Author Topic: Lubuntu - Flashing Screen  (Read 7012 times)
d4damage
  • Last login:May 07, 2014, 07:20:46 am
« on: April 16, 2014, 06:23:30 pm »
Hi,
When I try to boot the latest Lubuntu live cd from usb, it gets as far as showing the mouse pointer just before the desktop would normally load but then the screen flickers/flashes without end and never finishes loading.
Anyone know how to resolve this ?
nitrogen_widget
  • Last login:November 19, 2025, 07:10:59 am
Re: Lubuntu - Flashing Screen
« Reply #1 on: April 17, 2014, 04:59:04 pm »
Sounds like it doesn't like your graphics card.
I don't know Lubuntu but other linux distro's have a safe graphics option at the main menu.
you can try that.
General_Faliure
  • Last login:March 01, 2022, 07:30:40 am
    • My Arcade Cab
« Reply #2 on: April 18, 2014, 09:24:20 am »
What hardware / version of Lubuntu are you using.
14.04 has just arrived.
My cab is running Lubuntu, and doing fine for years now.
My Arcade cab: https://goo.gl/photos/yE1KACHryQjCaaCj7
Core2 duo8400 @3.6 Ghz, 4Gb of mem, Geforce 9500.
Linux Mint 17.3 XFCE, Mame, Mess, Daphne FS-Uae, Mednafen and some more.
Mah!cade
d4damage
« Reply #3 on: April 19, 2014, 02:48:01 pm »
I've been trying to use the 13 version.
It's an onboard video chip.
Any idea how to boot with the safe vga option ?
Louis Tully
« Reply #4 on: April 29, 2014, 02:32:01 pm »
« Last Edit: February 12, 2015, 05:07:49 pm by Louis Tully »
d4damage
« Reply #5 on: May 04, 2014, 01:16:23 am »
Hi,
Try setting NOMODESET to the boot option.
This will give you some info on it.
 http://ubuntuforums.org/showthread.php?t=1613132
Thanks Louis.
It's now got a box floating around the screen saying the refresh rate is out of sync (black background).
What should I try next ?
Louis Tully
« Reply #6 on: May 04, 2014, 06:06:10 am »
« Last Edit: February 12, 2015, 05:09:23 pm by Louis Tully »
General_Faliure
    • My Arcade Cab
« Reply #7 on: May 04, 2014, 10:27:00 am »
What videochip do you have?
Try to use the latest Lubuntu (i just updated my cab to it)
Maybe you can add a dedicated videocard, it doesn't have to be expensive, in my previous setup i used a geforce 5200, which worked fine.
Mah!cade
d4damage
« Reply #8 on: May 07, 2014, 07:18:45 am »
Not sure, it's a prebuild bartop cab.
General_Faliure
    • My Arcade Cab
« Reply #9 on: May 07, 2014, 08:48:03 am »
Can you try  "ctrl-alt-F1" which should give you a black screen with a cursor.
Then type "lspci" which should give you a lot of info about your hardware, including your graphics chip.
The latest (L)ubuntu should work with almost anything if it's not too old.
Mah!cade
