Author Topic: 5V DC to 6V DC  (Read 7241 times)
dhansen
  • Last login:November 28, 2025, 10:41:14 am
  • No Quarters Needed
    • Arcade Stupidity
5V DC to 6V DC
« on: November 16, 2003, 03:02:03 am »
Hello,
Wasn't there a separate audio forum earlier today?  When did these get combined?
Anyway, I have hacked a amplifier out of an old set of PC speakers and I was wondering if I could power this off the 5v of my switching power supply.  The amp origianaly took a 6V power supply, but I was wondering if the 1V would make any difference.
Doug
..as his cold lifeless fingers lie motionless on the garage floor, all he could hear in his head was...I JUST WANTED TO PLAY A GAME OF DONKEY KONG!!
OSCAR
    • Oscar Controls
Re:5V DC to 6V DC
« Reply #1 on: November 16, 2003, 10:05:19 am »
Yes, you can do this since it is only an amplification circuit.  About the worse that can happen is the amp will be a little quieter, but probably not enough to notice.
In a similar vein, Williams sound boards require +12V & -12V from the power supply for the amp (24V), but if you use a newer arcade switching power supply, you only have +12, +5, and -5V per the jamma standard.  In this case, I wire the -5V to the -12V input to the sound board, and it still works fine.  It just won't as loud as it would with -12V.
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:November 22, 2025, 12:26:51 pm
Re:5V DC to 6V DC
« Reply #2 on: November 16, 2003, 11:58:48 am »
I just can't leave well enough alone :)
Hello,
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
dhansen
    • Arcade Stupidity
Re:5V DC to 6V DC
« Reply #3 on: November 16, 2003, 02:49:50 pm »
Hello,
Ahhhh, I thought I was going nucking futz!  Thanks Oscar, I should have listened during the electronics chapter in science.  :-[
Doug
dhansen
    • Arcade Stupidity
Re:5V DC to 6V DC
« Reply #4 on: November 18, 2003, 12:21:27 pm »
Hmmm this didn't work too well.  I hooked up the power to ground and +5v 1A on the switching power supply and the red light on the amp lit up but it dimmed when I plugged the audio jack into the PC.  What would cause this?  Anyway, I just ended up using the transformer that came with it.
My power strip is wired to 4 plugs are on a switch and two are constant power so all the lights, sound, and monitor come on with one switch.  The PC's bios is set so I can power it up from the control panel with a couple clicks of a button.
Doug
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
Re:5V DC to 6V DC
« Reply #5 on: November 21, 2003, 08:42:57 pm »
Hello,
Good Grief Carlie Saint!    ;)
Macros
  • Last login:December 31, 2009, 07:40:44 pm
Re:5V DC to 6V DC
« Reply #6 on: December 03, 2003, 02:11:31 pm »
Hi,
I have a similar situation except I need to go from 12 volts to 9 volts to power my audio amp. The amp requires 9 volts .7 amps. I've tried feeding it 5 and 12 volts from my powersupply but it didn't like that much. Originally, I was using the ac adapter but it created a magnetic field causing my monitor to swim unless the refresh rate was exactly 60hz to coincide with the frequency of ac power.
I guess I'll have to order a voltage regulator like a LM2940T-9.0 from digi-key. It's $6 dollars for one but shipping will be $12, so I'll have to pad my order with some other stuff.
Macros
StephenH
Re:5V DC to 6V DC
« Reply #7 on: December 17, 2003, 01:57:51 am »
You can probably get a replacement 6V adapter at Radio Shack, or an electronic supply store.
MrDT
  • Last login:November 30, 2004, 12:11:55 am
  • I saw a squirrel!
Re:5V DC to 6V DC
« Reply #8 on: January 14, 2004, 11:06:09 pm »
Hi,
Macros
It might be worth trying it on 7 volts. The 7 volt trick was initially used by modders who wanted to quieten their fans, simple instructions on how to do this can be found here: http://www.cpemma.co.uk/7volt.html
I don't know if it'll work for you (due to me being too dumb to work out the current you'd get), but it might be worth a try before you go off and buy some stuff you might not need ;)
Case modder + mame fan = cab buildin' time ;)
Macros
Re:5V DC to 6V DC
« Reply #9 on: January 15, 2004, 09:53:24 am »
I knew about the 7 volt trick but I was a little apprehensive about using it with the speaker amp's circuit. It's fine for something simple like power to a fan. I ended up buying parts locally to make up a circuit using a 7809 fixed voltage regulator. I bought enough parts to make 5 of these for less than $12.
It's a pretty simple thing to do, here is a schematic.
