green led/led's stuck .let's look at the bus
with d5a blinking your secondary bus is running
this is u53/modem/card1 ic/reset ic/and a few others
with d20 solid
your primary bus is not working
this would be u15/u26/u61/u2
now so u are clear as mud on this u2 is where the primary/secondary bus meet
so I tend not to look at it first
but I foucs my thought to u15
bent pin/bad socket/broken trace
start there
ed
