Main > Driving & Racing Cabinets
Just got Immersion FFB!
<< < (2/5) > >>
BadMouth:
--- Quote from: Hadeys on May 24, 2014, 02:39:29 am ---Alright so I acquired the power supply, and everything is wired up great!  Where can I get that UI I keep seeing for it? I downloaded the driver expecting it to be there but had no luck.
It's part of the driver.
It shows up when you look at the device in Windows control panel.
For Windows 7, it's Control Panel>Devices and Printers
Then right click on the device and select "game controller settings"
For XP it's much easier to find, but I don't have an XP pc booted up at the moment to refresh my memory.
I do remember that there is no right clicking necessary in XP.
Hadeys:
Anybody know why force feedback in model2 only turns one direction?  Also, no centering feedback at all.
BadMouth:
--- Quote from: Hadeys on May 25, 2014, 12:26:03 am ---Anybody know why force feedback in model2 only turns one direction?  Also, no centering feedback at all.
Strange.  It works fine with other games?
Post your emulator.ini file from your model 2 folder.
If the issue is limited to Model 2, the answer has to be in that ini file.
Hadeys:
--- Quote from: BadMouth on May 25, 2014, 09:57:05 am ---
Yeah the problem is just with model 2 and only since I switched to the immersion board. Here are my ini settings regardless..
Input]
XInput=0         ;Enable support for Xbox360 compatible devices
EnableFF=1         ;Enable Force Feedback Effects
HoldGears=0         ;Set to 1 to return to Neutral in driving games when the gear shift key is released
UseRawInput=0         ;Read mouse through Rawinput, allowing 2 mice
RawDevP1=0         ;Assign specific RawInput devices to players. If you have more than 2 mice
RawDevP2=1         ;set which one is assigned to each player (0-based)
;FORCE EFFECTS PARAMETERS
;FE_CENTERING Effect (Spring centering effect)
FE_CENTERING_Gain=10000      ;Global gain
FE_CENTERING_Coefficient=10000   ;0-10000
FE_CENTERING_Saturation=10000   ;0-10000
FE_CENTERING_Deadband=10   ;10%
;FE_CLUTCH Effect (Friction, wheel turn hardness)
FE_CLUTCH_Gain=1.0      ;Global gain
FE_CLUTCH_Coefficient=10000   ;0-10000
;FE_LEFT,FE_RIGHT (Constant force in a direction)
FE_LEFT_Gain=1.0      ;Global gain
FE_LEFT_Magnitude=10000      ;0-10000
FE_RIGHT_Gain=1.0      ;Global gain
FE_RIGHT_Magnitude=10000   ;0-10000
;FE_UNCENTERING (Sine force, wave the wheel, rumble)
FE_UNCENTERING_Gain=1.0      ;Global gain
FE_UNCENTERING_Magnitude=10000   ;0-10000
FE_UNCENTERING_Offset=-200
FE_UNCENTERING_Phase=0
FE_UNCENTERING_Period=56000
Jollywest:
I also use the Immersion board, here are my settings for Daytona USA if you want to give them a try.
FE_CENTERING_Gain=0.5       ;Global gain
FE_CENTERING_Coefficient=5000   ;0-10000
FE_CENTERING_Deadband=0    ;10%
FE_LEFT_Gain=2.0      ;Global gain
FE_RIGHT_Gain=-2.0      ;Global gain
FE_UNCENTERING_Gain=2.0      ;Global gain
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
