Author Topic: Large Screen Big Buck Hunter Pro  (Read 9154 times)
Alphacowboy
  • Last login:January 12, 2013, 08:20:25 am
« on: December 23, 2012, 04:53:51 pm »
New here!
Looking to build a large screen version of Big Buck Hunter Pro.  I have gotten a hold of the loaded motherboard including processor, memory and HDD preloaded with BBHP.  I also got the gun.  I can wire up the unit by following the schematics but where can i get the two internal pcb boards listed on the schematics?  One is a jamma board (are these universal?) Not sure what the other board is.
Re: Large Screen Big Buck Hunter Pro
« Reply #1 on: December 23, 2012, 05:27:12 pm »
Really hard to answer without more info than that.  Can you link the manual to this thread?
BobA
  • What Me Worry?
« Reply #2 on: December 23, 2012, 05:30:44 pm »
Big Buck Hunter Pro does not use a mother board.   It has a jamma to USB and serial interface board but the main work is done by a PC that the HDD connects to.  There are 2 boards for the light guns and you need a CRT type monitor.   LCD or PLASMA will not work so to go larger than the 27 inch CRT monitor that comes in the cab you will need a larger CRT monitor.
Alphacowboy
« Reply #3 on: December 23, 2012, 06:38:32 pm »
I was looking to use a projector like they have at BassPro shops.
Well the OEM pc motherboard i bought was cheap, so no biggy there.  I am curious if the generic USB jamma boards available on ebay and other sites would work.
Alphacowboy
« Reply #4 on: December 24, 2012, 12:32:18 am »
Does this mean all HD monitors are out?  DLP TVs and DLP Projectors maybe?  I have a 65" Optima that needs a purpose!
BobA
  • What Me Worry?
« Reply #5 on: December 24, 2012, 01:39:26 am »
All projectors or rear projection are out as it has to be a CRT monitor.  Sorry don't know anything about the generic usb jamma boards available on ebay.
  • Last login:Today at 05:13:46 am
« Reply #6 on: December 24, 2012, 02:51:35 am »
How about a Hercules Visual Pinball setup?  :duckhunt
Alphacowboy
« Reply #7 on: December 24, 2012, 10:37:53 am »
Just trying to learn this stuff here.  Why do the guns require the CRT monitor and how did they get past that on the new HD models w/LCD monitors?  Thanks for the help guys, hopefully I can get it all figured out and working!
chopperthedog
  • Last login:Yesterday at 02:35:56 pm
« Reply #8 on: December 24, 2012, 11:06:50 am »
http://www.howstuffworks.com/question273.htm
For guns that work on LCD screens they use this tech. i.e. this gun http://www.ultimarc.com/aimtrak.html that uses infrared triangulation for aiming purposes.
good day.
Alphacowboy
Alphacowboy
« Reply #10 on: December 24, 2012, 04:41:09 pm »
My ultimate plan would be to use an airsoft rifle modified with the oem optics but still use a CO2 cartridge so that the gun has a "realistic " feel.  If any of you have been to the virtual ranges at gander mountain you'd understand where i want to go with this idea.
