Main > Driving & Racing Cabinets |
fooling with m2emu network |
<< < (43/68) > >> |
vandale:
--- Quote from: SailorSat on June 08, 2019, 03:05:57 pm ---Hm... That should work. Do you get any error? --- End quote --- The game won’t link at all, I get network error immediately after the screen that says master and slaves, nodes etc. if I remove the code from the script then it works fine and links but fails like it used to randomly. Am I meant to run lagfix and the script together? Thanks Sent from my iPhone using Tapatalk |
SailorSat:
Hm... Then I can't help. I have "FrameSync=1" in "m2network.ini" and the script. Other than that I didn't change anything. |
vandale:
--- Quote from: SailorSat on June 10, 2019, 09:48:18 am ---Hm... Then I can't help. I have "FrameSync=1" in "m2network.ini" and the script. Other than that I didn't change anything. --- End quote --- Do I still need to run lagfix also or does it only need the script and framesync to work? Thanks Sent from my iPhone using Tapatalk |
vandale:
--- Quote from: SailorSat on June 10, 2019, 09:48:18 am ---Hm... Then I can't help. I have "FrameSync=1" in "m2network.ini" and the script. Other than that I didn't change anything. --- End quote --- Please post a copy of your LUA with widescreen and network fix. Thanks |
XSFDriver:
G'day Vandale, was wonderin'... (from your "G'Day mate" earlier), if you were down under as well, yeah? ...Anyway, I'm no programmer (only done a bit of "Basic" YEARS AGO), but I'm trying to get my head around the .lua scripts and how they work/what they do... I've been reading the "model2lua.txt" trying to understand the contexts, layouts of these. Also checked out the .lua scripts of other roms that were packaged in with Model2 1.1a (not that I get what they mean, but I gotta start somewhere)..... and was wondering, what this section of your lua script does exactly?- function Frame() I960_WriteDWord(0x005ec6b0,0x00000000) end Also, to you others who do coding, I've done a little research, but can you tell me if I'm on the right track (or not)... are the .lua scripts written in "C" programming format or something else? I can see a BIG learning curve coming up for me. I know that I might come across as a bit of a noobie with this, but I gotta start somewhere, to understand whats going on in the background, if I'm gunna get this 4 player Model 2 system up and running in the future sometime (and mess with it's head), and I would like to help with SOME input in the future here, if possible. Cheers. |
Navigation |
Message Index |
Next page |
Previous page |
