Author Topic: Arcade side art, CPO, marquee, bezel, etc. printing available Chicago, IL  (Read 35126 times)
stpcore
  • Last login:February 09, 2019, 05:48:56 pm
I've been a member here for quite some time and would like to contribute by giving back to the community.
I have been doing commercial vinyl decal printing out of my home for the past 5 years and thought it would be fun to help some of the members here to complete a project (even if you are working with a limited budget).  I use a Roland printer with solvent inks on Orajet RapidAir (no air bubbles) vinyl.  Everything is of commercial grade and quality.  The size of the project (small or large) is of no concern as I can print just about any size or quantity.
If you would like to get a quick quote please feel free to post here or send me a PM and I will get back to you within 24 hours (often the same day).  If you reside in Illinois I am located in St. Charles and would be happy to offer a local pick up to save on shipping or to help you to meet a deadline.
There are some very respectful vinyl printers in this community and I would also like to offer my services if needed!
« Last Edit: March 07, 2015, 12:26:50 pm by stpcore »
Offering commercial grade vinyl decal printing for cabinet side art, control panel overlays, monitor bezels, marquees, etc.
chopperthedog
  • Last login:Yesterday at 07:14:27 pm
Re: Arcade side art, CPO, marquee, bezel, etc. printing available Chicago, IL
« Reply #1 on: September 12, 2014, 11:59:26 am »
Do you offer laminating of textured poly?
good day.
stpcore
« Reply #2 on: September 12, 2014, 12:04:14 pm »
I do use a textured polycarbonate laminate (upon request) for those that are looking for extra protection for a CPO, bartop side art, etc.  I can laminate anything that I print but I don't offer laminating services on any vinyl or materials that I did NOT print.  Not sure if that helps?
chopperthedog
« Reply #3 on: September 12, 2014, 12:09:55 pm »
Cool. Yeah, I meant as in if you printed a cpo can you laminate with the textured poly. Sorry for the confusion.
good day.
stpcore
« Reply #4 on: September 12, 2014, 12:14:24 pm »
No apologies necessary as I thought that is what you were asking.  Absolutely I can do that for you.  I personally recommend using the laminate every time on a control panel unless it's sitting under plexi of some sort.
  • Last login:Yesterday at 09:40:52 pm
« Reply #5 on: September 12, 2014, 12:17:27 pm »
$ per square foot?
stpcore
« Reply #6 on: September 12, 2014, 12:21:15 pm »
Square foot pricing may range slightly but in most cases it would be around $5 - $6 per square foot.  The only extra costs involved (other than shipping) would be if custom design work or editing had to be done on your art file before printing.  If you have a printable image (high res jpeg, eps, vector, pdf, ai, etc.) then there should be no additional costs involved.
« Last Edit: September 12, 2014, 12:27:46 pm by stpcore »
JimmyU
  • Last login:July 28, 2025, 08:19:07 pm
  • I believe I can fly!
« Reply #7 on: September 12, 2014, 01:59:13 pm »
Since you're really close to me, I'll keep you in mind when I need something.
  • Last login:November 09, 2025, 07:06:54 pm
« Reply #8 on: September 12, 2014, 02:41:12 pm »
RGB or CMYK?
stpcore
« Reply #9 on: September 12, 2014, 03:45:46 pm »
Thanks JimmyU.  Let me know what you need.  Where are you located?
RGB or CMYK?
My Roland printer is CMYK.
« Reply #10 on: September 12, 2014, 04:12:02 pm »
Don't mind Haruman.  He's just trolling you.  Or incredibly stupid.
 :dizzy:
jennifer
« Reply #11 on: September 12, 2014, 04:33:58 pm »
    That would be a valid question for getting the print to match the desired pantone color.
Well Fed Games
  • Delicious!
« Reply #12 on: September 12, 2014, 04:49:54 pm »
I'm over in NW Indiana and getting close (no really, I am!) to needing some side art printed. Will keep you in mind when the time comes. What part of the city are you in, generally, and would you offer local pick up? (it is like a 45 min drive for me, so not sure if it is worth it in my case).
stpcore
« Reply #13 on: September 12, 2014, 05:08:26 pm »
When attention to color matching is extremely important I have a printed Roland color chart that I can use as reference.  I can also send out smaller versions of this chart so that customers can find the best color match and by giving me the swatch number from the chart it's a guaranteed match since my printer not only will be printing the decal but also printed the chart.   ;)
I am located about an hour west of Chicago in St. Charles.  I don't mind local pick up at all as long as you don't mind picking up from my personal residence.  That being said I also use USPS Priority or FedEx Ground / Home delivery.
jennifer
« Reply #14 on: September 12, 2014, 05:19:13 pm »
     No don't get Jennifer wrong Stp, I imagine your color is spot on, Im referring to the "stuipid" question as to where most better printers are cmyk for that reason.
« Last Edit: September 12, 2014, 05:21:49 pm by jennifer »
stpcore
« Reply #15 on: September 12, 2014, 05:21:43 pm »
I didn't take you the wrong way at all, Jennifer.  Thanks!
stpcore
« Reply #16 on: September 24, 2014, 11:04:24 am »
Just a little weekly bump!  Thanks.
  • Last login:Yesterday at 08:32:45 pm
« Reply #17 on: September 24, 2014, 11:09:43 am »
Are you able to print directly on to plexiglass?
stpcore
« Reply #18 on: September 24, 2014, 11:15:35 am »
I cannot print directly to plexiglass (I don't have a flatbed printer).  Sorry.
« Reply #19 on: September 24, 2014, 11:43:25 am »
Are you able to do a print, then attach it/laminate it/adhere it to the backside of the plexi so it looks like a real bezel?
stpcore
« Reply #20 on: September 24, 2014, 11:59:48 am »
If it's going UNDER the plexi you wouldn't necessarily need a laminate.  The laminate could be useful if applied to the top side but that's personal preference.  If you are local I could help you with the plexi application.  Send me a PM and I will help you to the best of my ability.
« Reply #21 on: September 24, 2014, 12:23:19 pm »
I'm in Phoenix.
Basically, I'd like to make my bezels like so: A sheet of plexi, with the printed bezel attached directly to the backside of the plexi so it's all one piece. That way, I don't have to sandwich the art between two pieces of plexi, I don't have to mount the artwork to foamboard, anything like that. To me, that would be idea.
I'd like something that looked like jdbailey's marquee here - on his, I'm sure the art has been printed directly on the plexi, but that's the look I'm going for.
stpcore
« Reply #22 on: September 24, 2014, 12:53:15 pm »
You would need to get your art reverse printed on clear vinyl and then backed with white vinyl (most color printers do not print white which is why you would use white vinyl as the background to fill in those areas that should be white).  Now when you apply the clear vinyl with white background to the underside of your plexi it will display correctly (not in a reversed orientation).  You could also back the clear vinyl with a piece of white poster board if it was easier.
screamingtiger
  • Last login:November 22, 2016, 11:48:41 am
« Reply #23 on: October 01, 2014, 07:49:47 pm »
how much per square foot for this PCL?
thehammer12
  • Last login:October 24, 2021, 01:46:34 pm
  • Arcade Breaking Specialist
« Reply #24 on: October 10, 2014, 10:36:36 am »
I will PM you as I may need some work done soon.
MaxpowerX360
  • Last login:April 22, 2016, 04:01:31 pm
« Reply #25 on: December 03, 2014, 04:14:18 pm »
Very interested in getting a quote for printing artwork for my cabinet. Thx
infrarad
  • Newbie
  • Last login:May 02, 2023, 12:26:09 am
« Reply #26 on: December 03, 2014, 07:46:23 pm »
Do you offer or have any contour cutting abilities on printed vinyl?
skyzophrenyk
  • Last login:March 27, 2015, 11:56:47 am
« Reply #27 on: December 12, 2014, 04:36:45 pm »
Definitely will keep this in mind in the future.
Does this unit have a soul?
CharlesDeMar
  • Last login:October 11, 2017, 11:46:41 am
« Reply #28 on: January 14, 2015, 04:42:19 pm »
I recently got a control panel and marquee printed by stpcore.  Great price, fantastic work, and a helluva nice guy as well.  Will definitely do business with again.  Looking forward to my next printing job.  Thanks!
stpcore
« Reply #29 on: January 19, 2015, 07:52:41 pm »
Thanks for taking the time to post here as that was very thoughtful of you.  It was fun working with you on your project!  Thanks for the trust and your kind words.
stpcore
« Reply #30 on: January 19, 2015, 07:54:30 pm »
Most of the work I do is contour cut so the answer to your question is, "yes".
I apologize for not replying to some of these posts as I did not realize I had any unread posts in this thread.  For some reason I don't get notified all of the time of new posts or even PMs with my email carrier.  I will try to check back in this thread more frequently but the quickest way to reach me is via PM.  Thanks!
SNAAKE
  • Trade Count: (+29)
  • Last login:November 16, 2025, 04:44:38 pm
« Reply #31 on: January 20, 2015, 09:32:17 am »
you have the sticker type material that wraps around the cabinet then I can install tmolding?
check this picture and see if you can tell. I got this from mamemarquees.com I can't remember exactly what the material actually is.
stpcore
« Reply #32 on: January 20, 2015, 10:07:31 am »
Yep, it's adhesive backed commercial grade vinyl.  Regarding side art I do a contour cut (cuts the final print work in the shape of the cabinet side) with some extra slack along the perimeter so that once applied it will wrap around the edge and will be tucked under the t-molding.
« Last Edit: January 20, 2015, 03:45:16 pm by stpcore »
jkasch10
  • Last login:May 20, 2015, 08:23:25 am
I am interested in a CP overlay, 2 sides and a Marquee, please e-mail me at jason_kasch@comcast.net
Hey there, you'll need a post count of 5 to PM anyone.  It's a spam reduction thing.   :cheers:
jkasch10
stpcore printed my Vinyl graphics and CPO with Laminate overlay and MAN THEY ARE AWESOME!!! I thought my arcade was cool before but once I put on these graphics it went to a whole new level. If you are looking to set your arcade apart from everyone else reach out to him!! Attached here are pictures of the final product, you be the judge.
stpcore
Thanks for the kind words!  Nice work on your bartop!
Maxatron4000
  • Last login:June 03, 2015, 03:36:51 pm
  • Loving every minute of it.
    • Some stuff I've build and haven't updated in forever
Hi Stpcore,
    I'm pretty new to the site and can't quite figure out how to pm you about details. Mind emailing me?
-Maxatron4000
Maxatron4000
Sorry to be so inept but the site isn't letting me reply to messages or view profiles. I've messaged the admins but could you please email me or message me your email so we could communicate that way?
-Maxatron4000
Mr_Numbers
  • Last login:December 01, 2017, 10:49:05 am
  • Long time lurker, first time builder
I think you need to make atleast 5 post before you can send a PM.
