Author Topic: So an idiot downloads Crunchbang and wants to play MAME on it  (Read 8130 times)
  • Last login:Today at 01:47:41 pm
« on: December 02, 2014, 02:30:30 pm »
What do?
Louis Tully
Re: So an idiot downloads Crunchbang and wants to play MAME on it
« Reply #1 on: December 02, 2014, 05:27:04 pm »
« Last Edit: February 12, 2015, 06:22:15 pm by Louis Tully »
« Reply #2 on: December 02, 2014, 11:08:00 pm »
Oh lawd...
Louis Tully
« Reply #3 on: December 03, 2014, 02:44:23 am »
« Last Edit: February 12, 2015, 06:22:52 pm by Louis Tully »
  • Last login:December 02, 2025, 03:23:14 pm
« Reply #4 on: December 03, 2014, 09:16:47 am »
Ahh linux & SUDO....
General_Faliure
  • Last login:March 01, 2022, 07:30:40 am
    • My Arcade Cab
« Reply #5 on: December 06, 2014, 07:17:58 am »
I tried crunchbang a while ago, but the current version is a bit old.
It would be a great back-end for an arcade cab, but are the emulators a bit up to date?
I am currently using Lubuntu, which works well for me.
My Arcade cab: https://goo.gl/photos/yE1KACHryQjCaaCj7
Core2 duo8400 @3.6 Ghz, 4Gb of mem, Geforce 9500.
Linux Mint 17.3 XFCE, Mame, Mess, Daphne FS-Uae, Mednafen and some more.
Mah!cade
nitrogen_widget
  • Last login:November 19, 2025, 07:10:59 am
« Reply #6 on: December 07, 2014, 12:39:44 am »
I have pclinuxos lxde.
One 32 bit with compiled advance Mame .106 and booting up to icewm using about 80 mb of ram and another with 64 bit patched Mame .149 .
The 32 bit version will run on a p3 1 GHz with 256 mb of ram.
A little slow to get going and booted up but afterwords all is good.
The 64 bit version  I'm not too concerned with memory usage but its still under 150mb.
Took a lot of installs and failed attempts at compiling to get it right.
But I think it was worth it.
General_Faliure
    • My Arcade Cab
« Reply #7 on: December 07, 2014, 06:29:20 am »
Why compile?
Isn't Mame in the repositories?
That's why i use Lubuntu, you can find almost everything in the repositories, or add extra PPA's, or install stuff from .DEB files.
Mah!cade
nitrogen_widget
« Reply #8 on: December 07, 2014, 07:44:24 am »
Why compile?
I compile because I like having some control over which version of Mame I use and I like not having the nag screen.
